With the use of rca/video cables and the Samsung composite cable, how do I connect to an audio/video receiver(surround sound)
  • 961 Answers
There are alot of different options when it comes to your connection basically , it comes down to quality and what in and out jacks are available to use. To me 'composite cables" were always the red, white, yellow combo where, yellow is video and red and white are l/r sound. "Component cables" were always red blue and green. The component cable provides a higher quality picture but, does not carry sound, like composite. To gain sound using component cables, you have to add either your yellow composite or a digital optical cable, again, depending on what your system will accept. HDMI carries both audio and video at the best quality and is easy. To answer the question for what you have if you have "composite"(red, blue,green) this will provide the best picture but, you will have to use the red and white "composite" for sound.
Posted on Mar 25, 2011
  • David Petry Mar 25, 2011
    I said yellow for sound above and meant red and white.(either your yellow composite)
How to hook up a laptop to play utube music
Buy a 3.5 mm-to-RCA audio cable (you will probably need a long one). Plug the 3,5 mm. end of the cable into the headset jack of your laptop and the RCA end of the cable into the RCA/composite (R/L) audio input of your receiver.
Dec 21, 2014 | Sony Str-k665p Am/fm Receiver Digital...
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
How do i get my TV to play through my surround sound system
I don't know which receiver you have but, I can give you a basic idea.
You need RCA cables Yellow for Video, Red and White for Audio.
You may not need to connect the Yellow cable for the Video again, it depends on the receiver you're using. Basically, to get the TV sound from your Surround system, you only need the white and Red RCA cables.
Connect one side of the RCA cable white & Red to the receiver (IN) and the other side of the RCA Cable to the TV or cable box (out) You need to select the source on the receiver, AUX or Video.
I could help better if I knew which receiver, if you're using a cable box and how are you getting TV signal? do you select CH 3 or AV to watch TV?
Best of luck to you.
AAA TV SERVICE
www.aaatvservice.com
Jul 31, 2011 | Samsung TXK2766 27" TV
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
Audio Issue
component has 3 video cables.... then you have to use the composite Red & White cables as your audio.
so you are using both the component video with the composite audio to achieve this. 5 RCA cables total. you will NOT be using the composite video cable(yellow). But you will use the Red & White for audio...
simple.. good luck
Sep 25, 2009 | Microsoft Xbox 360 Console
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
Help! Surround Sound problems!
Since you have a surround sound system, you probably should just bypass the TV's audio.
Connect the red/white plugs from your digital cable box to one of the inputs on your surround sound system but not the Phono input unless the Phono input lists something aside from Phono, like Aux/Phono or CD/Phono.
Connect the S-Video or composite (yellow) video plug from your digital cable box directly to the S-Video or composite (yellow) video jack on your TV.
If your digital cable box does not have a S-Video (4 pins and flat rectangular hole) or Composite (yellow RCA jack) jack and only has the screw/push-on type cable with the pin in it, then leave the remaining connections as-is.
Now switch your surround sound system to the input you connected the red and white plugs to and turn on your TV. You should see picture from the TV, but hear audio from the surround sound system.
Apr 06, 2008 | Emerson EWF2004 20" TV
 Grubhead
Grubhead
