Question about Square D 9013FHG14J52M1X Air Compressor Pressure Switch
I have a air compressure with a square d 9013fhg44mix pressure switch. The problem is where the 1/4 air line goes, this valve leaks when ever the compressor is off. Once the compress is on it is off and then when the compressor turns back off air leaks out of the valve again. Is there an adjustment on this? Bought new switch and have the same problem. Is this 1/4 inch line neccesary?
  • 885 Answers
The 1/4" line is very necessary and there are no adjustments on it. When the tank reaches full the pressure switch turns off the power and opens the valve to the 1/4" line to bleed off pressure from the air pump and feed tube so the motor can turn over the next time the tank drops to the kick in pressure. Every time the pressure switch turns the motor off a small amount of air should be heard coming out of the bottom of the switch for three to five seconds and then it should stop completely. If air continues to leak out of the switch by the 1/4" line, you have a bad tank check valve. The tank check valve is the brass fitting at the other end of the 1/4" line where the feed tube from the air pump goes into the tank. It keeps air in the tank after the pressure switch turns off the motor. Easy to replace, find the one you need for your model compressor.
Posted on Mar 25, 2011
I have a Dewalt model D55166. It will not shut off when it reaches the maximum allowed air pressure. What could cause this?
If safety pressure release valve pops open then electric pressure switch is bad, however if compressure keeps running and never pops safety valve then most likely tubing / joint leaks or cylinder / ring worn out. Spray soapy water on all joints and drain valve , if no leaks suspect cylinder. Good luck
Feb 23, 2015 | Dewalt Air Tools & Compressors
We have a craftsman 60 gallon air compressor model 919.175.260. The valve on the side of the pressure switch is leaking air. What might be wrong? Thanks.
If their is air leaking out of the pressure switch after the motor turns off you have a stuck or broken tank check valve. The check valve (PN CAC-437-2) is located on the tank where the line from the pump goes into the tank. There is also a smaller line from the check valve to the pressure switch. If working properly, the check valve lets air into the tank but closes when the motor shuts off. The pressure switch then opens a valve to the smaller line and lets the pressure out of the pump head and lines so the motor can restart when the pressure drops. On rare occasions you can remove the valve and clean it, but more often than not, you have to replace it.
Aug 24, 2012 | Craftsman Air Tools & Compressors
Bostitch compressor
If air continues to leak from the pressure switch after cycle is indication that the check valve is not sealing or the pressure switch diaphragm has failed. Easy fix. Follow the 1/4 inch airline to the tank and remove the line from the brass valve(check valve). If air is leaking at the brass valve, remove it and attempt to clear debris under valve or replace as needed. If no air is leaking from the checkvalve, then most likely diaphragm is leaking. You could replace the diaprhagm or the whole switch. Generic switch is available thru ebay about 18- $20
Oct 29, 2011 | Air Tools & Compressors
I R Ts4 5hp 80 gal 175 psi 230 volt Air leaking from near pressure switch. Replaced switch but still leaking near 1/4 tubing. Thanks
You have a receiver tank check valve leaking. If you loosen the 1/4 tube slightly and air blows out more and will not stop replace the tank check valve. If you follow the copper line for the compressor HP head back to the tank you will see that the line screws into the check valveand the check valve screws into the tank. Bleed all air from the tank,remove the 1/4 line and the 3/4 line from the check valve. Then unscrew the check valve. Install a new check valve and connect the lines. Problem solved.
Apr 30, 2011 | Ingersoll Rand 2340/2475 Electric Air...
My compressor builds up to preset pressure just fine. My problem is after the pump shuts off, the air leaks down at the valve on the pressure switch. I have changed pressure switches and still have the...
This switch is only rated for up to 2 HP at 240 volts and 1-1/2 HP at 120 volts. Using 3 phase power, you can go only up to 3 HP. That would not cause the problem that you discuss, but it is an unsafe condition.
Some Square D switches have a small relief valve so that when the compressor reaches pressure, the motor stops and the relief opens and lets pressure out of the compressor cylinder. Does your switch have that and might that be what is "leaking"? I believe that if the compressor is tight that the leak would stop rather quickly.
Dec 11, 2010 | Square D 9013FHG14J52M1X Air Compressor...
Air leaking out the top..not building any pressure
Sounds like theres either a piece of debris in your pressure switch where the 1/4" line enters it. Or you have debris stuck in your check valve or a bad check valve. Remove the pressure switch line and check valve and try cleaning the valve and the switch where the line was disconnected. with solvent and compressed air. Unfortunitely you'll need someone elses air source.
Aug 08, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Leaking air
When the Pressure switch shuts off, the little air valve in the pressure switch vents the copper line from the compressor, to blead the pressure from the compressor so it's easier to start the next time. If it continues to leak, the check valve between compressor and tank must not be holding.
Jul 16, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
T30 model 2340 is leaking air from around the pressure switch when compressor shuts off. This will last for a few minutes and then when compressor starts and stops it will do it all over again
you have a broken valve. follow the small 1/4 line that comes from the pressure switch, and if it goes to the discharge line from the pump to where it enters the tank, there is a large hex fitting that it is hooked into. drain all the pressure off the tank, and remove the fitting from the tank, this should be a check valve and is stuck open.
If the small line goes to an innerstage cooler between the large and small cylinders, then you have a broken valves in the cylinder head that need to be rebuilt.
Jan 25, 2010 | Ingersoll Rand 2340/2475 Electric Air...
A DIRECT DRIVE COMPRESSOR & THE PRESSURE SWITCH IS FAULTY
STOP! Your pressure switch is doing what it is supposed to, but the tank check valve is leaking. This valve is usually at the tank where the line from the compressor head enters the tank. The small tube line from the pressure switch probably also goes to this valve. You'll need to clean or replace it.
Nov 14, 2009 | Air Tools & Compressors
Makita MAC2200 runs fine (with new Manifold Switch and repaired power cord) but there is an air leak under the new manifold switch that seems to be a feature of the switch. When set to automatic, the...
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Mar 18, 2009 | Makita Air Tools & Compressors
Square D 9013FHG14J52M1X Air Compressor Pressure Switch Logo
395 people viewed this question
Top Square Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Square Air Tool and Compressor Expert? Answer questions, earn points and help others
