Question about Apple MacBook Pro Notebook
Macbook startup issue
Wanda, if that is the case, (your computer being locked) you may have to go to your network administrator or whoever manages the network in your school and ask them to remove the batteries to re-initiate the boot-up process of the computer. it is just a very simple method, i'm sure they will do it for you.
  • adin kapul May 11, 2010
    tell me the problem
  • Paul Burrows
    Paul Burrows May 11, 2010
    Hi there
    Can you please clarify the problem. The solution suggested above seems a bit strange.
  • Apple Expert
  • 481 Answers
There is no problem statement here, only a highly questionable solution to some other issue.
Posted on Sep 21, 2009
How do i change who the administrator is on my a1502 mac book pro
You need to have the administrator password to manage administrators
Jan 31, 2016 | Speck SeeThru Satin Malachite Green 15 "...
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
When I turn my apple MacBook Pro on it goes to a system lock pin entry screen. I tried resetting the ram but then it goes to an administration password entry screen. What options do I have. I think the...
If you have a apple store account and wifi, you hold down the Option and the R buttons while booting until the apple symbol appears, follow menu from there to install proper OS
Sep 21, 2013 | Apple Genuine 13.3" Macbook Pro Unibody...
How do you unblock facebook from school laptop?
Usually blocks are set by the school system administrator and cannot be unblocked because you do not have administrative privileges. Schools do this to avoid problems with FB and other social networking sites because they own the computers, and could face liability issues if there were problems caused by accessing those sites. Sorry...
Aug 30, 2011 | Apple MacBook Mac Notebook
Forgot password for macbook air
Dear Sir,
Welcome to Fixya Support
Resetting Your Password You can reset your administrator password and passwords for all other accounts. To reset your password, using a partner computer and Remote Install Mac OS X:
1 Follow the procedure for using Remote Install Mac OS X
To use Remote Install Mac OS X: 1. Insert the Mac OS X Install Disc 1 into the optical disc drive of the other computer. 2 .If the other computer is a Mac, open /Applications/Utilities/Remote Install Mac OS X. On Windows, choose "Remote Install Mac OS X" from the Install Assistant. 3. Read the introduction and click Continue. 4 .Choose the install disc you want to use, and click Continue. 5. Choose a network connection: AirPort, if you are using an AirPort network, or Ethernet, if the other computer is on an Ethernet network and you have an optional Apple USB Ethernet Adapter connecting your MacBook Air to the same network. Click Continue. 6 .Restart your MacBook Air and hold down the Option key as it starts up, until you see a list of available startup disks. 8. If you chose AirPort as your network in step 5, on your MacBook Air choose your AirPort network from the pop-up list. If the network is secure, you are prompted for a password. You can enter a private network name by choosing the ellipsis (...) and typing the name. 9. If you chose AirPort as your network in step 5, when you see the AirPort status icon indicating signal strength, click Continue in Remote Install Mac OS X.
10. Click Continue in Remote Install Mac OS X. 11. On your MacBook Air, choose Utilities > Reset Password from the menu bar and follow the onscreen instructions. When you finish, quit Mac OS X Installer. 12. On the other computer, click Quit to exit Remote Install Mac OS X.
I think it helps.Let Me know.
Dec 25, 2010 | Apple MacBook Air
Cant connect to internet on laptop
for wireless connection, make sure you turned on your wireless capability, set your wireless settings to dhcp and look for wireless signal
for LAN connection: make sure you know the ip settings of the network otherwise contact network administrator
Oct 19, 2009 | Computers & Internet
I inserted a blank disk into my mini mac. It did not come up on my desktop. I can't discharge it....How?
When you install Toast, one of the install questions is whether you want Toast to recognize blank CD's or DVD's when they are inserted. If this was set to yes, then I believe this could override the OS acknowledgement and Toast will take over.
One way to check is to open up Disk Utility (Applications > Utilities > Disk Utility) once you insert a blank disc, if you see the blank disc, try using Disk Utility to mount it, than it will should show on your desktop.
If you want the OS to mount the disc all the time, check your Toast settings.
Check both the preferences in Toast but also under System Prefs-->CDs and DVDs...there is an option there to choose what the computer should do when a blank DVD is inserted. Probably Toast set that System Pref to "Open Toast" based on your install configuration.
The Finder Pref you refer to only determines if CDs and DVDs recognized by the Finder show up on the Desktop. This is only a display preference, not really a determination of whether the Finder is the primary app that will recognize a blank disc. The CDs and DVDs panel in the System Preferences is where you need to go.
if that doesnt solve ur issue... i wud recommend u to reset ur pram and smc.....
Resetting PRAM and NVRAM
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
Resetting PMU on PowerBook or iBook computers In some troubleshooting situations, if resetting PRAM does not resolve an issue, resetting the PMU may be the next appropriate step. For information on when this is appropriate and for instructions on how to reset the PMU in your PowerBook computer, see Resetting PowerBook and iBook Power Management Unit (PMU).
Additional Information Resetting NVRAM in Open Firmware If your computer is Open Firmware-based (Power PC) and you are unable to reset NVRAM as described above, you may alternatively reset the NVRAM and Open Firmware settings using the steps in the Solution section of Message “To continue booting, type 'mac-boot' and press return”.
In some cases, an Open Firmware-based computer may not respond to the keyboard commands noted above, and may not allow starting up into Open Firmware by pressing and holding the Command, Option, O, and F keys during startup. If you are unable to get to an Open Firmware prompt (and your computer supports doing so), try powering on the computer with the power button held down continuously—as if you were doing a firmware update. This should force the computer into Open Firmware, allowing the steps in the article noted above to be used.
Contents of PRAM Some Macintosh computers may not have all the settings described below. For Mac OS X information, refer to Mac OS X: What's Stored in PRAM?
  • Status of AppleTalk
  • Serial Port Configuration and Port definition
  • Alarm clock setting
  • Application font
  • Serial printer location
  • Autokey rate
  • Autokey delay
  • Speaker volume
  • Attention (beep) sound
  • Double-click time
  • Caret blink time (insertion point rate)
  • Mouse scaling (mouse speed)
  • Startup disk
  • Menu blink count
  • Monitor depth
  • 32-bit addressing
  • Virtual memory
  • RAM disk
  • Disk cache
with respect to ur SMC...
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
Resetting the SMC is not intended for resolution of a stall or situation in which the computer is unresponsive. An SMC reset should not be necessary except as a last resort in cases where a hardware issue with the power management system is suspected. Performing an SMC reset resets the hardware power management functions.
For most situations, a restart is sufficient. If the computer has stopped responding, try each one of these steps, one by one. Test between each step to see if it has worked. If one step works, don't worry about the next one. You should only reset the SMC if you've tried all of the steps listed here and the computer still isn't working.
  1. Force Quit (Option-Command-Escape)
  2. Restart (Control-Command-Power)
  3. Force Shut Down (press the power button for 10 seconds)
Only perform an SMC reset on the computer if none of the above steps resolved the situation. If this is the case, see below for instructions on locating the reset button or key combination for your model of computer. If your computer is earlier than the models listed here, see "Resetting PowerBook and iBook Power Management Unit (PMU)" or "PowerBook: Resetting Power Management Unit (PMU)".
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
  1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
  2. Connect the power adapter to a working power source.
  3. On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
  4. Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
You should only perform an SMC reset when the MacBook Air or MacBook Pro (17-inch, Early 2009) has been properly shutdown. This prevents issues from occurring to the file system.
While the power adapter does not need to be connected to reset the SMC, it may be necessary in situations where the battery needs charging or if the computer has been without power for an extended period of time. You can also visually check the SMC reset by observing the LED on the adapter. It will momentarily turn off as the SMC resets.
Jul 16, 2009 | Computers & Internet
Don't have password to access computer.
The easiest way is to use the startup disc that came with the computer. Start from it and choose the language. The next screen should have a menu bar. Under (tools or utilitys) you will find a little program called password reset. Change the password, reboot the computer log in as the user with the password you created and make a new account for yourself with administrator privileges. Log into your new account and delete the previous user.
May 16, 2009 | Apple MacBook PC Notebook
Macbook
Go to system preferences, select Accounts. Whoever set up the Mac should be listed as the administrator, so click on administrator name. This will bring up the password change icon. Click on it and change your password. (You might want to check out those Parental Controls, too. :)
Jun 18, 2008 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Apple MacBook Pro Notebook Logo
161 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
