Question about Car Audio & Video
I'm getting the ignition switch fixed soon. The mechanic showed me how to take a screwdriver near the starter and touch it to something to start it. I would like to see a picture so I do it right. I know to turn the key to start first.
    Scholar:
  • 146 Answers
Dont have a picture but you "short" the small wire to the big wire and that will make the starter spin
be very careful it is dangerous to do this and probably should not be tried
there are only 2 wires on starter so you should be able to figure it out - if not you probably are better off not trying and hurting yourself
good luck and BE CAREFUL!!!!!!!
Posted on Mar 25, 2011
Dodge 440 no crank no start
Check the ignition switch wire . from the ignition switch to the starter. Try jumping the starter. The lead that the battery cable hooks to and the lead the ignition wire hooks to. use a screwdriver and touch both.
Aug 26, 2016 | Dodge Cars & Trucks
Wires on starter but wont start will start with screwdriver whats wrong
The solenoid on a starter receives voltage when you turn your ignition switch to the start position that tells it to activate the starter. When you use the screwdriver to start the car, you are basically bypassing the solenoid on the starter. Since the car won't start when you turn the key, this means that either the solenoid is bad and the starter needs to be replaced, or the solenoid is not getting the voltage from your ignition switch that tells it to engage the starter. You might be able to eliminate the ignition switch as the problem if you get somebody to hold the key in the start position while you check to see if there is voltage at the starter solenoid. If you have voltage there, the starter solenoid is most likely bad, and the starter needs to be replaced.
Sep 26, 2014 | Cars & Trucks
Why my 2005 saab 9-3 Turbo won't start?
Check that you're getting charging current to battery. Voltage at battery terminals should read about 14.5 volts (well above 12 volts in any case). If not, a bad alternator may be failing to provide your battery with a full charge. If charging is good, and battery holds its charge, other possibilities are bad wiring connections to starter solenoid and/or starter motor, or bad ignition switch assembly.
Jul 29, 2014 | NRS S129 - Starter Solenoid Switch, D984
Ford f100 starter diagram
You have starter relay on fender lining. A large post on either side of relay? You can take two long shank screwdrivers, touch each post, then touch the shanks. The starter motor should crank. If you try that make sure tranny is in park or neutral and parking brake is set. Battery has a full charge and battery connections all good? Starter motor is good? Engine isn't seized?
I couldn't get everything in one picture, there is the ignition switch and neutral or clutch switch depending on the tranny and wiring circuits.
Dec 25, 2017 | Cars & Trucks
Sorry my bmw 1991 3181 had a problem with the starter..how can i fix it.....when start to run it didin't work so i had to use a screwdriver to initiate the starter by make it touch the starter then the...
Locate the starter wires coming from your ignition key switch. Short these out and see if the starter turns. If it does, you need a new key switch, or you can connect a press button to those two wires and by-pass the key for starting. I assume you used the screw driver across the big terminal on the starter and the terminal on the solenoid, or else the bendix would not have kicked in. If you shorted the two big terminals on the starter and the bendix did for some reason kick in, you should have a look at the solenoid first before looking at the starter switch.
Mar 26, 2011 | 1991 BMW M3
Put new starter in,all electric works but car won't start
Does the car crank with the new starter? If it does, then it might be fuel system or ignition system problem. Take one spark plug wire off, put a screwdriver in the wire and rest it near a metal object on the engine. Have someone crank the car while you watch for a spark jumping from the screwdriver to the engine. If so, then the problem is fuel related. Don't touch or hold the screwdriver while cranking, it will be shocking. Some ignition systems can stop your heart.
Dec 19, 2010 | Pontiac Sunfire Cars & Trucks
Starter Issues/Manual Bypass
I would look into the ign. switch. The ign.switch sends the signal to the solenoid to activate it.
Nov 11, 2009 | 1995 Toyota Camry
89 toyota celica st not starting but clicking
There is either a cable not getting a very good connection, solenoid has problems, or there is a wiring leading to a relay that has a bad connections. How is your ignition? Is it loose or have loose wires?
also check the magnetic switch mounted on the starter housing, is supplied by current from the starting switch circuit of the ignition switch. This magnetic action of the switch mechanically engages the starter clutch assembly and electrically closes the heavy switch which connects it to the battery. The starting switch circuit consists of the starting switch contained within the ignition switch, a transmission neutral safety switch or clutch pedal switch, and the wiring necessary to connect these in series with the starter solenoid or relay.
Jan 29, 2009 | 1989 Toyota Camry
As soon as I turn the key to the on position, the engine turns over
The problem is either in the mechanism that pushes the rod that activates the ignition switch from the key lock cylinder, or the ignition switch is defective.
Sep 29, 2008 | 1988 Jeep Cherokee
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
