I cant enable my wifi ,fn key f8 not working - Computers & Internet
    Scholar:
  • 84 Answers
You can re-enable your wireless card through the Device Manager window.
Hold Alt and double click on the My Computer icon on your desktop. Select Device Manager and then scroll down the list until you find your wireless card. It should be listed under Network Adapters. Right click on and it select Enable. That should bring your wireless back up.
Posted on Mar 25, 2011
Lost my wi-fi on my toshiba l455
It's common that the switch that enables/disables wifi gets hit accidentally. I believe, on your model, that pressing the Function Key (Fn) and the F8 key simultaneously is the way to turn wifi on and off.
Aug 13, 2014 | Toshiba Satellite L455D-S5976 Notebook
Restore FN + F8 key to reactivate Wi-Fi on Toshiba Satellite L500
My laptop didnt enable the wifi with the fn+f8 key.
I even reset the cmos and nothing.
Then I went to toshiba drivers website and after installing the "thku" "toshiba hotkey utility" the fn+f8 start working and enable/disable the wifi. It now shows a popup windows when I press the fn+f8 key.
Before the wifi led was always off. Windows detected the wifi device but nothing on the wifi available list.
Now the led is always on, starts orange when I turn on the pc and blue when connected.
Oct 05, 2012 | Toshiba Satellite L500 Series Notebook
Cant find the wifi switch
Press the Fn + F8 on the keyboard.
The Fn key is located at the bottom right corner of the keyboard and F8 (you'll see a small antena icon with F8) is at the top center.
(See Fig1)
Fig 1 - Keyboard Layout
Regards,
Shrey
Jun 05, 2011 | Toshiba Satellite L500 Series Notebook
I can't turn the wireless on?
Hi - With some laptops there are a few places you need to check to see if the wifi is enabled.
1st - check to see if you have a wifi switch. Usually found on the front at one of the corners or on the side of the laptop. Make sure the switch is "On". It may also be a button on the top of the keyboard.
2nd - make sure the wireless is "enabled" in your OS. If you are using windows, go to Control Panel then Network Connections. Make sure that where the wireless card is shown as a connection it says enabled.
3rd - If the second does not work sometimes certain wifi cards will use their own utility or program to operate the wireless card functionality. This can most likely be found in All Programs. Hard to say what it would be called unless we know the type of wifi card. Try the 1st two options, if they dont work, try this. Find the program, open it and make sure that it is enabled from there.
If none of this works, try restarting the laptop.
Mar 01, 2011 | Toshiba Satellite L500 Series Notebook
Please help me . How do you connect ASUS X58L to wireless so i can use away from home without my router. ?
Hi
Have you enabled your wifi switch or key
and does it show you down in the right hand side of your screen that wireless
networks are available
if it is not enabled then try to press the FN+F2 or FN+F8 or FN+F11 or sometimes
there is a push or slide switch to activate the wifi
Feb 26, 2011 | Computers & Internet
I cant find the Wifi switch on my toshiba L505d. the only thing I see is what looks like a volume know next to the wifi led but when I turn the knob it does nothing
To enable or disable wireless communication, use the Hot Key
Fn+F8.
To use the Hot Key Cards:
1 Press and hold the Fn key.
The TOSHIBA Cards appear along the top of the screen.
2 Click the Card for the system function to be modified.
The selected Card is displayed full-size with its available
options below it. All other Cards are again hidden from view.
3 Click the desired option.
To use a Hot Key Card using a hot key:
2 Press the hot key associated with the desired function.
The associated hot key card appears at the top of the screen
with its available options below it.
3 To cycle through the displayed options, hold down Fn and press
the hot key repeatedly. Release the Fn key when the desired
option is selected.
NOTE
May 30, 2010 | Toshiba Satellite A215-S4747 Notebook
I have a Toshiba Satellite L500 and the wifi won't work. Have read other forums and apparently it's a faulty wifi card problem. How can I get this fixed without shipping it around the world. I'm in the...
  • Hi, I hope that you are still monitoring this "Website" for a "Solution?" I might be able to help you. Follow these instructions, and we will be able to get you connected. I'm familar with the "Computer Model" that you have, so lets get started! First, click on the (Start button) to open the "Start Menu," next "Type" in the (Search box): "Toshiba." In the Program list; find the Toshiba Application Installer, and "select" to open. The Driver Installer "appear." Now you can select, and install the Wireless Drivers; click on the "Next" button, in the ("choose an item...") window, select the By Name: Wireless LAN Driver, and to the (right), click on the "Install" button. To finish click on the "Exit" button. Note: Follow all instructions thereafter exactly. "I hope this help you, let me know, if possible"
Jan 15, 2010 | Computers & Internet
I can not work out how to turn the wireless conection on.advent 7070.what keys do i use
To enable the Wireless LAN Fn + F2
usually the wifi function key has the universal antenna symbol with radio waves emanating from it.
The manual says the other hotkeys are:
Fn + F2 - Wireless LAN
Fn + F3 - Standby
Fn + F4 - External display
Fn + F7 - Reduce brightness
Fn + F8 - Increase brightness
Fn + F9 - Play / pause media
Fn + F10 - Stop media
Fn + F11 - Media previous chapter
Fn + F12 - Media Next Chapter
Fn + scroll - Scroll Lock
Jan 14, 2010 | Advent Netbook
Cant switch on wi-fi what key function is required
Look for the FN key and another key with a Wifi looking symbol on (three lines normally).
Press the FN key and then the second key.
This should turn on the Wifi or launch an application enableing you to manage the conectivity.
Sep 27, 2009 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
