Question about Nintendo Pokemon Pearl Version for DS
I want to get a good dry berry and i have no wifi connection
Can cranberry sauce be frozen
Simply, yes.
If the sauce is whole-berry sauce the texture when thawed again will be off, because the ice crystals will have ruptured the berries, but jellied cranberry sauce should be fine, though might be a bit watery when thawed.
Dec 04, 2013 | Camping, Backpacking & Hiking
Tip
Blackberry 9630 tour or any black berry
Roller ball stuck: get some denatured alcohol put it on a dry paper<br /> <br /> towel then press on the roller ball. work it back and forth, until<br /> <br /> all the grit and dirt is removed. good luck!
on Jul 10, 2011 | Cell Phones
Bb 8520 wifi hack to hack nehbor's wifi hack crack
black berry 8520 wifi conection settings
Jan 20, 2013 | Cell Phones
How to play radio on BB bold 9700
if you have wifi at home and you use a laptop to surf, then you can do the same with your berry. it should automatically connect to your router when you run a scan. se the wifi forum for more help
to main wifi setting do it though options/advanced/browser as it doesn't always save when you do it through options directly in the browser.
3g/2g - browsing only a real reason to need if you are at work and don't have net access or you are out and about and want to check something on the net quickly
Feb 24, 2012 | Cell Phones
I bought Foot Works berry mint soak from Avon, but instructions are only in russian language. I need to know the instructions necessarily !
Firstly clean that area with water where you want to apply this, dry with towel and apply the Foot Works berry. Use it 3 times in a day. For more help http://www.homeoinformation.blogspot.com
Jul 03, 2011 | Avon Foot Works Vanilla & Brown Sugar Foot...
Please tell steps in opening gprs of black berry 8520, and i cant acces wifi
in setting up gprs for blackberry 8520 you have to contact first your network provider to ask for the settings. After getting the settings just follow the step below.
In network selection you have to choose 3G.
go to option >adavanced option>TCP/IP> both option tick enable( put tick mark)
for APN: name of the network
username and password: blank
For you to access wifi, you have to remove your phone on 3G mode and just switch it to GSM. because by default your phone is defaulted to your network.
'Try manual search for wifi connection
  1. On the Home screen, click the Manage Connections icon.
  2. Click Mobile Network Options.
  3. Change the Network Selection Mode field to Manual.
  4. Click Scan for Available Networks.
  5. Click a wireless network.
  6. Click Select Network.
  7. Press the Menu key.
  8. Click Save.
May 17, 2011 | Computers & Internet
Does all black berrys come wit wifi
sure do!!! you want to press menu, then manage connections, then select wifi on and besure to set up wifi under the same menu. you want to make sure though that you are by a wifi signal or wireless router. i hope this helps!!!
Jan 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
How do i connect my black berry 8700 in computer
It is always best to download both the latest Desktop and Handheld Software to ensure the best compatibility. For more information on how to download and install the latest handheld software version go to Downloading the BlackBerry® Desktop and Handheld Software. then connect the black berry to your system
Sep 19, 2009 | RIM BlackBerry 8700c Cellular Phone
Phone Book Transfer Nokia N70 - Blackberry 9000
Syncronization! The Nokia phone will not just easily transfer or sync the contacts to your Black Berry because they are running on 2 different softwares.
In order for you to transfer all the contacts to your Black Berry is through synchronization
The Nokia N70 came with a CD called the Nokia PC Suite. And Black Berry should have a sync software.
What are the things you need:
1. Computer
2. Nokia N70
3. Black Berry phone
4. Nokia PC Suite CD
5. Black Berry sync software
How:
1. Install the Nokia PC suite to the computer.
2. Connect the Nokia N70 to the computer.
3. Export all the Contacts from Nokia N70 to your computer (refer to the manual)
4. Once the contacts are saved in your computer, disconnect the Nokia and connect your Black Berry.
5. Run the sync software of Black Berry and import the Contacts that are saved in the computer going to your Black Berry (refer to the manual of Black berry).
This is hiow to transfer the contacts from one phone to another.
I would also suggest to contact Nokia so that you will have a clearer idea on how to do it.
May 23, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Black berry got a little water on it, and would not work
take baterry out and let it completely dry for 24hours
Mar 23, 2009 | RIM BlackBerry Pearl 8100
Nintendo Pokemon Pearl Version for DS Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
