Question about Chicco 4-in-1 Quattro Ride On Car
After opening box and making sure all parts plus instruction booklet were included, I started to assemble product. Most of the issues were fine until we came to the last few steps. In assembling the seat back (green and yellow part) I noticed that the teeth in the back were note reaching the notech that they go in. With further investigation, I also noticed that the removeble arm rests were also not going in all the way. I have been able to assemble it but there are parts that aren't secure and there are several places where fingers and such could get pinched.
I recently changed the filter. Now after pressing START it makes a noise then says FILL SYSTEM. After I press the water portion button, things are fine. This happens everytime I turn on my machine.
I think you could use this manual method instead.. My nephew use it to repair my car and it's totally repaired now. Here's the website he bought it from. www.reliable-store.com
everything covered
wiring diagram/ electrical
error/fault codes
repair instructions including removal, installation, assembly
parts info
pcv
service instructions
troubleshtooing
engine issue
etc. a lot more
Jun 10, 2018 | Washing Machines
Charged my quick power cordless vac.no 440004454 for 6 hr. like the booklet said. tried it out for about 15 min., worked well. next day went to use it, no power. and now it won't even charge.
everything covered
error/fault codes
parts info
pcv
troubleshooting
engine issue
etc. a lot more
Jun 10, 2018 | Cars & Trucks
My glove box won't open in my 2013mkx and I believe something is stuck on the latch that is preventing it from opening. How can I take it apart to get it open.
everything covered
wiring diagram/ electrical,
error/fault codes
repair instructions including removal, installation, assembly, parts info, pcv, service instructions
troubleshooting
engine issue
etc. a lot more
Jun 09, 2018 | Cars & Trucks
My kabota 1100c rtv starts fine but not enough power to make it move
everything covered
wiring diagram/ electrical, error/fault codes
troubleshooting
engine issue
etc. a lot more
Need instruction booklet
then I would go to place of purchase and see if they have one you can have or make a copy of for you
Apr 13, 2015 | Panasonic KXTG6572C KX-TG6572C KX TG6572C...
Prints very slowly
After you print a test page and establish a baseline print speed for your HP product, you determine that computer issues cause slow printing. Solution one: Check minimum system requirementsThe most common cause of slow printing is a computer that runs at or near its system resource limit. Follow these steps to make sure that your computer has enough system resources to process timely print jobs. Step one: Make sure that the computer meets RAM requirementsThe amount of available random access memory (RAM) can affect print speed. Follow these steps to make sure that the available RAM exceeds the minimum requirement for the HP product.
  1. Open the computer Properties window:
    • Windows XP : Click Start (c01827528.gif ), right-click My Computer , and then click Properties .
    • Windows Vista or Windows 7 : On the Windows task bar, click the Windows icon (c01364735.gif ), right-click Computer , and then click Properties .
  2. Find the available RAM and make a note of it:
    • Windows XP : Click the General tab, if it is not already selected. Find the amount of RAM in the list with the other Computer specifications.
    • Windows Vista or Windows 7 : Find the Memory (RAM) in the System section.
  3. Check the system requirements for your product, listed in the product manual and on the box, to make sure that your computer has enough memory.In general HP recommends the following RAM:Operating SystemRecommended RAMWindows XP128 MB minimum
    256 MB recommendedWindows Vista512 MB minimum
    1 GB or higher recommended Windows 7 (32-bit) 1 GB minimum
    1 GB or higher recommendedWindows 7 (64-bit)2 GB minimum
    2 GB or higher recommendedc01647276.gif These recommendations vary by product, so if you are not sure of the specific requirements for your HP product, look in the manual or on the box. Or, you can follow these steps to check the product specifications online:
    1. Right-click this link, Product Support Home Page , and then click Open in New Window .
    2. Type your product model in the Locate your product to get support search box, and then click Next . A list of products displays in the search results.
    3. Click your product from the list displayed in the search results. The support page for your product displays.
    4. Click Product information , and then click Product specifications .
Step two: Make sure that the computer hard drive has enough free spaceThe amount of available hard drive space can affect print speed. Follow these steps to make sure that the available hard drive space exceeds the minimum requirement for the HP product.
  1. Open the My Computer window:
    • Windows XP : Click Start (c01827528.gif ), and then click My Computer .
    • Windows Vista or Windows 7 : Click the Windows icon (c01364735.gif ), and then click Computer .
  2. Right-click on the drive containing your operating system, typically (C:) , and then click Properties . The Properties window opens.On the General tab, find the available space, or free space, on the hard drive.Figure 1: Example of hard drive information in the Properties windowc01912502.gifIn general, HP recommends the following free hard drive space:Operating SystemRecommended hard drive spaceWindows XP200 MB minimum
    1 GB recommendedWindows Vista650 MB minimum
    2 GB or higher recommendedWindows 7550 MB minimum
  3. If the free disk space is near or under the minimum requirement listed in the table above, click Disk Cleanup to free up disk space.
Step three: Make sure that the computer meets CPU requirementsIf the computer does not meet CPU requirements, the print speed might be affected. Follow these steps to make sure that the computer meets the minimum CPU requirements.
  2. Find the CPU specifications and make a note of it:
    • Windows XP : Click the General tab, if it is not already selected. Find the computer processor information with the other Computer specifications.
    • Windows Vista or Windows 7 : Find the computer processor information in the System section.Use the following table to make sure your computer meets the minimum CPU requirements:Operating systemMinimum CPU requirementsWindows XP233 MHz Intel Pentium II or Celeron processorWindows Vista800 MHz 32-bit (x86) or 64-bit (x64) processorWindows 71 GHz 32-bit (x86) or 64-bit (x64) processor
  3. Print and time a self-test page again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Close unnecessary programs and processesFollow these steps to close all unnecessary programs to try to speed up printing.Step one: Close all unnecessary programs
  1. Press and hold the Ctrl + Alt + Delete keys on the keyboard.The Windows Security dialog box opens.
  2. Click the Task Manager button in the Windows Security dialog box. The Windows Task Manager dialog box opens.note.pngNOTE:If the Windows Task Manager dialog box does not open, right-click on the task bar and select Task Manager .
  3. In the Windows Task Manager dialog box, select a software program from the Applications tab, and then click End Task to close the program.
  4. Repeat the previous step until you have closed all unnecessary programs.
Step two: Close any unnecessary processesProcesses run in the background even when no applications are in use. Follow these steps to end unnecessary processes.
  1. Return to the Windows Task Manager that you opened in the previous step.
  2. Click the Processes tab.
  3. Select the process to end, and then click End Process .note.pngNOTE:If another window opens and indicates that the task has stopped responding, click End Task .
  4. Repeat the preceding step to end all unnecessary processes.note.pngNOTE:You cannot end critical system processes.
  5. Print and time a self-test page again.
Solution three: Check the print settingsPrint settings can affect print times. Follow these steps to check the settings for paper type and print quality.
  1. Open the Printers folder:
    • Windows XP : Click Start (c01827528.gif ), and then click Printers and Faxes .
    • Windows Vista : Click the Windows icon (c01364735.gif ), click Control Panel , and then double-click Printers .
    • Windows 7 : Click the Windows icon (c01364735.gif ), click Control Panel , and then double-click Printers & Devices .
  2. Right-click the icon for your product (c01520247.gif or c01514371.gif ), and then click Properties . The Properties dialog box opens.
  3. On the General tab, click Printing Preferences . The Printing Preferences dialog box opens.
  4. Click the Paper/Quality tab.
  5. Click the drop-down list under Media , and then select Plain Paper .
  6. In the Quality Settings section, select Normal .
  7. Click Apply in the Printing Preferences dialog box to save the settings, and then click OK to close the dialog box.
  8. In the Properties dialog box, on the General tab, click Print Test Page . The product prints a test page.
Solution four: Remove and reinstall the HP softwareThere might be a more current driver available for your HP product. HP recommends that you use the latest version to correct printing problems. Follow these steps to remove the HP software, and then reinstall it. Step one: Remove the HP software
  1. Unplug the USB cable connecting the product to the computer.
  2. Open the Windows Control Panel .
    • Windows XP : Click Start (c01827528.gif ), and then click Control Panel .
    • Windows Vista or Windows 7 : On the Windows taskbar, click the Windows icon (c01364735.gif ), and then click Control Panel .
    The Control Panel window opens.
  3. Open the list of installed programs and remove the software.
    • Windows XP : Double-click Add/Remove Programs . In the list of installed programs, click the HP product, and then click Add/Remove .
    • Windows Vista or Windows 7 : Click Programs . In the list of installed programs, click the HP product, and then click Uninstall .
  4. Follow the on-screen instructions to complete the uninstall.caution.pngCAUTION:If asked to remove shared files, click No . Other programs that use these files might not work if you delete the files.
  5. Disconnect the product from the power source, and then restart the computer.
Step two: Download and reinstall the HP softwareIMPORTANT: If you receive any third-party firewall messages during installation (for example, a message from McAfee), click continue , unblock , yes , allow , or permit . Otherwise the software installation fails.
  1. Disconnect the USB cable from both the product and the computer (if you already connected it).
  2. Turn the product on.
  3. Browse to the Get Software and Drivers page: Get Software and Drivers
  4. Check the instructions on the page, and then click the Plus sign (+) next to the correct heading for additional instructions:
  5. Click the Plus sign (c02200813.gif ) next to Driver , and then click the driver that you want to download.
  6. Read through the minimum system requirements and additional instructions. You can also click View directions (c016472760.gif ) for complete download instructions.
  7. Click Download . This option allows you to install the software at any time after the download completes.
  8. Click Save , and then browse to the location on your computer where you want to save the file.
  9. Click Save . The software downloads to your computer.Hint: Make a note of the place that you saved the file, in case you want to install it at a later time.
  10. hope this help : - )
Dec 20, 2012 | HP Photosmart 6510 e-All-in-One -...
Just opened up box and no instruction booklet nor remote control included
Contacted Danby- Direct and they are sending me the missing parts from my order...
Thanks for you help.
Jun 02, 2009 | Danby DPAC120068 Air Conditioner
My lens wont open when i turn it on
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Feb 26, 2009 | Olympus FE-230 Digital Camera
Need icoaster instructions
go to thee web site and click on down load instruction booklet for that product make sure u have the model and serial numbers available you might nedd them , you should find these numbers on the bottom or side of the product it self or on the box if you still have the box the product came in.
Nov 30, 2008 | Toys
Chicco 4-in-1 Quattro Ride On Car Logo
18 people viewed this question
Top Chicco Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Chicco Toy Expert? Answer questions, earn points and help others
