Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite QuietPak 2 front loading washer..lately it has been taking FOREVER to finish a cycle (always stalling at 0:01 when cycle is about to end) Suggestions??? I am also using HE detergent but often getting SUD warning (I have recently taken off front panel & cleaned out filter when I was getting SUD & F2 warning, so I don't undertsand why it's still doing it???)
    Brigadier General:
  • 6,277 Answers
Where you able to check the operation of the drain motor when yo removed the filter for cleaning?
If not please see the extract of my guidance notes ;-0)
REMOVE POWER
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Mar 25, 2011
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
Apr 07, 2016 | Kenmore Elite 45986 Front Load Washer
Why does my Kenmore HE3t front load washer always take more time to finish then what it says on the timer?
Check the filters in both ends of the hoses. If they are clogged, it will throw the timer off. If it figures on 2 minutes to fill but it actually takes 6 or 7 minutes, the timer won't be accurate.
Jan 20, 2013 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite washer and dryer is there any way to speed up the time it takes to do a load of wash it takes mine forever. Can it be reprogrammed or a way to reduce the time it takes for a wash...
No way to change pre programmed main control board, although you can use a gentle/delicate cycle that does have a shorter wash time. I would not use this for very dirty laundry. Good Luck, Appliance Specialists
Jan 06, 2010 | Kenmore Elite 45986 Front Load Washer
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine
full of sudsy soap after cycle complete, no water ???sounds as if your using the wrong detergent, youll NEED to use an HE detergent (low sudsing)specifically designed for use with front loading washers
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite steamwash quietpak 9
This problem is usually associated with the connection between (poor communication) the main controller and the touchpad. unplug the unit for about a minute - power back up and go through a series of selecting different cycles and options - if problem still persists the connectors need to be checked - If connections checked out change touch pad
Regards
Sep 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
