Question about Mitsubishi WS-65611 65" Rear Projection Television
MY TV IS OUT OF FOCUS ON THE ENDS CLEAR IN THE MIDDLE WITH GHOSTING RED A BLUE EVERWORD OR DIAGRAM LOOKS 3 D OR DOUBLE VISION WHY
Your convergence ic 2 of them need to be replaced and convergence done this will cost about 300 dollars
Posted on Mar 25, 2011
    Scholar:
  • 146 Answers
Have you tried adjusting the convergence on the tv
once they get older or get moved you need to do this
go through on screen menus and look for adjusting convergence menu and follow on screen instructions
good luck!
Convergence, picture is warped on the sides, double images or ghosts, clear in middle
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2010 | Sony KP-51WS520 51" Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 16, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red lamp gives off ghostly blurr
Red convergence IC is bad...replace both STK IC for durable,
long-lasting repair..............................T.
Dec 24, 2007 | JVC AV-48WP30 48" Rear Projection...
53fdx20b double vision?
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 18, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Ghosts in Tv Projection TV
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 02, 2007 | Philips 60PP9352 60" Rear Projection...
Blue ghost
If you have the ability to work on solid state electronics and know how these circuits work, you will need to replace the convergence IC's in this TV set. If you do not, call in a pro to assist you in this repair. Good Luck
Jun 20, 2007 | Toshiba 43H71 43" Rear Projection...
Mitsubishi WS-65611 65" Rear Projection Television Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
