Question about Dewalt DW983K - 2 heavy - duty XRP 1/2" 14.4v cordless drill/driver kit
My trigger for my dewalt 14.4v cordless drill doesn't always kick in when used in short bursts, anyone have any ideas what's wrong with it?? thanks in advance!
  • 60 Answers
I have the same exact problem with my ryobi impact driver. I checked on my warranty first and i still have it, next I have to find the time to get it to a place so they can repair it under warranty. I'm pretty sure it's one of the boards that's connected to the trigger that's broke. Check your warranty if not check ebay for the piece. hope it helps!
Posted on Mar 25, 2011
I have 2 dewalt 18 volt hammer drills. The first one died about 2 years ago. The trigger seemed to mess up. I took it apart several times thinking I could fix it. I finally gave up on it. It's laid...
Hi, Take the drill apart using a star driver. When taking the chuck assembly from the yellow section have the drill chuch down to stop bits falling out. Once handle is apart popout the triggger assembly. Remove the two power leads from the assembly. Try a direct connection to the battery (polarity doesn't matter. If the motor goes it means that the trigger is U/S. Put a tester across the terminals (either set). You may have a short (as I had). It appears to me that the trigger is not user servicable. I used one from a DeWalt recip saw with a mod on the reverse lever. Works well.
Good luck.
Mar 15, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do you know if the trigger is bad? getting dc volts to trigger but nothing out when I press it.
It's not unusual for Dewalt triggers to go bad and it appears you have correctly tested the trigger. You can test the motor by wiring it directly to the battery but hold on to it and only give it a short burst of power so it doesn't spin out of the case. Dewalt triggers are fairly easy to find online but shop around, they're not cheap.
Jan 26, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt cordless 12v drill, 3speed model...spinning problem
Sounds like your brushes are either damaged or the armature is failing the current. Remove the brushes first and inspect them, that is where your arcing is coming from. If the brushes appear ok, your problem is in the armature itself. Regardless of low use, if you store the unit with the battery attached, there are issues with the current draw while stored.
Jan 17, 2010 | Garden
DeWalt DW972 cordless drill has intermittent variable speed trigger. (Battery is fine, recently replaced) How can I clean the variable resistor in the trigger or must replace the whole trigger module?
have to replace whole trigger assembly.
worn brushes in the motor can also cause intermittent function, if you havent already checked those. i'd replace those first if they have never been replaced or look worn, broken, cracked, or if springs seem worn.
Dec 14, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
DeWalt cordless drill DW926. I can't get the
Turn your drill speed selector to "1" and put drill direction in reverse. Hold the outer end of the chuck and push the trigger. Should come loose.
Nov 18, 2009 | Dewalt Cordless drill/driver kit 9.6 volt...
Part # of the Voltage Regulator in Dewalt Drill
The part number for the switch is 152274-19 . Dewalt doesn't sell the individual parts for the trigger assembly. It really depends on the manufacturer of the trigger at the time of production. You should be able to locate a company name on the side of the trigger switch assembly. It may be Marquardt. I am unaware of any way to order individual parts for these type switches. If you find a source please post.
Oct 02, 2009 | Dewalt DW983K - 2 heavy - duty XRP 1/2"...
Need procedure to replace trigger on dewalt cordless drill
I have been rebuilding drills for 10 yrs and have installs hundreds of switches. This is not an issue in a switch like this. If it was, the energy from the motor working should damage the switch more than the static from your body. I would not be concern with it.
Mar 28, 2009 | Dewalt DC759kar heavy - duty 1/2" 18v...
Dewalt DW983K - 2 heavy - duty XRP 1/2" 14.4v cordless drill/driver kit Logo
96 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
