Question about Garden
What parts do I replace in order to repair electric brake on a Hitachi C10FSH
  • 710 Answers
On miter saws, the switch controls the brake, so you might start by replacing the switch. Have you checked your brushes? If they don't have good contact on the armature, I believe this might cause the problem also. However, I would try the switch first.
Handie Andie
Posted on Mar 25, 2011
Trying to remove brushes on my Hitachi C10FSH MITER SAW. Removed caps on sides of motor housing with no problems. The brushes will not come out, scared to pull on springs to hard. Suggestions please!
You might have let the brushes go to long and they are worn so far that they came out of the holders. Maybe try turning the blade backwards while pulling on the brushes.
Jan 30, 2017 | Hitachi Saws
The lever to release the turntable for mitre cuts on my Hitachi C10FSH is disconnected. How can I tell if it can be reconnected or how to repair it?
try to look at another one thats complete,to give you an idea.then enquire to see if you can get parts
Feb 17, 2015 | Hitachi Saws
Braking on miter saw not working
Try fitting a new set of brushes first otherwise it could be that it needs a new field coil.
Dec 27, 2013 | Hitachi C10FSH 10" Dual Bevel Slide...
How do you remove the brushes on a Hitachi C10FSH compound miter saw?
On the sides of the motor housing there are two small, black screw caps about as big around as a dime. By removing those the brushes will come out. Most come out easily but if they are in very tight, be carefull not to strip out the screw driver slots. The caps are made of a hard plastic that breaks easily and if the slots are stripped out they are very difficult to remove.
Sep 18, 2012 | Hitachi C10FSH 10" Dual Bevel Slide...
Hitachi C10fsh laser doesn't workWhat's your problem?
Hello
If Laser Pickup Unit do not works, it has to be replaced as unit. There is no repair to this part, and only replacement could be done.
I've included picture of both DVD mechanism alongwith laser pickup unit, and idle laser pickup unit here. It will be best to replace the unit with its chasis. 2_28_2012_4_10_53_am.jpg2_28_2012_4_11_29_am.jpg
Feb 27, 2012 | Televison & Video
AFTER NOT USING MY HITACHI C10FSH FOR A YEAR OR SO. I TURNED IT ON YESTERDAY AND I HIT THE TRIGGER AND IT STARTED, I THEN SET UP MY CUTS AND IT WOULD NOT START. AFTER CHECKING THE POWER SOURCE, I PRESSED...
with the tool unplugged check that the two carbon brushes are free in the holders . remove the two caps locking them in and take them out , blow out and replace . be careful make sure when putting them back in that the caps do up nice an free. possibly dust stopping brushes from making contact to armature .
Aug 16, 2011 | Hitachi C10FSH 10" Dual Bevel Slide...
Can I replace the screen on a hitachi 57f510 myself?
You can find a new OEM Hitachi replacement lenticular screen and Fresnal screen (availble together as the screen assembly) for a model # 57F510 from a major Hitachi distributor at the following links:
Hitachi 57F510 Replacement Part Screen Assembly (Fresnal Screen w/ Lenticular Screen)
And here's a link for the protection screen if needed:
Hitachi 57F510 Replacement Part Protection Screen / Super Shield
You should be able to replace it yourself with basic electrical knowledge.
Apr 13, 2009 | Hitachi 57F510 57" Rear Projection...
The laser light doesn't work on the hitachi c10fsh
Take the unit off your saw. There should be a removable back side that will allow you to replace the coin battery inside the unit.
Good Luck!
Ben
Jan 12, 2009 | Hitachi C10FSH 10" Dual Bevel Slide...
Garden Logo
151 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
