Question about Brother HL 5250DN Laser Printer
Now what? All the cards are clear...still wont print
  • 101 Answers
Very hard to diagnose without seeing the object...
1) try inserting a A4 paper via the front paper feed, see if that works.
2) take out the toner and see the condition of the internal paper path
Posted on Aug 04, 2008
Trying to print on clear pvc keeps acting like no card is there says card not fed , i put in non clear and prints just fine
Go to the printer driver setup screen and choose clear . The paper out sensor will then be bypassed and the printer will pick up the clear sheets.
Mar 12, 2016 | Office Equipment & Supplies
Unable to clear missing/damaged cartridge msg even after cleaning.
why does my printer say ink cartridge missing or damaged ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Aug 8, 2012 - 10 posts I recently changed my ink cartridges ( colors and black) and now it says that the ... why does my printer say ink cartridge missing or damaged? ... cartridge from Office max and it still has the message and I am unable to print. ... Remove the cartridge and take a close look at the tiny circuit card on the section ...
Nov 30, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
Why my Fargo ProL Printer is not printing my Card Back Clear?
Hi, Its not clear what you are saying.
First, what kind of ribbon are you using for printing, and what kind of lamination ribbon are you using?
what are you trying to print on the front and back?
Feb 17, 2015 | Fargo Pro L ID Thermal Printer
Evolis Pebble 4 with a gold monochrome ribbon. Printing on pre printed blank cards. The print is not complete, almost as if there is not enough pressure on the card as it is printed. All the letters are...
Make sure you have selected gold ribbon in printer graphic properties.
Also you can try changing luminosity and treatment options in graphics under Advanced setting.
Check for print on a white card also as problem may be due to card surface also .
You should cklean print head also at once.
Oct 04, 2010 | Evolis PEBBLE 4 Led Card Printer
When i try to print card it causes a paper jam all time. it used to print card but not now i feel this is a grat pity cause its a good printer. It doesnt matter which place i put card it just will not lift...
fter a clear card option has been installed in a Datacard card printer SP35 Plus or SP55 Plus, a card jam error my occur. The same error may occur when after replacing the main control board.
To clear this error the printer will need to determine the sensor type. For the printer to recycle through and make this determination, a power on test card is required using the appropriate clear or opaque card type to force the firmware to redetermine the sensor type. Each time the card is changed from clear or opaque to the other type, a power test card will be necessary to redetermine the sensor type.
For additional information about Datacard printers currently on the market, SP25 Plus, SP35 Plus, SP55 Plus and the SP75 Plus, contact our id card experts toll free at 888-485-4696.
Nov 19, 2009 | Epson AcuLaser C4100 Printer
How do you print cue cards
Do you mean "how do you make cue cards?" because printing them is the same as printing anything else. And just to be clear, what do you mean by 'cue cards'?
Nov 10, 2009 | Apple iMac G5 Desktop
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Wont fire up, just reads E3
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Kodak 5100 wont print after paper jam
If you cant get the jam cleared from the back or the top access door you could exchange it from where you got it. Or try and open it up and fix it yourself but that will void the waranty and you wont be able to exchange it. Or you could check the yellow pages for a PC/printer repair shop. But I mostly recomend trying to exchange it from where you bought it.
Feb 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Brother HL 5250DN Laser Printer Logo
49 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
