My guess would be the power oscillator mosfets. Was the 25V AC or DC? If there is no AC and the output is DC then the chances are very good that one of the switching mosfets that produce the AC is shot. These are usually set up in an H-Bridge configuration and both the neutral and hot leads alternately get switched between high voltage DC and ground, producing a modified sine wave output. For the cost of one of these inverters, it might be cheaper to just buy a new one and recycle the old.
SOURCE: I need to replace the 120 volt AC wall adaptor
Here is your link to buy it.
http://www.centurytool.net/5140044_04_Charger_W_Small_Jack_p/5140044-04.htm
SOURCE: Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
SOURCE: My 400 watt inverter will not charge my laptop the
Your laptop PS has big condensers in the input. Even supplied by mains through 6A quick fuse or automatic breaker it will drop first time, but may hold the second. Your inverter may be has fast fuse 2 - 5 A. If not so fast it may carry the initial load.
Hint: If you are not "both left handed" you can connect 20 - 200 Ohm (2 - 10 W) resistor in series to your Laptop Power Supply. After the initial start of the inverter you can shorten the resistor by a 3 - 5 A switch.
SOURCE: (Vector 400 Watt sst Power inverter) When I plug
I am assuming that the inverter works with other devices. This being the case, i am thinking that the television start up current is drawing too much power too quick for the inverter to handle and this is what is shutting down the inverter.
SOURCE: i bought two veco51d 3000 watt inverters made by
Hello, I hear you. Was the reason to supply 240 volts? When you try the inverters separately, do you get 120Volts output? Let us look at the units working individually first and go from there.
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
