Question about HP ScanJet 5370C Flatbed Scanner
What does it mean when you try to scan and it says "your scanner is not initialized? The light also does not work.
  • HP Master
  • 1,381 Answers
Hello jeible
This is typicall for a drivers issue . Verify your connections first .
You need to install the latest and up to date driver . Delete the current one , DISCONNECT your device , download and install the driver from here :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=60665&
Reconnect your scanner .
NOTE : HP DOES NOT SUPPORT THIS DEVICE BEYOND WIN XP ! This means , if you are using Windows 7 , your device will not work , it's useless trying .
If you don't want to purchase a new device , here is a workaround :
solution one:
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
solution two :
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.
Back up your data first.
solution three:
I have Win 7 on my primary and installed Win XP on my secundary . Works like a charm .
Have a nice day ,
Best regards,
fanaudi .
Posted on Mar 29, 2011
Scanner error 14
the problem with scanner assembly
Mar 20, 2013 | HP LaserJet M1120 MFP All-In-One Printer
Scan says all channels locked out
Please try this,
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Hope that helps!!
Happy Scanning
Nov 22, 2012 | Radio Shack Pro-97 Handheld Scanner
Hey I'm using a HP LASERJET M1120 MFP. But every time I turn on the machine the screen says "Scanner Error 6". How to fix it up? Thanks!
This means that the scanner sensor is facing some issue so that it is not able to initialize the scanner sensor.
Is you scanner working fine?or you are facing any issue while scanning documents?
Sep 10, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Hello, I am attempting to scan an important document and the printer keeps saying "set the document on the platen glass" the document is there but it keeps saying the message
The best way to scan images to save on yourcomputer is to use the scanner software on the computer. Not the scan functionon the scanner.
You don't say what type of scanner software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned
May 01, 2011 | Canon Pixma MP480 All-In-One InkJet...
Moved my M20i 20 feet now it won't copy or scan. Have done the Lock/Unlock of scanner. Worked before I moved it, but not now. Have upgraded the firmware and reset everything.
If you're using the PC to initialize the operation you want to do, and the USB cable is longer than 15 feet, then you will need to reduce the distance between the PC and the printer and use a shorter cable. USB cables should not be longer than 15 feet. Anything longer adds to data corruption and the printer refuses to work.
If you're using the on-printer dashboard to do the scanning/copying then it may happen that some wires came loose. See if the printer can print from the PC, to verify that the printing mechanism is OK. Then, turn off and back on the device and see if the scanner lights up and does the initial alignment. This should make some noise and move the scan head back and forward an inch or so (depending on the model). If the initialization of the scanner works that will mean there are no loose wires.
If the scanner does not go through the initialization procedure then probably some wires got loose inside and you'll need to open it and check the connections. If the scanner does initialize then you should run a self-diagnostic procedure from the printer dashboard. This should be a menu selection (usually in the Troubleshooting section). Check your users manual for the self-diagnostic procedure and how to run it.
Also, you may try to remove the toner/printing assembly and re insert it, just to jumpstart the diagnostic procedure that may then fix the problem by itself without throwing out any messages on the built in LCD.
Jan 13, 2011 | Xerox WorkCentre M20i All-In-One Laser...
Hi, I need your help with this problem: the Canon MP210 ran out of color ink. I have removed both the cartridge. Anyway, the problem is not in the E5 error. The problem is, that the scanner does not work,...
The scanner and the printer are connected together.Both need initialized for printing or scanning.You can't scan if you haven't cartridges in printer and you can't print if the scanner not initialized.Put cartridges back and press and hold the resume button for 5 seconds.If you still have E5 error that mean you have a defective cartridge and you need to replaced.
Oct 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Using hp scanjet 3970 Just loaded hp scanning software and the large install of the 3970 drivers. When I enter the program the scanner opens and scans te image on the tray. (I am trying to scan a...
Have you checked the cord from the scanner lid to the scanner base. if that doesn't work I would try uninstalling the scanner and then reinstalling it. It sounds like a problem with the twain driver for the scanner.
Dec 20, 2008 | Computers & Internet
The Scan Dual IV will not initialize on startup although the door is closed.
 Hi I'm GusGusGus, I just posted a solution that might help. It's under the post about "2nd request for help on the scan dual 4", Hope it helps. Good Luck!
Jan 07, 2007 | Konica Minolta Dimage Scan Dual IV Film...
HP ScanJet 5370C Flatbed Scanner Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
