Question about Brother GX-6750 Typewriter
Hi, MY typewriter is not working. The printing device is stuck on the left side and it beeps loudly when I turn it on and says check printer. Can you tell me what the problem is please. Thank you.
  • 86 Answers
It could be that the printhammer is not latched into place. push forward on the black lever to the right front of the printwheel until it latches into place. if the P/H is already latched into place, look into the machine with it turned off and unplugged and try to move the carrier by hand and look to see if there is some forien object in the machine. if this doesn't help, seek professional help or replace the machine.
Posted on Mar 25, 2011
I have a brother sx-4000 typewriter,when i turn it on, there is a beeping noise an the little screen saidspitch10 line1 word spell. Can somebody tell me whats wrong with my typewriter?
If beep that does not stop after start up you may have bad key switch or the ribbon end sensor may be stuck . Check it out, and get back with any info nomatter how small , listen to it very closely when you turn it on you should hear the print assembly check for the home position, this may seem insignificant but my be the vital info that tips the scales you way, good luck, Bret
Mar 08, 2015 | Brother SX-4000 Electronic Typewriter
I have a Swintec 8016 that doesn't have a "print" key. How do I print stored files?
Hi Linda, Once upon a time, I worked on Swintec typewriters. When you speak of printing do you mean to an external printer or just allowing the thy writer to to type out of memory? What kind of printer, what type of external port. Did it ever work? With what printer? I,m not familiar with this particular typewriter , give me as much info as you can , I mean anything you can think of . The smallest detail can tip the scale. You stated there is no print key, that tells me there must be an alternative way to print. let me know what you find out. If you can take a picture of the plug ports on the back and the keyboard, in this case a picture is worth more than words! Good luck. Bret... I was a typewriter tech for 7 years there are not many of us left.
Jan 04, 2015 | Swintec 8016 Typewriter
How does the print head on a Brother ML-100 sense when it has reached the left hand side after a carriage return?
when the print head reaches the left side it touches a switch to cause it to inter the setup for the print wheel and ribbon mechanism
Dec 06, 2014 | Brother ML-100 Typewriter
Beeps
Check for debris inside T/W, put some WD40 on the silver shaft that the carrier rides on. If these fail check the wiring harness about 1" from carrier you may find broken wires there.
DickyO
Jun 16, 2010 | Nakajima AE-740 Typewriter
IBM wheelwright 15 series 2
Try puting some light oil (WD40 works well) on the silver shaft that the carrier slides on, also check for debris it that area.
DickyO
Jul 06, 2009 | Lexmark Wheelwriter 15 Series II...
Brand new EM630
there is a set of graphics on the instruction book that indicate the packing pieces that are to be removed. there was one more item that at first look seemed part of the mechanism and was not clear on the graphic. spoke to tech support for brother who told me what to look for, and how to remove it (white double spire-looking thing). once i removed this piece, the print cartridge was released to the left side of the machine and it worked just fine.
Jul 31, 2008 | Brother EM-630 Typewriter
Beeping
It most likely beeping because it cannot make its resetting movement. That is,it cannot "find-out" where its left margin is. There may be something hindering the actual movement of the print carrier. Check inside the typewriter by lifting up the top cover and move the print unit by hand. It should be able to move from the left to right-hand side of the typewriter unhindered. The shaft that the print unit moves on should be clean and it may have gathered dust etc,so give it a wipe with a clean cloth (lint free) with a small drop of light oil on it.. Replace the top cover and switch on the machine
Nov 05, 2007 | Nakajima AE-740 Typewriter
New Cartridge Will Not Drop
Make sure the print hammer is pushed forward as far as possible so that it is latched
Aug 27, 2007 | Brother ML-300 Typewriter
Brother GX-6750 Typewriter Logo
65 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
