Question about ViewSonic N3251w 32 in. LCD HDTV
It just wend dead while watching, i unplugged it and then pushed the power button , a green light tryed to come on but went back out.
  • 11,361 Answers
Please see pictures here;
http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20N3250W/
Also check for bad caps with bulging/leaking tops.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Jul 08, 2011
    Sergeant:
    Champion:
  • 431 Answers
Bad q8 npn trans. and zd 8 16v zener diode in pwr supply
Posted on Jun 17, 2011
No power when turned on - light green on back - no lights on motherboard - no fans
sunny,try with a other powersupply if possible.
faulty PSU are often the cause.
Jul 13, 2013 | HP Media Center m7250n (ED842AA) PC...
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
Xbox not coming on what to do
hi, what do you mean by ti wont come on
is it totally dead or do you have any red lights lit up on the power button
check the power brick and when you switch it on at the main it should have an orange light on it then watch the orange light as you press the on button it should turn green to tell you it working or flash red if it has a fault let me know ok.
try unplugging all the leads out of the back of the xbox and switch the power lead off at the mains. then plug all the leads back into the xbox, no the power lead can be a bit funny at times so push it in then try forcing it in a bit further sometimes the connections get weak and you need to push it in further so try this pushing it in as hard as you can.
then switch it on at the mains then try pressing the on button if the on button still wont do anything try pressing the eject button as this will also switch it on and open the disk tray
if its totally dead or you have any red lights lighting up tell me how many then i can assist you further ok
let me know how you get on or if you need further assistance ok
please rate this solution and leave a testimonial as i have pages of unrated posts as users forget to leave a response, thanks
Dec 08, 2010 | Microsoft Xbox 360 Console
My xbox not coming on what to do pls help me
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
Dell 5160 orange light
I have never found hibernation to work successfully.
Disable hibernation if you ever get it started.
Try reading the manual on how to restart for hibernation, press "spacebar", "enter" or something.
Oct 10, 2008 | Computers & Internet
F32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
ViewSonic N3251w 32 in. LCD HDTV Logo
88 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
