I have and overheated promblem with my 1993 jeep chorekeee country . What can it be
    Brigadier General:
  • 4,736 Answers
Chris, unfortunately, it can be caused by a host of things: Low radiator coolant, a clogged radiator or engine thermostat, a leaking coolant hose, faulty radiator cap and the list goes on and on. However, it's best to start with the easy things, like Low Radiator Coolant, because that's easy to check. Just make sure the engine has cooled before removing the radiator cap. While you're waiting for it to cool, look in the plastic coolant overflow tank. If there's no coolant in it, more than likely, when you remove the radiator cap, you'll see the coolant level is low. However, if it appears full, it may be that the radiator is clogged and needs to be flushed and new coolant put in. If the coolant in the radiator looks like old coffee grounds, nine times out of ten, the radiator is clogged and seriously needs to be flushed.
Also,pull the oil dip stick and look at the color and consistency of the oil on the dip stick. If it's a milky color, your engine has a blown head gasket and that's where the coolant is going.
As I said before, it can be a "host of things". Just start with the simple ones first.
Hope this helps you in starting to troubleshoot the problem If so, please leave me a good rating. Thanks!
Posted on Mar 25, 2011
Where is the ignition switch on 1993 jeep cherokee country
I use and I'd recommend you register for free at www.autozone.com Once registered you'll have access to repair and shop manuals for virtually any car or truck. All the data and diagrams you need now or may need in the future will be a couple of mouse clicks away.
Jun 11, 2011 | 1993 Jeep Cherokee Country
Where is the speed sensor located on a 1993 Jeep Cherokee Country?
Its should be on your left side of your transmission And hope the picture below can give you an idea. Good luck tgv1501_3.jpg
Dec 07, 2010 | 1993 Jeep Cherokee Country
Antifreze leak/overheating by pullies in front of engine by waterpump
Hello, nydbcoach and thank you for asking your question on Fixya!
Here is a simple process that will walk you through a few steps that will pinpoint the overheating problem on your
1993 Jeep Grand Cherokee, without even using any tools. It has helped millions of people, and I am certain that it will help you, because I wrote it for people in your exact situation.
How to diagnose your overheating
Get more great money saving tips and tricks about your vehicle from: twitter.com/acoates23234
Thanks for the vote, and good luck!
Nov 22, 2010 | 1993 Jeep Grand Cherokee
Need to find location of the crankshaft position sensor on a 1993 jeep cherokee country
It's mounted on the transmission flange where it bolts to the engine block.Left hand side.Just above the middle.(On a clockface description,About 10 o'clock)Hope this helps
Oct 02, 2010 | 1993 Jeep Cherokee Country
Overheating
Typically its either the thermostat or radiator fluid issue. On mine, I flushed the radiator twice, changed out the thermo and then inspected it for a while. Still overheated. I noticed the auxilary fan wasn't coming on, fuses were good, thermo is good. I just hotwired the dang thing to a switch inside. Works great. Engine stays cool now.
Aug 19, 2010 | 1993 Jeep Cherokee Country
Need to know what trouble code 55 is on the 1993 jeep cherokee country 4.0 l
code 55 is the "end" code showing that the diagnostics have been completed. If you had no other codes, then there is nothing stored as a fault in the computer.
Oct 21, 2009 | 1993 Jeep Cherokee Country
Blower motor jeep cherokee 1993
Review the Jeep XJ Service Repair Manual (page 24 for Blower Motor Fan replacement).
I hope help you with this. Good luck (remember rated this help).
Oct 01, 2009 | 1993 Jeep Cherokee Country
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
