Question about Morphy Richards 40708 Iron
It's not working - Morphy Richards 40708 Iron
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 | Irons
Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Jul 04, 2012 | Rowenta Irons
My Rowenta Power Glide DE-08 iron has stopped working. Once, if I moved the cord around it worked. So I I took it apart and checked the wiring connection which seemed to be tight. I then plugged it in...
hi.
you will probably find that the cable is broken where it comes out of the iron.
this is not an unusual problem as the wire is being constantly bent and straightened here, and eventually breaks.
take the iron apart as you did before to check the connections, and cut of the last 4-5 inches of the cable and reconnect in exactly the same way it is now.
this should cure the problem.
hope this helps
Jun 18, 2011 | Rowenta Powerglide DE08 Iron
Nothing happens
Check the cord feed onthe part when it comes to the iron sometimes there got cable broken on the inside
Jun 03, 2010 | Rowenta DX-8800 Iron
Stream is not working
Sounds like the internal tab attached to the trigger is broken. Unplug unit, let cool. Pry up the rubber cushion from the handle, working from the front to the rear cord, You will probably see the tab lying on the switch. New trigger assy can be had from Rowenta Service Center:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
This would be my first choice as your boiler is working fine. Good luck and tell us how things get resolved.
May 23, 2010 | Rowenta DG-980 Iron
How the cordless iron box is working,please tell me the working principle
hi,
The working of Panasonic Cordless iron box is same as a normal Iron box except a fact that it uses rechargeable batteries for working. They can be recharged after usage. Thanks for using Fix-Ya! Please rate my solution as helpful!
Mar 21, 2010 | Panasonic Cordless Steam Iron - White/Aqua
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Steam not working
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Nov 06, 2008 | Conair Compact Garment Steamer Iron
Premature shutting off
the only thing you can do is change out the motion sensor which is 1n the machine or disable it
Apr 21, 2008 | Irons
Morphy Richards 40708 Iron Logo
24 people viewed this question
Top Morphy Richards Irons Experts
Mack Baxter
ray gallant
Are you a Morphy Richards Iron Expert? Answer questions, earn points and help others
