Question about Directed Electronics A1004 Car Amp
I disconnected a directid a1004 car amp from a boat to a car. the esp indicator light is blinking red abut three times in a row and the amp does not turn on. it worked when it was disconnect. please help
    New Friend:
Amp on red light on and green light on no sound is that surpose to be
Posted on Jan 21, 2014
  • Nigel Wayne
    Nigel Wayne Jan 21, 2014
    amp on red light on and green light on no sound is that surpose to be
My Sony Bravia TV - Model #: kdl-52z5100 no longer powers on. There's a red light that blinks twice whenever I attempt to power it on. Please help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jul 30, 2016 | Sony KDL-52Z5100 LCD TV
How do I stop the anti-theft device red blinking light? Car is off and locked and from the window can see the red light blinking.
the red light drain 0.001amp. from you battery.need 1000 hour to drain 1 amp. test the battery if is any good. do drain test on the car.rust and short will drain battery overnight.after market equipment,light in the trunk or glove box, under hood light etc. disconnect the battery and install amp meter. do the drain test. your computers uses 0.2-0.4amp when sleep.anything over 0.5-.6 amp is bad. after you connect the amp meter give 1min. to turn all systems to sleep mode.Is normal the first minute to be high drain.
ones you know something is wrong disconnect the fuses one at the time and note if any changes. if the fuse you disconnect turn the amps low note what system is connected to the fuse and you will know were is the problem
Oct 24, 2014 | 2003 Oldsmobile Alero
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
What would cause the power light to blink red and the tv will not turn on
three times red light blink mean DC Alert which is related to system in internally & some time sound ic problum
Jul 12, 2014 | Sony KDL Televison & Video
Red light blinking
blinking of red light indicates that fault in main board or related boards. you need to open back cover remove each cable connected with main board one by one & put on tv after each cable is disconnected. if red light stops blinking on disconnecting any of the cables, that means related board is defective, if it does not stops blinking, check the power supply is generating proper voltages. if it is ok that means the main board is defective.
Sep 26, 2011 | Panasonic TC-32LX24 32 in. LCD TV
Hi, I have an LXi heaterthat keeps kicking off! On
This usually indicates an ignition lockout...The heater tried to fire but either didn't fire or a flame was not detected. Check and ,ake sure ignition is good, gas valve is opening and make sure all grounding is intact..
Jul 30, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a Directed D2400 amp and my red ESP is on
ESP ties the amp into your vehicle's alarm system. If the amplifier is working normally you can ignore the light. Note that this is NOT the protection LED for the amplifier.
Nov 04, 2009 | Directed 2400d Car Audio Amplifier
Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Directed Electronics A1004 Car Amp Logo
77 people viewed this question
Top Directed Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a Directed Electronics Car Audio and Video Expert? Answer questions, earn points and help others
