Question about AudioBahn A1504DP Car Audio Amplifier
I have a 60 amp fuse under the hood.. and two 30 amp fuses on the amp. when i turn the power on the blue led light come on and then both 30 amp fuses blow.. all my wireing should be set correctly sence bestbuy ran the wires and hooked it up to an alpine 500watt max 250 rms amp and it works like a pro..but when i switch amps the Audiobahn A1504DP 4 channel 1800 watt amp blows its own fuses..its weird?.. i was thinking about taking it to a shop to get checked?..
    Scholar:
  • 146 Answers
Either you attached power wires wrong when you hooked up amp or you have bad amp
Posted on Mar 25, 2011
2000 JIMMY 4.3 WONT START AND KEEP BLOWING MAIN 40AMP FUSESE
What all does that fused supply B+ voltage too ? Do you know ? That would be your first thing to find out ! Do you know what a electrical distribution diagram is ? Do you know how to test electrical circuits with a DVOM - digital volt ohm meter ? Do you know what a short to ground is ?
Which fuse ? IGN A - 40 amp ,under hood fuse / relay box ? This fuse powers the Starter Relay and Ignition and Start Switch
Does your vehicle have a manual or automatic transmission ? The starter relay could be shorted inside , It's also located in the under hood fuse box . If you pull the relay out of the box it's plugged into an look on the bottom of it you would see four sets of numbers ! 30 & 87 an 85 & 86 . If you were to jump 30 to 87 in the relay box the starter should spin the engine over , not start an run just spin ! 85 & 86 is the control side . Could be the ignition switch !
That 40amp fuse powers a lot of subsystems !
Here is a web site for free diagrams !
http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine , Under system click on electrical distribution , under sub system click on power distribution . Then click the search button .Click blue links one at a time . First blue link scroll down to the second diagram . You will see Ign A 40 amp fuse at the top of the page .you will also see it powers the igintion switch ,look at last part of ignition switch , when in start or run that 40 amp fuse powers all those other fuse's plus three relays i see there also . A/C compressor relay , rear window defroster relay ,daytime running lights . Any one of those circuits could have your short . You need to isolate the circuits , pull fuse's till the fuse doesn't blow !
May 27, 2017 | Cars & Trucks
Fuse location for 2000 nissan maxima marker lights
Before you get started, please review this article: Where's The Fuse?
Keeping the information in the article above in mind, the fuse that supplies power to the marker lights is located in the engine compartment fuse block It is fuse# 60. it is a 10 Amp fuse. This fuse supplies power to the Tail Lamp Relay which is located in relay box #1. This relay is controlled by the Auto Light Control Unit, which in turn, is controlled by the main lighting switch.
The Auto Light Control Unit gets its power from fuse #30 (10 Amp) which is located in the Instrument panel fuse block under the left side of the dash.
Mar 26, 2011 | 2000 Nissan Maxima
02 altima wiring for all three harnesses
12V'green '+ 'ignition harness '
' STARTER'black/red '+ 'ignition harness '
' SECOND STARTER'black/yellow '+ 'ignition harness '
' IGNITION'black/red '+ 'ignition harness '
' ACCESSORY'red '+ 'ignition harness '
' SECOND ACCESSORY'white/blue '+ 'ignition harness '
' POWER LOCK'pink *7 '- 'pin 37 @ BCM by fuse box '
' POWER UNLOCK'brown *7 '- 'pin 44 @ BCM by fuse box '
' LOCK MOTOR'yellow/red ' 'pin 30 @ BCM by fuse box '
' UNLOCK MOTOR'green/white ' 'pin 23 @ BCM by fuse box '
' DISARM DEFEAT'green/red ' 'pin 31 @ BCM by fuse box '
' PARKING LIGHTS +'red/blue ' 'driver kick panel '
' HEADLIGHTS'blu (L), red/yel (R)'+ 'IPDM E/R *1 '
' DOOR TRIGGER'*2 '- 'BCM to right of fuse box '
' DOME SUPERVISION'comes on with unlock' ' '
' TRUNK/HATCH PIN'purple/white '- 'pin 18 @ BCM by fuse box '
' HOOD PIN'yellow/black '- 'hood pin switch '
'TRNK/HTCH RELEASE'red/blk or blu/red '- 'pin 76 @ BCM by fuse box '
' FCTRY ALARM ARM'pink/blue *3 '- 'driver switch in door '
'FCTRY ALRM DISARM'white/blue *3 '- 'driver switch in door '
' TACHOMETER'white/green ' 'ECM behind glove box *4 '
' SPEED SENSE'blue/yellow *5 '8 'pin 9 @ instrument cluster '
' BRAKE WIRE'red/green '+ 'brake pedal switch '
' HORN TRIGGER'green/white '- 'steering column '
' WIPERS'blu (L), blu/blk (H)'- 'wiper motor '
' LF WINDOW UP/DN'blu/red - blu/wht 'A 'driver window switch '
' RF WINDOW UP/DN'green - yellow *6 'A 'driver kick panel '
' LR WINDOW UP/DN'purple - blue 'A 'driver kick panel '
' RR WINDOW UP/DN'red/yel - yel/blk 'A 'driver kick panel '
' SUN RF OPN/CLOSE'not recommended ' ' '
' RADIO 12V'yellow/green '+ 'radio '
' RADIO GROUND' ' ' '
' RADIO SWITCH'purple '+ 'radio '
' RADIO ILLUMINATE'red/blue '+ 'radio '
' POWER ANTENNA'green '+ 'radio '
' LF SPEAKER'blu/wht - blu/red ' 'radio or amp under rear deck'
' RF SPEAKER'wht/blk - blu/blk ' 'radio or amp under rear deck'
' LR SPEAKER'grn/yel - blk/yel ' 'radio or amp under rear deck'
' RR SPEAKER'blue - red ' 'radio or amp under rear deck'
here is a wire diagram for the altima .you should be able to just buy a radio harness to attach to the factory harness with diagram of wires on back and find out what color are what on your factory wires
623.10482.150x100.nn03b.jpg 02 harness for your car from scosche
http://www.tintingbyfredjohnson.com
Dec 31, 2010 | Car Audio & Video
I have shorted out the electrical system in a 1998 mercury mystique. I still have somethings like the horn, headlights and dashlights but not the power locks, windows, brake lights, signal lights etc. \it...
Check all of the fuses located in the black box under the hood close to the battery on top of the inner fender. All power to the car begins there. Check for large fuses 30 amp to 60 amp. Make sure the heater fan is left unplugged. When working on components under the dash always disconnect the ground cable from the battery
Jun 14, 2017 | 1998 Mercury Mystique
Right power outlet not working
Hello. there are two fuses for the power outlets. check them both to make sure they are good. here is the fuses you need to check. both of these fuses are located in the fuse block under the hood.
CIGAR FUSE numbered 30 it is a blue 15 amp fuse.
the other fuse is AUX PWR numbered 29 it is a yellow 20 amp fuse
Sep 22, 2010 | 2004 Chevrolet Express
Brake lights not working even though the brake peddle is pushed down The switch still goes in and out. Fuse box has some fuses missing. The fuse box does not have a desription on every plug of what it is...
Here are the numbers on your fuseblock and fuses coresponding to the number that is on your fuse block.
1-20 amp (yellow)
Hazard flasher
2-10 amp (red)
back up lights, A/C clutch cycling Switch
3-30 amp (green)
Power windows
4-30 amp (yellow)
A/C or heater blower motor
5-20 amp (yellow)
Panel Lights, Side marker lights, Park, Taillights, Clock & radio display Intensity, License & panel lights.
#6-10 amp (red)
Stoplight, buzzers, Anti-lock brake module
#7-15 amp (lt. Blue)
Tachometer, horn & Relay
#8-8 amp (yellow)
Power Door locks
#9-10 amp (red)
Radio
#10-10 amp (red)
Rear Wheel Anti-lock module, Turn Signals
#11-20 amp (Yellow)
Windshield wiper & washers
#12-15 amp ( LT. Blue)
Cigarette Lighter
#13-5 amp (tan)
Speed Control, warning buzzers, gauges, indicator lights
#14-5 amp (tan)
Time/delay relay & under-hood light, dome light, power mirrors, readio & clock Memory, Interior lights, reading lights
#15-blank
Not used
#16-4 amp (pink)
Radio Lights & overdrive switch light 1989-91, Cluster lights, Cigarette Lighter light & as tray light, Cluster lights, A/C & heater controls.
#17-relay
Hazard Flasher warning
#18-relay
Relay
#19-Circuit breaker
#20-relay
Turn signal Flasher
#21-buzzer
Warning
#22-Relay
Horn
Aug 04, 2009 | 1991 Dodge Dakota
Cooling fans wont come on with out the a/c
First check all your fuses in both the under hood (60 amp) and right rear (10 amp) fuse blocks. Remove the low speed fan relay (in the under hood fuse box) and install a jumper across terminals #30 & #87. These are not marked on the box, but you will find these numbers identifying these terminals. With power at the #30 terminal, installing the jumper wire will send power directly to the primary fan. The fan should now run, if it doesn't, check it's ground wire, if that's OK, replace the fan.
Charlie
Jun 15, 2009 | 1997 Oldsmobile Aurora
Blew a fuse for my power windows looked in both boxes under dash and under hood looked in manual does not show a number or location
on my 1997 explorer the power window and door lock fuse is under the hood. fuse box driver side, passenger side of fuse box, 5th or 6th from front of vehicle. I now use fuses with LED in them so when they go out they light up bright red. easy to see even in full sunlight. cost about 3 dollars more but worth it. 30 Amp fuse.
May 05, 2009 | 1997 Ford Explorer AWD
Tail light are not working
fuses under hood
POWER DISTRIBUTION BOX Location Name Amp Circuits Protected A Trailer Tow 50 Fuse 32/Fuse 26/Electric Brake B Fan (Hi) 60 Cooling Fan (CCRM) C Start 60 Starter Solenoid/Fuse 30/Fuse 36/Fuse 2 D Ignition 60 Fuse 6/Fuse 12/
Fuse 8/Fuse 18/Fuse 14/
Fuse 24/Fuse 20/Fuse 21/Fuse 27/Fuse 33 E Rear
Blower/
RAS 60 Rear Heater Blower Motor
Rear Air Suspension F Seat 60 Power Seats G — — Not Used H Fan-Lo 40 Engine Cooling Fans J Power Accessory 60 Fuse 13/Fuse 25/
Fuse 1/Fuse 31/Fuse 37/
Fuse 40/Fuse 7/Fuse 19 K Light 60 Headlamps/Fuse 10/
Fuse 11/Fuse 3/Fuse 9/
Fuse 23/Fuse 29/Fuse 35/Fuse 41/Fuse 17 L ABS 60 ABS Control/Pump Motor Module M Heated
Backlight 60 Heated Backlite/Fuse 16/Fuse 28/Fuse 22 N Fuel 20 PCM/Fuel Pump/CCRM P — — Not Used R PCM 15 PCM Memory S PCM 30 AX4S/Cylinder Identification Sensor/EDIS Module/PCM Power/EGR Control/HEGO's/IAC/
Injectors/MAFS/VMV T Alt./Reg. 15 Generator U Air Bag 10 Air Bag (Dedicated) V Trans. Light 10 Transmission Indicator Light W Fan 10 PCM Fan Monitor X Diode — Hood Lamp Diode Y Relay — RH Trailer Turn/Stop/Hazard Lamps Z Relay — Powertrain Control Module AA Relay — Windshield Wiper Speed BB Relay — LH Trailer Turn/Stop/Hazard Lamps CC Relay — Windshield Washer Pump Motor DD Relay — Windshield Wiper Dynamic Brake/Run
The fuses are color-coded by amp rating.
Fuse Value Amps Color Code 4 Pink 5 Tan 7.5 Brown 10 Red 15 Light Blue 20 Yellow 25 Natural 30 Light Green 40 Orange 50 Red 60 Blue
Mar 14, 2009 | 1997 Ford Windstar
AudioBahn A1504DP Car Audio Amplifier Logo
136 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
