Question about Fisher and Paykel GWL11 Top Load Washer
Wash rinse and spin lights on, what does that mean?
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 25, 2011
Testimonial: "thank you so much, will try it, but need to find it first, we have a fisher and paykel washer"
What’s the problem with a fisher and paykel wash when the wash and rinse and spin lights up with beeping and washer stopping on rinse
You need to be more specific. There are 5 wash lights and two rinse lights. Each have a different number value when working out the error code. Count from left and say what number light is on. Spin being the 8th light from the left.
May 17, 2018 | Fisher and Paykel Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Novotronic 1918 front load washing machine- not spinning 1st and 2nd rinse lights flashing
the flashing lights mean it's "disabled". You need a qualified repairman to service it further.
May 06, 2012 | Washing Machines
Maytag MAH8700 AWM will not spin during rinse cycles
As you said in the question you are washing machine need to get services during rinse washing machines should spin.Try selecting only rinse option only.If it does not spin means just services it will be fine.Thanks for you are question.
Jun 17, 2011 | Maytag Washing Machines
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
320 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
