Question about Siemens Washing Machines
HOW TO RUN THE MACHINE - Siemens Washing Machines
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France, You have forgotten to tell us the model!
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Posted on Mar 25, 2011
How do I start the machine when set on auto
every sewing machine has to have a foot control, your AUTO is for other function, not for "run"
Oct 27, 2015 | Janome Memory Craft 9000 Computerized...
Hot water will not run into top loading machine.
Is this a new install? Has it worked before and now it doesn't? Did you let it run long enough to confirm that there was ample opportunity for the hot water from your heater to make its way into the machine? If you turn off the hot tap and the only solenoid that is opening is the cold, then there is a problem with the machine.
Dec 27, 2014 | Washing Machines
Motor continues to run after machine has been switched off
If it keeps running after you unplug it, you have somehow gotten your hands on a perpetual motion machine. Use it to run a generator and sell electricity to your neighbors!
Seriously, I think you meant "after you turn it off at the washing machine control panel." You probably have a shorted motor contact in the timer (contacts welded together).
Oct 23, 2011 | Washing Machines
How to decalcify and ventilate the machine
Use diluted CLR to remove calcium, and then fill the water reservoir with vinegar, let this sit for a couple hours and then run the machine. Immediately run it again with water. Let it sit and dry for a couple hours and run water through it a final time before making coffee.
Mar 06, 2011 | Saeco Vienna Digital Coffee Maker,...
Descaling cycle will not run
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Jun 12, 2010 | Gaggia Titanium Espresso Machine
Water does not run into the machine
Check the strainer attached to the machine inlet. May be it is clogged. Try loading water 10 liters to the front chamber manually and run the m/c. If any air locking in the water pump this will ease out.
Apr 16, 2010 | Bosch 24 in. SGS09L12 Logixx Free-standing...
Francis francis X1 the water supply seems to be lacking pressure
I would go ahead and run a solution of 50% distilled white vinegar and 50% water through the machine. If the machine still runs slow after that, pour another 50/50 vinegar/water solution into there - let it run just enough so that the vinegar water starts to drip out, then cut the machine off. Let the vinegar/water sit in the machine for about 20 minutes. Then cut the machine on and let the rest of the solution run through. Then run plain water through the machine to clear out the vinegar. Try brewing a batch and see if the machine behaves normally.
If the above fails to resolve the issue, the FrancisFrancis machines are now owned by illy, so would need to contact them for further TS.
-Tha Mp3 Doctor
Mar 08, 2009 | FrancisFrancis! X1 Espresso Machine
Washing Machines Logo
172 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
