Question about Hunter Ceiling Fan Remote Receiver 85112-01
We need a split canopy for a ceiling fan - Hunter Ceiling Fan Remote Receiver 85112-01
4 Suggested Answers
  • 351 Answers
SOURCE: The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Posted on May 06, 2010
  • 57 Answers
SOURCE: How does the receiver of
if you look at the mount bracket where the ball of the fan fits in to it should fit right above the ball in the mount bracket and if it can fit loose in the canopy thats ok to just long as ou can get the bell housing back up
Posted on Jan 23, 2011
SOURCE: Trying to remove the Hunter
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Posted on Oct 01, 2011
How do I remove fan mounted close to ceiling?
There should be side mounting screws in the canopy which attach it to the mounting bracket. The screws are removed to allow the canopy and motor assembly to drop down free of the mounting bracket. A convenient hook is provided to allow wires to be disconnected.
Oct 23, 2015 | Hunter 20461 Brushed Nickel Ceiling Fan
Fan is 52" hugger style. I need the mount between the fan canopy & the outlet box in the ceiling.
Most likely need to contact manufacture of fan. What make/model of fan do you have?
Jun 19, 2015 | Dryers
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
How does the receiver of the Hunter model 21871 ceiling fan attach to the canopy? There are two things on the receiver that seem as though they should connect to the canopy with slots but no slots in the...
Jan 23, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Trying to remove cover that houses the ball and pipe that hangs the fan. There is no screw to hold the ceiling mount cover to the ceiling mount. I tried pushing up and twisting but no luck. Could someone...
There should be a couple of small screws at the very top on the side of the canopy...you will need to loosen these a few turns and then turn the canopy and drop it down...
This link will help you they had the same problem as you...
http://www.askmehelpdesk.com/electrical-lighting/hampton-bay-ceiling-fan-removal-25673.html
heatman101
Apr 29, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Mar 02, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Need to uninstall the fan as it has become a bit loose from the ceiling
The first thing to do is loosen the ceiling canopy, there is usually a couple screws at the top edge of the canopy. then you want to disconnect the wiring, do not forget the green wire also. then depending on the mounting type, it may just lift out, one side of the mounting bracket has a space to allow the ball to pass thru. Or you may have to unscrew a couple mounting screws at the ends iof the mounting bracket
Feb 06, 2010 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
142 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
