Question about Suspension & Steering for Buick Century
Hard heavy thump/thud in right front end when turning left -- we have a lot of pot holes this year
    Scholar:
  • 65 Answers
Hello
I would first start with the sway bar end links, they could have broken, they are just 2 bolts with bushings and spacers that tie the sway bar to the suspension the sway bar goes from the drivers side to the passenger side of the car if the links are not broke check to see if the sway bar is not broke if none of these then check the front suspension ball joints and tie rods
Good luck
Chris
Posted on Mar 25, 2011
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
00Linc ls noise from front end sounds like tire road noise steering wheel shakes a little
Wheel bearing? If you turn left and it gets louder. It is the right wheel bearing. And vice versa.
Nov 07, 2015 | Cars & Trucks
Front end vibrates at any speed
have a wheel alignment done as the upper strut mounting plate was not put back in the right place . . The mounting plate is off set so by turning it around ,the wheel alignment changes and when the strut was re assembled the original holes were not in the right place and the alignment has altered.
Mar 23, 2014 | 1999 Honda CR-V
Loud thumping inback end when i hit a bump and ginding on turns in the front end
check the u joints in the drive shaft or the rear end needs greased,or it could be going out.have you changed both the inner bearings as well on the front end?
Aug 10, 2012 | 2003 Buick Rendezvous
Thumping coming from front end all speeds.
IF IT ONLY THUMPS WHEN YOUR CAR IS MOVING YOU COULD BE WRITE. PAY ATTENTION TO THE THUMPING CLOSLEY, DO YOU FEEL A VIBRATION IN THE STEERING WHEEL, IF SO THE PROBLEM IS IN THE FRONT END. IF YOU FEEL A VIBRATION IN THE DRIVERS SEAT THE PROBLEM IS IH THE REAR END. YES THE VIBRATION FROM THE FRONT STEERING AND THE DRIVERS SEAT IS A WAY TO TELL WHERE THE PROBLEM IS
Aug 10, 2009 | 1994 Volkswagen Jetta
Heavy thumping noise with the turning of the drum
sounds like your rear bearing is bad, look in the rear center of your drum. for a crome pop out plug. Pop it out with a flat srew driver
there will be a nut that holds the drum in. take that nut off and you can lift the drum right out the front of your dryer. the front cover pops off after you take out the 2 screws from the lower front panel.
Aug 08, 2009 | Dryers
04 Pilot front end noise
This would be your front struts.
Aug 07, 2009 | 2004 Honda Pilot
1997 Cadillac Deville vibration
suspension problem my friend have it check
Jul 01, 2009 | 1997 Cadillac DeVille
Thump noise in front end
Have your CV joints inspect.
Mar 21, 2009 | 1999 Buick Century
Suspension & Steering for Buick Century Logo
266 people viewed this question
Top Buick Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jeffrey Turcotte
Jeffrey Turcotte
mike
Are you a Buick Vehicle Part and Accessory Expert? Answer questions, earn points and help others
