Question about Panasonic KX-T7636-B Corded Phone
Panasonic KX-T7636 I can't pick up voice messages. What am I doing wrong? Press intercom, then message, then the 4 digit passcode followed by # All I get is a busy signal!
  • mail791 Mar 28, 2011
    There are no prompts. The phone automatically starts ringing busy. I'm guessing that I am testing it without having a message to listen to, therefore, it does not go into the prompt. I've picked up messages, but since I have a new job, I was testing how to pick up messages but without a message to pick up.
  • Panasonic Master
  • 2,460 Answers
Are you listening to the prompts after you press all of these things? By default, a Panasonic voice mail sysetm uses 500 as the VM extension. So, you could just dial 500 on the intercom and listen to the prompt. If you're getting it, you're asked to give your password and then "#". If that doesn't work, the voice mail owner (mailbox 999) can reset the password.
I'm guessing you're not listening for any prompt at all.
Carl
Posted on Mar 25, 2011
  • Carl Navarro
    Carl Navarro Mar 31, 2011
    Then either record a message, or just dial 500 on the intercom.
HOW DO I CHANGE THE GREETING ON A KX-T7453 PANASONIC CORDED PHONE?
The KX-T7453 phone does not have a message function, you may have an associated voicemail on your system. Try dialing (on the intercom) extension 165 if you do not have a voicemail button. Are you trying to change the greeting for your individual phone or the main greeting people hear when they call your company?
This gets a lot more complicated and you should contact your vendor.
Dec 24, 2014 | Panasonic KX-T7453 Corded Phone
How do you set up voicemail on the Panasonic KX-T7636 system?
1. Raise the handset on any telephone in the Panasonic Telephone system.
2. Press the "INTERCOM" button and dial 165.
3. When answered by the Auto Attendant, dial # XXXXX * 9 9 8.
(Pound Six Star Nine Nine Eight)
4. Enter the Administrator Password. Followed by a #. (Pound) If required.
5. Dial 5 to "Modify Message"
6. Dial 1 to "To Change The Company Greeting"
7. Enter the Company Greeting Number from 1 to 32.
If you are not sure of which Company Greeting Number to change, then start with 1.
The Panasonic Voice Mail system will actually play the greeting to you.
Then you can determine if it is the correct one you want to change.
If it isn't, you can dial 2 and move on to next greeting and so on.
If you select a greeting number where there is no greeting recorded,
the Panasonic Voice Mail system will prompt you to record one at that time.
You may dial *1 (STAR ONE) to skip recording and return to Step 7.
8. When you have found the Company Greeting you want to re-record
follow the system prompts to record and save your new greeting.
Note:
You can change the Company Greetings remotely from anywhere.
1. Call the main number of your business.
2. When answered go to Step 3 and follow the same procedures.
3. When completed....Hang up....
Aug 09, 2011 | Panasonic KX-T7636-B Corded Phone
I have a Panasonic KX-T7636 phone system. We have a new receptionist and want to change the main menu greeting so that one of the options is "press zero for (new assistant)" instead of the old...
You have a Panasonic 7636 PHONE. The system is either a TDA/TDE or NCP. The Voice Mail system is either embedded or a TVA and it comes with a set of instructions. Custom service announcements and company greetings are administered from the message manager's mailbox 998. Check your original installation notes and documentation for how to do that.
Carl
Jul 08, 2011 | Panasonic KX-T7636-B Corded Phone
Can't pick up phone messages off a Panasonic (office phone) KX-T7636
hello you will have to call your network provider they will set it up for you only takes 2min goodluck
Mar 25, 2011 | Panasonic KX-T7636-B Corded Phone
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
Message light not resetting after clearing message box. Panasonic KX-T7636
Press the MESSAGE button and look at the display. Message waiting can come from any phone or port in the system, not just the voice mail.
The soft keys has a CLEAR function.
May 14, 2010 | Toshiba DKT 3010 Corded Phone
HOW TO LEAVE A VOICE MESSAGE ON A PANOSONIC kX-t7636
Your VM has an extension, usually 165 or 500. You forward your phone to Voice Mail by dialing *710x 500 # where x is 2 for all calls, 3 for busy, 4 for no answer or 5 for NA/Busy. I use 4.
The FWD/DND light will blink and the display will say Call FWD (condition) 500.
Now, all calls, both from the inside and outside will forward to the voice mail system.
Carl
Apr 15, 2010 | Panasonic KX-T7636BK Digital Telephone...
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Panasonic KX-T7453
    If there is a voice mail button on the other set/s, press it, then [#][6], then [*] and your mailbox number.
    If there is no button, press [intercom] 165, [#][6], [*] and your maibox number.
    Note that 165 is a common voice mail extention number, but it may vary from site to site.
    Jul 02, 2008 | Panasonic KX-T7453 Corded Phone
    Panasonic KX-T7636-B Corded Phone Logo
    109 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
