Question about Gateway Computers & Internet
The Fn key on my Gateway laptop is malfunctioning. When I type, the blue Fn characters on the keys is what is showing up unless I hold the Fn key down and type the letters I need...help...I replaced the keyboard because I thought it was bad but it is doing it with the new keyboard as well.
  • 112 Answers
Make sure Num Lock is turned off. If Num Lock is on the blue characters will show up by default.
Posted on Mar 26, 2011
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Feb 17, 2013 | Computers & Internet
My function is stuck on, i cannot type on my keyboard unless i hold the function key down the whole time i am typing. is there such a fn key release function.
Normally, if you hold down the "Fn" key, you'll get whatever character or function is printed in blue on those keys. So holding down the "Fn" key, you now have a numeric keypad in the middle of your keyboard. Release "Fn" and things are back to normal.
Which is exactly the opposite of what the question is asking. The person asking needed to press the "Fn" keys to get the normal, white, characters for each key.
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
numlk.jpg To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jan 14, 2011 | Computers & Internet
My Compaq laptop keyboard seems to be stuck in ALT mode. All the keys which have an alternate character in the upper right corner, will only type those characters. For example, the "m" key will only type...
Never ran into this problem myself but a friend of mine has. He said what fixed his what holding Fn + Num Lock and it remedied his problem.
Unless your key is stuck/broken you can also try a can of air and try to blow it out and or pull the key and make sure its not stuck down.
But deff try the holding Fn + Num Lock method first.
Jul 18, 2010 | Compaq Presario 700 470024-192 Notebook
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
Restore my acer 3680 back to factor
to restore your system to factory default....restart the system..immediately hold the AltGr key(the one right to the space bar)down...and keep tapping the F10 key...you should screen that says windows is loading file..if not try a couple of times...once you get that screen...navigate through the screen ..this will help you restore system to factory default
let me know if this helps...
regards
Dec 29, 2009 | Acer Aspire 3680 Laptop
Asus X58Cseries with Windows Vista Basic has $ sign on 4 key but no pound sign. Any way of getting it? If not, I can live with it but would like to know either way.Cheers, Linda.
I'm an Asus X58C user in the UK and my keyboard is the same. I've not found an easy solution. The only way I can insert a £ character is this. Place your coursor where you want the character. Turn Numbers Lock on using the blue Fn and NumLk keys. Hold down the Alt key and then using the blue numbers keys type 0163. Release the Alt key and the £ character will appear. Turn Numbers Lock off using the blue Fn and NumLk keys again. Its laborious but it works, its how I typed it here. I also found out that if you hold down Ctrl and Alt and then press the 4 key, you type the euro character €. Hope this helps
Oct 06, 2009 | ASUS 90-A4C1K1000 Keyboard
Blue characters on the keyboard when I type
It is a combination of key known as "Function" (Fn, for short). You have to press it and hold while pressing other keys showing the blue letters on it. The most common use is to make a virtual Numerical Keypad on laptops, so you can perform calculations. To be back to normal mode, you need to press FN+F8 (or the key with the Calculator icon).
May 28, 2009 | Compaq Presario R3000 Notebook
How do I use NumLoc on lenovo t-60? No keys for it?
If you hold down the Fn (function key) and hit one of the NumLock keys, this will type those NumLock characters usually printed in blue on the keytop). Also this is different on virtually every laptop, but one key should say NumLock or have a picture of a lock on it in blue. This is the NumLock and it is toggled by holding the Fn key and that key.
Jan 29, 2009 | Lenovo Thinkpad T60 Notebook
Function keys
Hi you need to hold down the function key (FN) and press the number lock key (num lk). hope this helps
Jan 14, 2008 | Gateway MX6453 Notebook
Computers & Internet Logo
206 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
