Question about Xerox WorkCentre XE90FX Laser Printer
My system says there is a paper jam (E#) but there is no paper anywhere inside the printer??
  • 7 more comments
  • thunderva82 Mar 25, 2011
    I have already done that and even taken the machine partially apart..Please read my description again..THERE IS NO PAPER IN THE MACHINE... I have even used a flashilight in there..THERE IS NO PAPER STUCK IN THE MACHINE!!!!!! I even blew all the dust out
    Good question..I aded a new ink cartridge..and it printed fine for several pages..then a few days later I printed again and after several pages it jammed and I pulled the stuck page out from the bottom, and after that jam and clearing, the system showed there was still a paper jam error after it had been cleared..
  • thunderva82 Mar 26, 2011
    I had to go to work for awhile so sorry..hope you can still help me..I do have the PDF fiule and it says nothing in it that I can remember about cleaning, regarding this error...only to remove the paper from the unit, which was done..I also blew all the dust out of it today as best I could and the error code remains and the system still will not work..
    I cleaned toner cartridge with the paper roll as explained in the manuel and no success..??
  • thunderva82 Mar 27, 2011
    I appreciate you trying to help me but there is no paper and there is no paper fragments that I can see anywhere in this unit and I cannot get the machine to reset itself..any other ideas?
    Thanks anyway I appreciate your time.
  • thunderva82 Mar 28, 2011
    I appreciate you trying to help me. I did all the things on the list and now I have a C1 error..any ideas?
    Thank you so much for sending me the right info to try..I did all those things you suggested and i think doing all those check points released something that was stuck and my printer is now working properly..I was ready to junk it..Thanks so much I am very satisfied...Deanna
    yes I was satisfied that the printer is now working after trying everything on the list you sent me.
  • 624 Answers
Hello and Welcome to FixYa Sir.
Paper jam Error is very Generic issue, it usually starts due to a real Jam and remain there even after removing it. You need to check a number of things to get to some solution. I'll advice you to follow all the instructions given on the links below. Even if you have done it already, do them again precisely, you may be missing something.
Kindly navigate to the link according to the Error you are facing, and follow the instructions there.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Posted on Mar 27, 2011
  • 384 Answers
Hi There and welcome to Fixya.
I have the following possible solutions to this problem involving E# Paper jam error. You've possibly tried these but it's definitely worth double checking since even a tiny fragment of paper can cause halt in printing operation.
E1 jams at the Paper tray:
  • Remove the lever at the right of paper tray
  • Check and remove paper/paper fragments carefully
E2 jams at the workcentre:
  • Push the front door latches on each side, pull it towards you and lift the toner cartridge handle.
  • Remove the toner cartridge
  • Do not touch the green surface of the drum
  • Carefully remove the drum
E3 jams at paper exit area:
  • Push both latches and open the front door
  • With the door partially open, check and remove all paper/paper fragments
I certainly hope this is a help to you. For your convenience, you can access the complete user's guide through the below link :
XE90fx
Thank you for using FixYa.
Posted on Mar 26, 2011
  • Arvin Antonio Mercado
    Arvin Antonio Mercado Mar 27, 2011
    My apologies for the delay and for not being able to help you out entirely. I think it's best to contact xerox's support technicians on this since the problem may be internal that requires a certified tech to resolve.
    Here's their support site for your reference and other information :
    http://tinyurl.com/4esrekh
    Thanks again.
  • 2,632 Answers
Welcome to Fixya. To verify this is E3 Jams at the Paper Exit Area. Please follow the steps below to fix the issue you can also refer to the manual below about your XE90FX. Please refer to page 6.4 or 44 of the pdf file.
1. To Reduce the pressure on the paper, Open the front door by pushing in the latches on the both sides of the door.
2. With the front door partially open, remove any paper that may be in the paper exit area.
XE90FX Manual
If you have questions please let me know. Thanks for using Fixya.
Posted on Mar 25, 2011
  • Rofel Lantican
    Rofel Lantican Mar 25, 2011
    May i know before it happens what are the changes made to the machine?
  • Rofel Lantican
    have you tried to clean the system. The tone and drum cartridge? Basically e3 is usually fix by using the instruction manual.
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
Paper Jam error
unplug the printer and then restart your computer and plug the again. if not work, please try cleaning some part of the printer inside by blowing air.
Jan 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Tip
Steps to clear paper jam.
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Says paper jam but can't find any paper anywhere
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Paper jam check drawer two t640 printer
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Aug 20, 2008 | Lexmark T640 Laser Printer
False paper jam message
PRINTER TRY TO PICKUP THE PAPER,BUT PRINTER CAN'T.THE CAUSE OF THIS ERROOR IS FAULTY PICKUP ROLLER & SEPRETION PAD.SOME TIMES PAPER TRAY CAN NOT BE OPEN WHEN WE PUSH IN,IN THIS CASE PRINTER SHOWS PAPER JAM
VIJAY THAKUR
Jul 01, 2008 | HP LaserJet 2430dtn Printer
Printer
2.
3.
4.
5.
6.
7.
Jun 03, 2008 | Office Equipment & Supplies
Xerox WorkCentre XE90FX Laser Printer Logo
119 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
