Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Door for Hotpoint WD440 not opening, latch is stuck. Have opened machine from the top and can not find a way to release the latch.
    Brigadier General:
  • 6,277 Answers
Is it 'stuck' or is the washer keeping it locked are the questions!
It is worth trying the following JUST in case.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 25, 2011
Why is the Washing machine door does not open?
The door latch is normally locked by a relay whilst the washing machine is operating to avoid accidental door opening and flooding. Once the wash is complete a timer operates and releases the door latch relay to allow door opening. The relay must have stuck. Try to turn off the mains power supply to washer and if you hear a click then relay has released and the door should open. But if no difference then the relay or latch is jammed and you will have to use a mild force with a blunt screw driver to force open the door. If this is hard then take the washing machine cover top cover out and access the switch from side. Make sure the mains power cable is taken out.
Aug 02, 2014 | Washing Machines
HELP! Very urgent! I have a Hotpoint Aquarius WD440 washer/dryer and the door handle has broken off. My clothes are stuck inside and I need them by tonight. How do I get the latch to open. I know I need to...
Slide a thin knife from 3 o clock door position against the frame to push the locking latch pin towards your left, only about a centimeter and the door would then release
Dec 21, 2012 | Washing Machines
My washer door will not open its a wd645 model i cant find the lever when i took lid off
Hi.
The door latch is probably broken. Emergency opening can be done accessing the door latch from the inside of the washer assembly.
Before attempting an emergency opening, disconnect power cord and empty water inside the machine through the filter located at the bottom front side of the machine.
After removing water connect back the machine and try opening again.
If that does not work, then the machine must be disassembled. Most models have an emergency cable located on the inside of the door latch. Pulling the cable will release the latch.
The inside of the door latch is reached either from filter housing or from top of the machine. Either the filter (usually held by screws) or the top panel must be removed to access the inside of the lock mechanism.
Power must be kept off while doing maintenance. Due to the safety issues involved the door latch emergency opening and repair must be done by a trained technician.
Regards.
Ginko
Dec 15, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
The handle is broken on hotpoint bwd12, how do you open the door?
The door can be opened by pushing a piece of plastic such as an old credit card, or cut down lenonade bottle into the door recess releasing the latch. Or thread a peice of string around the door rim and give a strong pull to release latch.
hope this helps. GARY
Dec 21, 2010 | Hotpoint Washing Machines
Door on WD420 will not open
There is an electrically controlled lock on the door that prevents opening while the machine is in operation, and sometimes for a short period after a cycle has finished.
Sometimes this lock can get stuck and requires some persuasion to release.
This may sound odd but try it:
Make a fist with your hand and bang the door, near the latch, with the side of your fist. Do this firmly, but obviously not so hard that you will damage the door or, more importantly, your hand. This can often release the latch that should have released automatically.
Apr 07, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint electronic 800 delux 9525. can not open the door help
Make sure there is no water left inside washer.
If it still will not open, then you need to remove the top cover, and release the door manually from inside at the front where the door latches in.
Can be caused by the belt being off the pulley,or a broken ****** assy.
Jan 12, 2010 | Hotpoint Washing Machines
How do i open the door on hotpoint WD440, latch is broken?
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
I cant open the door
The door lock solenoid may be stuck. If the unit has a load in it, it could have a piece of clothing stuck in the door latch or too full of a load applying pressure on the door. Try to push the door inward with slight pressure and then pull out. If that does not work try unplugging the unit and then opening the door. The only other option is to remove the panels and manually release the door catch.
Sep 10, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door Won't Open
This is joyce
Have you tried to go to ge.com and download your documenton. your book. put in your model # and this will give you some info on why the door wont open. their is a reason.
let me know if you need any help, if you cant find out why, let me know and I will research it a little more and see if I can get you some help, but you may have to call a technician out to fix problem.
thanks
joyce
Feb 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Jul 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
499 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
