Question about TruTech LMD-5702RT Portable DVD Player
I need to purchase another cord for the players the one with the male and female ends where can i purchase this? /
  • 60 Answers
Almost all cords can be purchased at a local bestbuy or electronics store. If you knew the exact name of the piece your looking for you can buy it cheaper online. Most of the time people have extra cords laying around the house all the time. Try searching around before you buy.
Posted on Mar 25, 2011
How do I charge this?
You've probably figured this out by now, but their should be a thing that looks like the male end of an electrical plug in an odd place. Get an extension cord and place the female end over that male end and plug the male end of the extension cord it into the wall overnight.
Jul 05, 2012 | 450 Amp Battery Jump-Starter
The hose connection nipple is smaller than the garden hose-connector and leakes. Do I need a special hose or will putting plumbers tape on the nipple stop the leak?
No, that would probably leak too. What you need to do, is go to your local hardware store or home center (Plumbing Dept) and purchase a female to male connector. The female end is to connect to the unit's male hose connection and the other (Male) end, needs to be the same size for garden hose connection. Make sure that you use an appropriately sized washer for the Female end.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Danby DDR5009REE Dehumidifier
I have recently purchased an atari 2600 that came with no rf cable. I understand that using the female phono to male f adapter will work to hook it up, but this leaves me needing to buy the phono cord...
Yes, I know this works because I have done it. I believe both types of cable are the same impedence but different ends so any combination should work. Cheers.
May 14, 2011 | Atari 2600 Console
It looks like the plug on the blower melted slightly now the blower doesn't work can it be repaired
Parts are few for these machines (all I found was the blower tube). That being said, you can carefully cut off and remove the faulty male plug and replace it with a repair piece like you would add onto a damaged extension cord (outdoor type). They are made of plastic, but are fairly sturdy. Just carefully cut away the old male connector (the shrod isn't really necessary and remove the wiring from it. After purchasing the male-type plug replacement, rewire it and you will be set to go. To eliminate the male cord and the female end of the extension cord you will use from pulling apart when in operation, just loop the female end cord around the cord of the blower and it will hold in place.
Mar 19, 2011 | Toro 51585 Power Sweep 7 Amp 2speed...
Power cord will not light up where it is inserted into the laptop unless you hold it steady. It will not charge unless it is held in a certain position. Is the male part on the cord bad or is it the female...
You'll need to get another power cord that is identical in power and polarity and plug. One can buy a generic power supply from Walmart that will power most laptops or Radio Shack (Walmart is probably cheaper).
Once the new power supply is obtained, try it, and if the same thing happens, then the problem is in the female plug connection to the motherboard of the Compaq Presario C762NR Notebook.
The Notebook will have to be disassembled and the female plug connection to the motherboard will have to be replaced.
If the male plug end shows any fraying or excessive bending signs, then I would definitely replace the cord.
It is difficult to determine which is bad, the male or female part without changing the easiest part... the power supply.
Also, you could go to your local Compaq dealer and ask to plug in one of their power supplies to your computer and tell them the problem that you are having, determining which is bad, the male or female part of your power supply.
Good luck on this repair.
Aug 17, 2010 | Compaq Presario C762NR Notebook
Everything is unplugged, I just need a wiring schematic to plug everything back in
Does the motherboard have a "purple" socket?
Does your keyboard have a "purple" end?
If so, join the male to the female,
rotating the male until the stiff pins line-up with the holes.
Does the motherboard have a "green" socket?
Does your mouse have a "green" end?
If so, join the male to the female.
The end on the monitor's video-cable has 3 rows of pins;
there's only one place on the computer with 3 rows of holes.
Notice that the sides of the male are tapered,
so that it only fits ONE way into the female.
Similarly, the female end on the power-cord is tapered,
so that it only fits ONE way into the back of the computer.
Note where it connects -- there may be a "rocker" switch,
with a '1' and a '0' on the ends of the rocker.
Press the '0' end down before you reconnect everything.
Press the '1' end down after everything has been reconnected.
Do your PC speakers have a green tip?
If so, then connect the male from the speakers to the green female socket.
Sep 14, 2009 | 3Com Computers & Internet
I have a pair of JBL Platinum Series computer speakers that came with a Compaq Presario Desktop. I've since purchased a Dell Dimension 9200 Desktop and want to use the JBL speakers with it, but the power...
Go to the family dollar they have those wires that have both male ends. It is meant for ipods, and mp3 players so you can connect them to modern stereos that have inputs like that. I bought sevel of them because they are very usefull for about a few bucks each.
Apr 15, 2009 | Belkin COMPONENTS Computer AC Power...
TruTech LMD-5702RT Portable DVD Player Logo
110 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
