Question about Freestyle Tracer Pedometer
How do I set my freestyle with my stride - Freestyle Tracer Pedometer
I walk a lot so have bought a Tanita pedometer PD-724.Cannot seem to set stride length Help, Iam 78
That's okay Dorothy ...
I won't hold your youth & in-experience against you.
(Walk a lot: Good girl!)
Tried (really) looking it up... (below) 3 axes pedometer
http://www.tanita.com/es/pd724gl/
Seems 2 B a serious brain teaser. .. but if you have the numbers... weight and stride length.. you just advance to those settings with your mode control.
The only ISSUE I can imagine: you could have your stride length... in CENTIMETERS (METRIC)... So if your stride is
30 inches... that equals 76.2 CM (centimeters).
Aaaand...
if you underestimate your stride a little... It will make you feel like you accomplished more... (and who's to tell).
You go girl...
Comment me back if that didn't do it for you.
If you need to Phone them (Tanita) ...
Tanita Corporation of America, Inc.
Customer Service / Service Center
2625 South Clearbrook Drive
Arlington Heights, Illinois 60005, USA
Phone: (847) 640-9241
Fax: (847) 640-7978
eMail: 4health@tanita.com
http://www.tanita.com/en/contact-customer-service/ Contact Customer Service
Personal Scales Manual Downloads
Jan 24, 2016 | Tanita Exercise & Fitness
How do I adjust the stride length down?
suggest reading the setup manual again. having never seen one do not know what you might have done .
Jun 17, 2015 | Exercise & Fitness
How many miles are in 5101 steps
That depends on the length of your stride. If you have a very short stride (less than 12 inches), it'll be less than one mile. If you have a very long stride (36 inches or more), it'll be more than three miles.
Jul 29, 2014 | Exercise & Fitness
How does a person convert the steps to miles? How many in a mile?
Thats pretty hard to do since each persons stride is different. If you know your stride length then you can just multiply the length of your stride by the number of strides. S x N.
Oct 18, 2013 | Exercise & Fitness
Can't input stride length
My husband figured it out! Follow the instructions for setting time and _user information_, toggle the "set" button until you get to stride length (I think it's factory default setting is 33 inches). All the parameters listed at the end of this section are set this way.
May 20, 2012 | New Balance Balance Via Active Pedometer
What is the formula to figure out the pace
(I got this from http://www.livestrong.com/article/93695-set-up-omron-pedometer/)
Step 1
Pace out an area that's long enough for you to take 10 normal steps, in your natural stride, without having to turn to one side or the other. Place a piece of tape at one end of this distance, then stand with your toes flush with the edge of the tape.
Step 2
Carry another piece of tape with you as you walk straight ahead, taking 10 steps (5 with your left foot, 5 with the right). Stop at the end of the tenth step and place the tape flush with the toes of your leading foot.
Step 3
Measure the distance from one piece of tape to the other, in inches, with a measuring tape. Divide this distance by 10 to get your average stride length. If, for example, you walked 290 inches in 10 strides, your average stride length will be 290 / 10 = 29 inches.
Read more: http://www.livestrong.com/article/93695-set-up-omron-pedometer/#ixzz1uuGDz1tt
Nov 13, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
How do i set the stride for the sportline 2007 model 4202
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
Sep 20, 2010 | Accufitness SportLine Electronic Pedometer...
Pedometer # 4202
The Sportline 4202 has three buttons, Top MODE, Right S/R (RESUME/STOP), Left SET.
MODE - press once to alternate between Steps (how many steps you taken) and Miles (how many miles walked).
S/R - Clears the count to 0 for any mode by pressing one second. To change from Kilometers to Miles or Back Press S/R for 6 seconds.
R/S press one sec and then press SET one second to set "goals" for both steps and miles.
To change length of stride: press the buttons one at a time in the following order- R/S-SET-MODE.
It may take several attempt to get into the set stride and it may take you into other menus such as Goals in the process, just keep going in circles until you get to stride and change length with R/S and set with SET.
Feb 22, 2009 | Sportline 345 Electronic Pedometer
Freestyle Tracer Pedometer Logo
52 people viewed this question
Top Freestyle Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Freestyle Exercise and Fitnes Expert? Answer questions, earn points and help others
