SSID 2WIRE277 Network Key: 7797145128 Printer: Brother MFC-885CW In order to fix my scaning problem I need answers to the following questions: a. Name of the Network b. Authentication mode c. Inscription mode d. Network key. Your help would be appreciated.
  • 1,591 Answers
Network name: 2WIRE277
Authentication Mode: open
Encryption Method: WEP (64 bit)
Have a great day, and thank you for choosing FixYa.
Posted on Mar 25, 2011
Need manual for mfc-885cw
Welcome to Fixya.
Here's where you can view/download the user's manual for your printer :
Brother Printer Manual
Thanks for using Fixya.
Jul 26, 2011 | Brother Office Equipment & Supplies
After I scaned and faxed a document from my Brother MFC-240C, I got an error: print unable 4F. I checked the printer that no paper jammed, what's the other issue?
Hi oliver_calga,
You can fix this if you access the internal maintenance mode and do the following:
1.First, press the Menu/Set button.
2.Then press * 2 8 6 4 within 2-3 seconds. This should put you in the maintenance mode menu.
3.Enter 80, and then scroll down with the arrow down key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the error message.
Hope it helps.
Thank you for using FixYa.
Jan 31, 2011 | Brother MFC 240C All-In-One InkJet Printer
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
MFC-7840W Printer: need tp set the wireless setting, lost the instruc...
To setup your Brother MFC-7840W on a wireless network do the following:
Press Menu.
Scroll down to #5 LAN and hit OK
In the LAN submenu, scroll down to 2. WLAN and hit OK.
In the WLAN submenu select 2. Setup Wizard.
(The printer will search for the SSID of your network. If you are presented with multiple networks, select yours and hit OK.)
Depending whether you have setup a network key on your wireless network, you will have to choose the type of connection. Your options will be Open System, Shared key, and WPA/WPA2-PSK.
If you have a Shared Key or WPA/WPA2-PSK network, then you willhave to enter the key to connect. Open Key does not use a key to connect.
So for instance, if you selected WPA2-PSK you will then be asked to enter your passphrase key to connect to your wireless network.
May 16, 2010 | Brother MFC 7840W Printer
I have a brother mfc-885cw and I dont knoe how to
You have to connect the machine to the computer using a USB cable and install the S/W you got with the machine from the CD. That will have a TWAIN driver and some scanning S/W you can use to scan a document in to the computer, then you can email it. Please see document called Software user guide on the disc. If you don't have the CD you can go to Brother website and download the manuals and the S/W.
Jan 25, 2010 | Brother Office Equipment & Supplies
How do I connect a brother HL-5370DW printer with a Linksys WRT54G V8 router? The Brother manual and website says I must record my current wireless network settings for the following: Communication...
This means your SSID, or the name of your wireless connection, the encryption method whether it be WEP or WPA or WPA2 and the Pre Shared Key, these won't be in your manual, but you would have set them up when you intially setup the wireless router.
Jan 07, 2010 | Brother MFC-7820N Printer
I have a Brother MFC-885CW printer. A friend
I have a Brother MFC-885CW also and I have changed the colour inks no problem but now I have just changed the black it will not print black.
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-885CW Wireless keeps saying it's not connected to the computer yet it printed yesterday fine
hai ,salva,just finish to install mfc-885cw,wireless,when i try to install mfl-pro suite,at the end evething is fine except the printer,is not install.problemwith root directory of cd-rom.can you help please
Nov 13, 2008 | Brother Office Equipment & Supplies
Printer's MAC address
Hi!
I was able to locate this information for you on tht Toshiba FAQ section of their tech support site. Here is it, verbatim:
How do I discover the MAC address of the Brother network card?
To discover the MAC address of your Brother network card you will need
to print out a Network Configuration Report. To print this report
complete the following steps:
1. On the Brother machine press MENU.
2. Use the up or down arrow key to scroll to PRINT REPORTS and Press OK.
3. Use the up or down arrow key to scroll to NETWORK CONFIG and Press
OK.
4. Press BLACK START
5. The Network Configuration report will print. On the report, find the
section labeled <(><<)>Ethernet Address>. (Example: <(><<)>Ethernet Address> 00-80-77-90-0a-8c) This is the MAC address of your
Brother network card.
Oct 07, 2008 | Office Equipment & Supplies
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
152 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
