Question about Dell Motherboard Socket 775 For OptiPlex GX280 Mini-Tower System C7195
I need a diagram and/or a manual for this motherboard, Dell tech supp. does not provide one. System is Optiplex GX280. Thanks in advance!
  • 436 Answers
Here is the website with pictures.
http://support.dell.com/support/edocs/systems/opgx280/en/ug/replbrd0.htm
i hope it helps.
Posted on Mar 25, 2011
I need to remove my dell optiplex GX280 motherboard
You're supposed to pull up on the Green tab, then slide the Support Plate (Metal tray), with the motherboard on it towards the Front of the computer,
Scroll down towards the bottom of the page,
"If your system board is mounted to the chassis using a metal tray, remove the tray and the board as one piece: Pull up on the tab and slide the system board assembly toward the front of the computer, and then lift the board away"
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 14, 2012 | Dell Optiplex GX280 (99301) Motherboard
SATA Hard Drive Type The Dell Optiplex GX280 Takes?
It makes no difference providing the computer motherboards support SATA interface.
SATA 1 and 2 drivers are in the BIOS. If all the computers have SATA 1 you can upgrade the BIOS to latest version via Dell's support website.
Regards.
Jul 08, 2010 | Dell OptiPlex GX280 PC Desktop
I have dell optiplex GX280 System in unbranded casing, Kindly suggestion about Processor Fan Voice, he is so shouting
The fan(which runs on a bearing) has aged, it must be replaced. Luckily this is an easy and cheap fix. Pick one
http://bit.ly/9qzXBz
May 30, 2010 | Dell Optiplex GX280 (99301) Motherboard
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dell Optiplex Gx280 - cant detect two IDE hard drives
You should attach two hard drives on primary ide. Set both jumpers to cable select ( or one on end is master, middle one is slave). The one at the end of the cable is where your o/s should be. You could try putting the third on seconday, along with your dvd rom.
Hank
Jun 09, 2009 | Dell Optiplex GX280 (99301) Motherboard
How do i replacea fan on a dell gx280
First select the chassis type of GX280 you have from the link below
http://support.dell.com/support/edocs/systems/opgx280/en/ug/index.htm
The page would redirect you to the user manual for the system
Look under Add Remove components > Processor or motherboard.
The Fan removal instructions are given step by step with pictures
Thanks
Proton
Do rate the solution
Apr 30, 2009 | Dell OptiPlex GX280 PC Desktop
What cpu will it except
The M9475 board came on the GX280 amongst other Dell models. This is socket LGA775
Apr 13, 2009 | Dell Computer Refurbished SYSTEM BOARD -...
Dell Motherboard Socket 775 For OptiPlex GX280 Mini-Tower System C7195 Logo
542 people viewed this question
Alun Cox
