Question about Ecoquest Fresh Air Air Purifier
I have a FRESH AIR SPECTRUM UVX, air cleaner which I purchased from EcoQuest. The bulb in the unit is burnt out and I would like to replace it. The ECOQUEST part no. is 14-00036-001R. The number stamped on the bulb in big letters is 20707848 V.\r\nHope you can help me with a replacement or where I can purchase one in Canada, close to Toronto, Ontario Thank you Pete
    Brigadier General:
  • 4,736 Answers
Sagan, here's a link where you can find the parts you need. http://www.airpurifierrepair.com/
You can purchase them online.
Hope this helps you get the parts you need. if so, please be knid enough to leave a positive rating. Thanks!
Posted on Mar 25, 2011
How do you replace the bulb in a freshair purifier
Make sure you have the starter use with replacement bulb. Usually comes with replacement bulb. Open the back of th unit by removing the cover.
Oct 18, 2012 | Ecoquest Fresh Air Air Purifier
Is it possible to obtain an owners manual for the Ecoquest Fresh Air-Model Fresh Air 2.0? Intelliair SynAir G? We purchased a used one, biut need manual for proper cleaning instuctions.
The link below is to the EcoQuest Fresh Air manual. It doesn't specify model #'s but should provide you with the information to clean your unit. Thank you for using Fixya!
Greg
Ecoquest Fresh Air Manual
Jan 11, 2012 | Sharper Image Air Purifiers
Need a bulb for ecoquest fresh air spectrum
The Spectrum is no longer being manufactured/distributed by EcoQuest (now Vollara). We don't have extra bulbs in stock, either, but we can try to locate one from another dealer if you'd like. email us at fredandmb@frontier.com. We've been with the company 20+ years.
Feb 03, 2011 | Ecoquest Fresh Air Air Purifier
My Ecoquest Fresh Air Purifier is giving me a warning to replace bulb. I don't see anywhere on the manual where the bulb is.
The bulb is in the RCI module for the version 2.0 & 2.1. It the part that is rectangular with a honeycomb grid on two sides. Your dealer should be able to help you get a replacement. If you need more help just leave a comment. Hope this helps you.
Aug 31, 2010 | Ecoquest Fresh Air Air Purifier
Ecoquest fresh air
Yes it will. But do not run it on ozone mode while you or pets are present.
Mar 05, 2010 | Ecoquest Fresh Air Air Purifier
Why do you have to replace the plates in Ecoquest Fresh Air Unit
They get filled with the **** in the air which they remove for you.
Apr 16, 2009 | Ecoquest Fresh Air Air Purifier
I have a Fresh Air Unit from Ecoquest. The
When that message appears the plate does not make good contact with the two contact points. You can use rubbing alcohol and a q-tip to clean the points. After 1-2 years it is also advisable to change the purifier plate. Plates are about $15 and can be purchased at EcoQuest.com
If the plate is dirty (and this can unnoticeable grime-grease) clean the plate with 1 part clear ammonia and 1 part water. An old tooth brush works great.
Dutch
Fresh air flashes
This looks like a control board error. It needs to come in for repair. be careful not to turn it on, the RCI cell ( the blue light in the back) will stop working if it is switched off and on fast.
Call the company 1-800-989-2299 and get an RMA number. If you are under three years, you are still under warranty.
Dutch
Mar 28, 2009 | Ecoquest Fresh Air Air Purifier
EcoQuest Fresh Air Lamp replacement
Its probably the starter. Manual says to replace both lamp and starter at same time.
Jul 19, 2008 | Ecoquest Fresh Air Air Purifier
Lamp replacement???
Make sure the lamp is seated properly. Take it out, put it back in, turning it back and forth until it clicks. DO NOT TOUCH with your bare fingers.
May also need to replace the starter (the aluminum can at the rear of the unit).
Jan 20, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
400 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
