Question about Extron Electronics VSC 700 (60-477-02)
My vsc 700 wont power on? - Extron Electronics VSC 700 (60-477-02)
  • 6,993 Answers
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.
Posted on Mar 25, 2011
Engine turns over, car won't start
Engine Cranks But Wont Start - Professional Mechanics ...
www.2carpros.com/articles/car-cranks-but-wont-startJul 15, 2015 - Step 1 - A fuel pump operation failure will cause the engine to not startdue to ... The power distribution center of a vehicle houses fuses which .... Works atCVS ... I have a 1991 ford f150 the motor turn over fine but it won't start.
Car won't start - check VSC light - Club Lexus Forums
www.clublexus.com/.../is.../519132-car-won-t-start-check-vsc-light.html
Aug 13, 2010 - Car won't start - check VSC light IS - 2nd Gen (2006-2013) ... Carmakes an exaggerated version of the engine startup noise. Hard to describe the noise, but the one that sounds like .... It stopped accelerating, the VSC check & check enginelights came on. I immediately pulled over. Waited a few minutes.
Nov 22, 2015 | Cars & Trucks
What is a vsc in a toyota aurion?
VSC Is ..Vehicle Stability Control..It is a control system for traction loss,scidding,.If one tire loses traction it will light up..It shouldn't interfere with starting...Make sure all CV Axles for drivetrain isn't damaged...?..Did this happen all of a sudden..?..You can wear safety glasses and disconnect negative battery to erase the code and reset the computer..Reconnect and then try to start it..Be sure car is in park..!
Feb 20, 2015 | 2008 Toyota Camry
05 gx470 check engine and vsc trac lights are on, wont accelerate past 35
i had an issue with a nissan xterra and it turned out to be a Cam position sensor. Who would have thought? Engine light would be my primary concern, local auto parts store (advance or autozone) can pull the service engine code.
Dec 18, 2013 | Lexus GX 470 Cars & Trucks
Will it hurt 2007 tundra to drive with the VSC off light on
no , it will not hurt it vsc=vehicle-stability-control its wont haver traction control so it will spin the tires easier when its wet/snow
Jul 29, 2012 | Cars & Trucks
Vsc/vsc off check engine light gs300
go get your codes read. sounds like possible misfire due to lack of power. call around alot of places read codes for free then you can start there.
Jul 18, 2012 | 2001 Lexus Gs 300
My tv wont turn on
Check voltages in power supply to determine if power supply is bad. Check vs, va, vsc, vce, 5v, 12v, 3.3v, 1.8 v to see if you have these voltages coming out of the power supply.
Nov 19, 2011 | Hisense TA42P40M 42 in. Plasma Television
What is a vsc warning light on a toyota estima hybrid ?
It stands for Vehicle Stability Control When the VSC system takes control it activiates stability correction. The slip indication light flashes while the buzzer activates. The VSC is able to operate at all times except when the centre differential is locked. When the centre differential locks, the VSC-OFF light in the combination meter illuminates to inform the driver that the VSC function has been turned OFF. The centre differential lock is designed for freeing the vehicle if it is stuck in mud for example, however it would be difficult for the vehicle to free itself if the engine output were reduced due to the operation of VSC. Therefore when the centre differential is locked, the VSC function is turned OFF.If a malfunction occurs in the VSC system, the VSC warning light illuminates to alert the driver. If the vehicle with VSC begins to oversteer or understeer because of an emergency avoidance measure, or by excessive speed in a corner, VSC will automatically activate. By adjusting the engine’s power output and braking each wheel independently, VSC helps to return the vehicle to a ‘zone of stable operation’..
Aug 10, 2009 | 2007 Toyota Highlander Hybrid
2002 toyota 4runner with the engine,vsc off,vsc trac lights on
NEED TO HAVE COMPUTER CHECK FIND WHAT CODE MADE THE ENGINE KLIGHT COME ON.. AND HAVE IT FIXED,, VSC LIGHTS COME ON BECAUSE THE COMPUTER DEACTIVATES THE VSC AS A SAFETY FEATURE WHEN CK ENGINE LIGHT IS ON
Jul 30, 2009 | 2002 Toyota 4Runner
Laptop wont start ... ( Presario 700 )
chk your ac adapter bro .. i think its not working
Aug 27, 2008 | Compaq Presario 700 470024-192 Notebook
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
Extron Electronics VSC 700 (60-477-02) Logo
172 people viewed this question
Top Extron Electronics Televison & Video Experts
Are you an Extron Electronics Televison and Video Expert? Answer questions, earn points and help others
