Question about Shimano Dura Ace CS-7900
Hi i fitted a CS-7900 to a 10speed freehub. the shimano instructions say install the spacer to the "9speed freehub" but there is not mention of if it is needed or not when fitting to a 10 speed. Hope you can help. Mark
    Guru:
  • 347 Answers
So, the answer is maybe. Not all freehubs are the same. Some 10spd freehubs do and some don't. If your not having a binding problem with your freehub and when the rear derailleur is lined up with the lowest (inside) cog and it's not hitting your spokes then it's good. if either of these things happen install the spacer.
Posted on Mar 25, 2011
Fitting instructions needed for Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
The semi-circular spacer is what holds the derailleur in the dropout. Take the part that looks like a "C" and line it up on the drop out, the spacer goes on the other side of the dropout. There should be a screw that fastens to the spacer and clamps the derailleur to the drop out.
Apr 14, 2014 | Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur...
Does anyone have fitting instructions Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
the half circle nut needs to be loosened up, slide the whole lot of it into the rear dropout until it stops, tighten up the bolt to the nut and make sure the dropout slots match up with the derailleur dropout slots and you should be ready to go. Install your back wheel, chain and cable.
Ho remove freehub on shimano fh-rm30
The free hub body can be removed from the hub after the axle and bearings are removed. Typically you use a #8 Allen wrench. It will be tight and will take some effort, righty tighty-lefty loosy.
Jan 19, 2014 | Shimano Cycling
I have a 2001 Specialized StumpJumper FSR XC and have put a new chain wheel on 48t and I'm struggling to find a front deriailleur that fits any help please?
Clamp on front mech xt or xtr would be an option, be careful if you need bottom pull or top, cut or grind off bracket on old front mech to reinstall,as this is a spacer as well as a mounting bracket ,bit old school but older front mechs are best
Jun 16, 2017 | Shimano Cycling
Good day guys, i would like to ask if it is possible to repair the "shimano dura ace cs-7900" and those other shimano rear speed sprocket? because my speed gear wasn't working. thanks guys.....
What's not working about it? It has NO MOVING parts.
You can find details for it and everything Shimano at http://techdocs.shimano.com/techdocs/index.jsp
Chain issues maybe?
http://sheldonbrown.com/chains.html
Derailleur adjustment? Get focused in if you want specific help.
This resource covers a lot...
http://www.parktool.com/blog/repair-help
Search engines "how to..." also find a lot of procedures in video form.
Jul 14, 2011 | Shimano Dura Ace CS-7900
Which way round
you place it between 1and 2 or at the end of the of the sprocket don't worry about that just install it
Jan 16, 2010 | Razor Fz 2000 20-Inch Freestyle Bike
Need to replace the cassette body on my Ksyrium SL wheel. Is there a tech sheet on this procedure?
You need two tools: a cassette wrench or socket (it's a splined socket that fits into the cassette through the axle)and a chain whip wrench. You use the chain whip by wrapping it around one of the cogs of the cassette to immobilize it and then loosen the lock nut of the cassette with the cassette wrench. It is just like a screw or bolt. The Cassette needs to be lined up with the splines on the freehub. Find the thin spline and use it as your "key" because it is the only one that width. Then drop the new cassette on to the freehub and re-torque the cassette's lock ring. If the cassette is disassembled rather than one piece, from the largest cog first on the bottom, alternate between cogs and spacers until you are out of spacers. The smallest cogs have these cast in. As you take the old one off, the installation technique is the same in reverse.
Regards,
matt
Sep 14, 2009 | Mavic Cycling
HELLO, I HAVE A DURA ACE 7900 MODEL CASSETTE AND WOULD LIKE TO PUT IT ON A KSYRIUM SL RIM, DO I HAVE TO PUT THE SPACER ON IT BEFORE THE WHOLE CASSETTE GOES ON? THE CASSETTE IS A 12-25 GEAR.
In my experience with Shimano cassettes on Mavic wheels, the answer is "yes" but i had a mountain wheel and cassette. The only way to know is to put it on and see if there is slop in the fitment. If there is, then you have your answer. i also had this problem with Mavic: i had to adjust the high and low settings on my rear derailleur because of the awkward spacing of the Mavic freehub. Just something you should be aware of in case you have difficulty with shifting after the install. By the way - although they are inferior cassettes, SRAM cassettes seem to fit Mavic freehubs better.
Regards,
matt
Sep 14, 2009 | Cannondale Cycling
Shimano Dura Ace CS-7900 Logo
110 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
