for the whole car, wow. tall order that.
surely we can focus on an area,
under hood
- gas tank EVAP parts? rear of truck.
- Evaporative emission canister purge valve on engine
- HVAC vac parts?
- brake booster..
- EGR vac, reg solenoid.
- Throttle body leak vacuum or gummed up throttle valve.
- IAC , stuck, a vacuum + elect, part for idle controls
- PCV valve leaking or hose to it cracked, is Vaccum.
engine problems? no hint as to what's up doc.
Scanning PCM shows DTC errors , ??
fails smog for evap or egr? both?
brake problems?
HVAC problems?
there is a sticker under the hood for engine hose routing, (lost?)
the service manual covers all that ( we have none)
https://eautorepair.net/Marketing/Default.asp
is this a vac hose fell off question
or how to test vacuum related parts>
best of all is post photos of things wrong under hood
like hose not connected then tell or show where the other end goes?
