Question about kawasaki Garden
Cutter switch wires on the wrong terminals - kawasaki Garden
Tip
How to Wire On-Board Marine Battery Chargers
Battery chargers are wired into a boat's electrical system. Wiring the charger to a battery switch permits the charging of the individual batteries or battery banks. The switch can be configured to charge both batteries or battery banks at once. Mounting the charger in the vessel keeps the charger where it will do the most good--connected to the batteries. This is useful if you are stuck with low batteries and need a recharge. Power from a generator, shore power or even AC power from another vessel can be used to get you going again
Instructions Things You'll Need:
Battery charger
Battery switch
Battery cable (sized)
Cable cutters
Razor knife
Battery terminal lugs
Lug crimper
Terminal kit
Terminal crimper
Hammer
Step 1
Mount the battery switch with the mounting kit provided by the manufacturer. The switch should be accessible but close to the battery or battery banks.
Step 2
Mount the battery charger in a location that will be accessible but protected from the elements. Mount the charger close to the battery switch to reduce the size of the charger leads.
Step 3
Connect the battery cables to the battery switch. Mount the battery cables onto their corresponding terminal studs on the battery switch.
Step 4
Lay out the battery positive cable from the charger to the switch and cut it to length with the cable cutters. Strip 3/4 inch of insulation from the cable ends with a razor knife. Splice the cable to the hot wire from the charger with a **** connector and the terminal crimper. Crimp a terminal lug onto the battery end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery switch positive output terminal.
Step 5
Lay out a battery cable from the charger to the battery negative terminal block. Cut the cable to length and strip 3/4 inch of insulation from the ends with a razor knife. Connect the battery negative cable to the charger negative power lead with a ****-splice and the terminal crimpers. Crimp a terminal lug onto the terminal block end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery negative terminal block post.
Tips & Warnings
Set the switch to "1," "2" or "both" to charge battery bank 1, bank 2 or both batteries at once.
on Jan 07, 2010 | Mercedes-Benz C230 Cars & Trucks
Honestly, I would just like to turn off the timer. It is in my office serving no purpose and making an incessant noise. any advice
You posted under Intermatic box timer.
There are three ways to turn off timer.
1) Turn off circuit breaker momentarily, disconnect black power wire that connects to terminal 1, and then cap off wire. -Or- remove all wires and cap off each wire, then take timer home and put on your lights or pool pump. Basic 120volt timer is worth about 40$+.
2) If you do not have access to circuit breaker, you can risk life. Wear gloves. Stand on dry surface. Use insulated wire cutter, and a) cut black wire that connects to terminal 1 and cap off wire and/or b) cut several wires one at a time and cap off each wire.
3) Remove trippers from dial. Result: 3 watt clock motor continues to run, but timer will not click on-off. You can still control whatever is wired to timer by clicking override switch back and forth.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Aug 09, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
Bathroom double light switch/and for exhaust fan, Both go on when you use either switch. How is it wired wrong?
Each side of the switch has two terminals. On one side the two terminals are connected together with a little metal bar that is a removable part of the switch. On the other side of the switch the terminals are not connected together. Your hot wire coming in to the switch box should be connected to either of the two terminals that are connected together with the little metal bar. Your two output wires (one for the fan and one for the light) should be connected to the two terminals that are not connected together. You apparently have the fan and light connected to the terminals that are connected by the metal bar, and you have the hot wire connected to both terminals on the other side. You could switch the wires from side to side, or you could just break off the little metal bar.
Mar 09, 2011 | Electrical Supplies
Can't get my switch to operate the outlet just bought a 5625 switch i have two wires coming out of the wall i want to plug a light in the outlet and have the switch control the power to the outlet.
  • Turn off the power to the receptacle that will be replaced by switching off the circuit breaker in the fuse box. Check that the battery is good in a circuit tester. If not, replace the battery. Place the tester's two ends in one set of the receptacle's slots, then the other set. The light on the tester should not come on. If it does, the correct circuit breaker has not been switched off.
  • 2
    Take off the receptacle's face plate by first removing its screw. Detach the two screw securing the receptacle to the box and pull out the receptacle. Loosen the receptacle's terminal screws and pull away all wires from the back of the receptacle. Take out the receptacle (if working properly, it can be reused). If the ends of the wires are chewed up after removing them from the existing receptacle, cut them off with wire cutters. Strip off 1/2 an inch of insulation from the ends, using wire strippers. Bend them into loops with the pliers.
  • 3
    Bend the copper ends of all wires into a loop, using a pliers. Connect the white wires to the silver terminal and tighten the screw to the wires. Connect the black wires to the gold terminal and tighten the screw to the wires. Connect the bare ground wires to the ground terminal and tighten the screw to the wires.
  • 4
    Push all cables into the back of the box, followed by the receptacle. Attach the receptacle to the box with the two screws. Hold the new faceplate in position and install the screw. Turn on the power at the circuit breaker.
  • HOPE THIS HELPS YOU...Jim...Please leave a comment
    Feb 13, 2011 | Leviton Electrical Supplies
    Self propelled feature runs backward after I damaged my switch
    You have placed the wires from the carbon brushes on the wrong terminals. The wire from the carbon farthest from the switch goes on the upper switch terminal, and the one next to the switch goes on the lower terminal.
    Jan 30, 2011 | Kirby G5 Bagged Upright Vacuum
    My end of my headphones where you plug it in. has broke and i cant listen to music
    If you are any good with a soldering iron you can fix it yourself. You can buy a jack plug from your local hi-fi electrical shop. With some wire cutters cut the old plug off. Bare back the cable to reveal the wires. With a sharp knife open up the old jack plug. This will show you where the wires connect to the terminals of your new plug. If it's not clear where they go, the earth wires (left & right) which are around the two coloured wires, go on the large metal lug (they are not channel specfic). Attach the first coloured wire to the smaller terminal and the other wire to the other terminal. These coloured wires are the left and right channels. If you get the wrong they can be swapped and it won't cause damage. Make certain the solder doesn't short the terminals. If the sound is tinny/spaced out, the earths are not connected right.
    PS don't forget to put the cover to the jack on the cable before you fit the rest of the plug!
    Jan 11, 2010 | Skull Candy Audio Players & Recorders
    Miller Spectrum 375 problem
    It sounds like you have a problem in the power supply input area. Make sure your voltage select switch is in the correct location. Unplug the unit and switch back and forth between the two positions to clean the contacts. Try again. If still bad check you terminal lug connections on the input lead wires. If still bad please answer these questions.
    Does the power indicator come on at all? Does the fan start?
    Nov 12, 2009 | Miller Spectrum 375 Cutmate Plasma Cutter...
    I am trying to install a 2 way gang switch, i have put the two red wires in the bottom terminals the black and yellow in the right terminals, but they are not working two way, i have a spare blue wire...
    There is no simple answer. It all depends where your feed is and which switch is the "point". The point is the black wire bringing switched power to the fixture. Both the point, and the feed will be on the top black terminal on one or the other THREE way switches. The travelers go to the bottom two terminals and the neutral, usually white wire, just splices through. I hope this helps.
    Sep 21, 2009 | Cooper Wiring Devices 2-gang Cooper wall...
    Cd cut40d plasma cutter China
    From inside the machine follow the wires coming from the front panel control connection. Look closely for you will most likely find either a broken, disconnected or loose wire. The wires from the front panel connection run 1st to a small PCB( 1"x2" roughly) mounted vertically at the bottom front right of the machine frame, you may want to remove that pcb to get a closer look the connections. Wires then leave that PCB and run to a snap in connector on the front left side of the front bottom PCB, check the wiring that terminates in that snap in connector.
    Regards, Larry
    Dec 29, 2008 | A & A Manufacturing Ramsond 40D Plasma...
    Garden Logo
    20 people viewed this question
    Top kawasaki Garden Experts
    Jim Parker
    Jim Parker
    Joseph Mueller
    Joseph Mueller
    Phil Walker
    Phil Walker
    Are you a kawasaki Garden Expert? Answer questions, earn points and help others
