Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
My Barracuda skirt keeps folder under and stops the barracuda working. The skirt looks fine. Its approx 2.5yrs old.
  • 106 Answers
This happens when the skirt gets thin. A new one will definitely solve the problem.
Posted on Mar 27, 2011
Barracuda web filter 310 was reset now, I have a backup .bak file how can I restore this file?
if the web filter recognises .bak files you should be able to restore it with that if not you can try to rename the extension to what the web filter recognises but this might make the file unreadable. First make a copy of the file so that you do not lose the original format. Best thing to do is write down your network configuration information and keep on hard copy so that in the future you will have a reference to fall back on. I know hard copy yuck but sometimes it is needed. There is software out there that you can map your network setup showing all devices and there settings.
Jan 07, 2014 | Barracuda Networks Computers & Internet
Barracuda head keeps coming unscrewed from hose
Try wrapping white plumbers tape around the threads 3 or 4 times and then screw back together. That worked wonders for me when i had that problem.
Apr 05, 2013 | Zodiac BARRACUDA G3 IN-GRND CLEANER
How to unblock youtube from pacyber
Hello. i do Pacyber and i figured out how to safely unblock the barracuda ****. You click on the little windows button in the bottom left of the screen. From here you will need to type in the search bar located at the bottom the the window that comes up. Type in RUN and click on it. From here a box should come up and type in services.msc. without the period lol... and once you have typed that in you click ok. a lot of **** will come up. look for Barracuda WSA Service and Barracuda WSA. once you have found these you must double click it ethier one. once you have done that make sure you are on the general tab of that window that opened. Look in around the middle of the page and you will see Start up type. it will say automatic or anything EXCEPT disabled. click on that thing that should say automatic or manual. put it on disabled to BOTH Barracuda things and also make sure to STOP them but going under the start up type. it will be listed start stop pause and resume. click STOP . Do these steps to each of the Barracuda things only. Im sorry if this was difficult to follow it was my first tutorial and im only 14 so dont get a big **** about it. let me know if it was helpful or if it didnt work. this will enable you to use ANY website you disire. HAVE A GOOD *** DAY
Oct 23, 2011 | youtube.com
My Barracuda keeps stopping after a while. Did the suction test and it is reading 3. Is this too low to keep it running?
3 is perfect. The diaphram is most likely the problem. If the diaphram is more than say..9 months old it can get bloated and not function properly. The only other problem could be is if the cleaner is a few years old the foot pad could be worn out and the cleaner can **** itself to the pool and not move. Most likely the diaphram though.
Nov 22, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Iraq.comBarracuda 330 keeps dropping VPN tunnels - any ideas?
I have been having the same issue. I make one change on one tunell even and all of them go down. I have called Barracuda and they look at logs but nothing has ever been resolved. I have Cisco WRVS4400N on the other end of my 12 VPN's. Why they have such a hard time talking and communicating I don't know but it is very frustrating.
Nov 02, 2010 | Barracuda Networks Barracuda Link Balancer...
JUST CANT KEEP IT RUNNING , PUT IT IN THE POOL STARTS RUNNING THEN STOPS ????
Usually caused by low pool pressure at the filter. The barracuda works best between 12 and 18 psi. I have seen it work as low as 10 psi. The problem i have found is the intake lines have some debris in them that causes the flow to lessen, Best thing to do is pressure check your intake lines and to clear any debris. I had this problem for several weeks until I cleared all my lines, It now runs beautuful at 12 psi on filter gauge
Aug 17, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Harddrive
Hi, Looks like it will be a motherboard issue not Maxtor (ATA) and Barracuda (SATA) combination. So the question really would be if your motherboard would accept and recognize the Barracuda SATA. Post back with your motherboard details, (brand/model/version). Kind regards.
Aug 30, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
345 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
