Question about Honda Garden
Accidently tipped machine and it cut out. cannot restart. when i take the spark plug out and pull cord oil comes out of port. will it clear itself?
  • 885 Answers
Yes you can clear it out. The best thing to do is:
1 - remove the spark plug
2 - put a little gas in the plug hole (about a tablespoonful or so)
3 - pull the cord slowly so the gas can mix with the oil and thin it out
4 - pull the cord fast several times to blow everything out the spark plug hole
5 - dry and reinstall the spark plug
6 - try to start the motor without any choke
7 - if it won't start go to 1 and repeat
When it does start it will probably run rough for a while and smoke a lot until it gets everything cleared out of the cylinder. After a minute or two it should run like it did before the incident. Be sure to check the oil level, you probably didn't lose much but better safe than replacing the motor.
Posted on Mar 25, 2011
Looks like oil and fuel is leaking or blowing from exhaust.
John - Husqvarna makes really good power equipment that seldom offers trouble. The unit you are talking about is a 2 cycle system, meaning you mix oil and gas together in lieu of having an oil sump at the bottom of the engine like 4 cycle motors have. First question, did you mix a bottle of One Mix 2 cycle oil to a gallon of regular gas to start off using your machine? If you did, then I would think your unit is badly flooded, which happens a lot with 2 cycle equipment. Try taking out the spark plug and see if the spark plug looks wet from too much fuel. If it is, leave the spark plug out for a day or so to allow the cylinder head to vent the gas fumes. Replace the wet spark plug with a new one and try to start the unit again. Here's a tip: If you do flood a 2 cycle piece of equipment (trimmer, chainsaw, blower, etc.) again, make sure the choke is off and hold the throttle trigger wide open. Pull the started cord several times until the unit starts to run. Keep holding the throttle wide open until it clears itself out. Remember, you run the equipment, it does not run you :-)
Aug 01, 2016 | Husqvarna 223L 24.5cc 2-Cycle Straight...
This is an update on my lawnmower. Following various instructions. It looks as if the engine has seized.
I'm not sure I understand, but if you put oil in the cylinder and reinstalled the spark plug with it still in there...That's why your engine acts like it's frozen up. If that's the case, remove the spark plug and pull the start rope until the oil stops coming out when you pull it. You might want to even spray some carb cleaner in the spark plug hole, let it set for a couple of minutes and pull the rope until nothing comes out the spark plug hole.
Also, with the plug removed, tip the mower and see if you an turn the blade. If you can, the engine is not frozen. You may need to clean the oil off the spark plug as well.
Good luck! I hope I helped some,
Bill
Apr 03, 2015 | Gcv160 Gas Engine
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
Suddenly cut out whilst mowing the lawn. now wont start, pull cord stiff to pull
Something just like this happened earlier this year with my pressure washer. This is what I did to fix it and now it runs great. Check the oil. If it's black or feels the least bit tacky, drain a pint or two of the oil out and re-add that amount of Marvel Mystery Oil. Now, attempt to pull the cord all the way out, but slowly at first. It should get easier to pull after about 5 pulls. If the mower restarts, let it run for 10 minutes until the Mystery Oil is hot and has cycled around inside the engine. Then drain that oil and refill it with a quality brand of oil. To top it off, either clean or replace the air filter, and put a shotglass of Lucas gas & injector cleaner into the mower's full gas tank. I also do this to my lawnmower and weedeater. It works wonders. BTW...If you're unable to turn the engine over by pulling the cord, remove the spark plug and tilt the mower up, so you can turn the blade easily by hand (use gloves). BUT FIRST MAKE SURE THAT SPARK PLUG IS REMOVED. REMEMBER... SAFETY FIRST! Let us know if this helped you any.
Jun 29, 2014 | Garden
I cant pull the cord, everything seems to be frozen
It is possible the motor is seized or the pump component has jammed. The Honda Motor usually has an oil minder(wont start if low oil). So that being the case you may have a problem with the pump. If you are handy and have internet it is possible to download a parts/repair manual for the type of pump involved. Otherwise take it to a repair shop. Sometimes these pressure washers are more costly to fix as compared to a new one..
Nov 06, 2011 | Honda Maxus Prosumer MX5223 Pressure...
Hi, after deposited it for the winter, the cord
I have thought about this problem for a while now. It came to me that what you are experiencing is the aftermath of the WAY you my have stored your machine. If you stored it on it's side or on it's end ,this may have allowed the engine oil to leak into the cylinder . This causes the piston to be blocked by the engine oil.
First to see if this is so, remove your spark plug, if oil starts coming out tip the machine to allow the oil to get out of the engine. You can probably clean the spark plug with carburator cleaner, or just replace with a new one. Replace plug, fresh gas, and start. Your mower will smoke for a while ,but will then start to run clear. I hope your problem will be solved. GOOD LUCK.
May 13, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
How do you start it? My cord will not pull it seems locked?
Check the oil level and condition in the crank case. If it's way overfull or diluted with gas, the crank case is tool full to let the piston come down. Change the oil and check to see if the float and/or needle valve in the carburator are stuck. Next; Pull the spark plug wire off the plug, remove the plug and tip the machine up. Using gloves or wrap something like a towel around the sharp part of the blade, try to pull the blade around in both directions. If it won't budge at all you have somethnig locked up inside the motor. If it moves aim the spark plug hole in a safe direction and pull it over with the rope. If oil or gas shoots out of the hole it was keeping the piston from going up. Keep pulling it over to get as much out of the cylinder as you can. Reinstall the spark plug and try to restart it. It may be hard to start and will smoke a lot until it burns everything out of the cylinder. If the cylinder was full of gas again check the float/needle valve in the carburator to see if they're stuck.
Oct 04, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Ryobi 2 cycle 31 cc E-Z Pull Gas Trimmer (18 inch cut; straight handle) will not start. Have checked fuel lines and replaced Spark Plug with correct size. Gas and oil mixture is correct with fresh, clean...
The "grinding-type" noise is disturbing. This could indicate that a piston ring has broken loose and is scoring the cylinder wall and would likely be a significant or terminal problem. I will assume this is NOT your situation. Well done on your description. Follow this:
1. Best to determine if you have spark to the spark plug by removing the spark plug, plug it into the plug line and ground it the best you can to a metal surface on the engine. Pull sharply in a dim light and insure you have a spark. [If yes: Go on / if no: replace the spark plug and retry. If yes, replace spark plug and retry your efforts. If no, your machine will need a professional, on-site review).
2. Carburetor repair kits are inexpensive and are DIY for many. Diaphragms over time become in-flexible with modern fuels that were not well drained from the machine out of season and may not be pulling the fuel into the carburetor and into the machine. This may be your case.
3. Exhaust or mufflers can become clogged with carbon buildups at the screen or within the muffler itself when running lower quality 2-stroke oils or too low of a ratio to fuel. You can often pick-clear the muffler or replace it.
These are the most common issues encountered...other than, switching the machine to the ON position - good luck!
2. I
Sep 25, 2010 | Ryobi Garden
4 stroke mower tipped onto side and now will not start
Start with the basic
Fuel, try starter fluid, see if it kicks
Fire, arc the spark plug while pulling the cord, 50/50 you get the zap.
Compresson, put you finger over the spark plug hole, pull the cord.
After you have tried these, come back and give me the model as well, some units are famous for certian problems.
I am betting fuel.
Mar 12, 2010 | 2006 Eagle Talon
Garden Logo
337 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
