Question about Sony BRAVIA KDL52XBR2 Television
The MTS/SAP option on my Sony Bravia is greyed out and I cannot select it in any menu
    Scholar:
  • 146 Answers
It will only light up if the program has an SAP broadcast not all shows or channels have a Secondary Audio Program broadcast
Posted on Mar 25, 2011
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
Sap
Set the MTS option to "Auto SAP". See page 35 of the manual at http://www.docs.sony.com/release/KDL52XBR2.pdf
Jun 11, 2013 | Sony BRAVIA KDL52XBR2 Television
How can i switch my sylvania mts sap tv from fullscreen mode to widescreen mode?
kindly check the remote settings and your manual for it. Select Menu and click Settings, then sort it out until you see the option Wide so that you can select it to widen your screen..
Sep 06, 2011 | Sylvania SRT2232S 32" TV
I think that my TV soney braiva xbr has an issue with SAP but some ch. are in spanish some do not have sound How do i reset this tv?
Press MTS/SAP on the remote (under the number buttons) to go between the 3 options of STEREO or MONO or AUTO SAP. Not all channels will have SAP (secondary audio program). Selecting stereo should eliminate any secondary audio.
Mar 24, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony bravia 19 inch voice over for the blind what button do we press to stop it
Use your remote and go to your MENU.
Then go to AUDIO.
Select OPTIONS.
Make sure your MTS is set to STEREO and not SAP.
That should be it.
Good luck and please post back with how you make out.
Jan 24, 2011 | Televison & Video
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
No sound in Sony Bravia
If the sound is not heard during tuner (channel) but is when using an AV input (DVD) then it is likely the Second Audio Program (SAP) has been engaged. Some SONYs simply have a button on the remote to toggle through choices, SAP is used primarily for second language transmission of audio. Either move to a PBS station or some other channel that specifies SAP programmimg or turn the choice (MTS in some SONY menus) back to "main" by either a remote button or in the audio menu.
Good luck.
Jun 28, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
20" RCA television
Greetings de_on,
Per your owners manual I found you should have an option in your Audio menu labeled MTS. You should be able to adjust the MTS by selecting it and press the + key.
There should be three options under MTS: Stereo, Mono, Auto SAP. You would probably want to select Stereo as Auto SAP will engage the Second Audio Programing which will cause other sound problems.
Hope this helps.
Jon
Go Ahead. Use Us.
May 12, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony BRAVIA KDL52XBR2 Television Logo
924 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
