Im just trying to get my viewstat VS2000working again . need to find where bin and files are to make it work . i have a usb flash drive to put code in VS2000 ,but cant find now been off line for long time
  • 27,725 Answers
If you mean that you cant access
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on Mar 25, 2011
  • bingd69 Mar 25, 2011
    very informative but not what i was looking for .. was looking for bin code to get my VS2000 working again for free to air programs .. thank you for reply
Hi im looking for info on how to flash or load windows ce on a neoware ca5 thin client, i have downloaded the Os but have no clue how to load it on the thin. can you please assist me
  1. Make a bootable USB drive using HP Drive Key Boot Utility (via bootdisk.com Method 2)
  2. Format the flash disk in the device.
  3. Make the flash disk in the device bootable using MBRTool (This is necessary if you installed GRUB on the disk. The MBR needs to be overwritten)
  4. From the Win CE installation folder, from drive:\<path to wince installation>\PLATFORM\CEPC\SRC\BOOTLOADER\DOS\BOOTDISKcopy all files and paste it to the flash disk in the device (These files always comes with Win CE installation)
  5. Put your build of Win CE - EBOOT.BIN in the flash disk on the device (This will be your custom Win CE image)
  6. Remove the USB drive, and boot the device. Your new build of Win CE should boot up.
Aug 26, 2010 | Computers & Internet
How do i erase all on a sandisk memory card so i can use as a back up again. I am trying to make a new recover disk. It is low on space and so when it starts the save process, it gets partly done and...
>> 4.00 GB drive
>> 7.47 GB free
Something's wrong!
Connect the flash-drive to a USB port.
Open "My Computer".
Right-mouse-click on the icon for the SanDisk.
Choose Format.
Enable "quick-format", and click OK.
Aug 02, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a 16G USB flashdrive. I'm trying to save files from a video surveillence DVR and it was working fine until now. I started getting an error message saying the drive is full. i deleted engough...
When the drive is plugged in, empty the recycle bin or trash can on the computer. It may still being seeing used space because the files are technically still there. they don't really go away till you empty that recycle bin.
Jun 29, 2010 | PNY Attach? 16GB USB 2.0 Flash Drive
BD-HP21 cannot find update on my flash drive. Formatted the flash drive twice (FAT32 & NTFS) extracted the zip file on to the hard drive and copied the update file to the flash drive. Help!
Let's start from the beginning again. Go ahead and reformat your usb device to fat 32 wiping everything. Next go to www.sharp.ca
Click on Service Support on the left and next click on downloads. Select Bluray, next and then your model number, done.
Then save the firmware directly to your usb device.
If the usb device is larger than 4GB it might not work.
If the download still does not work try formatting the usb device again this time to fat and then dowloading again.
You may need to reset the bluray player. Hold down the power button on the front of the unit until it says reset. Then put the usb device into the player before turning it back on. Press setup-->settings--->software update.
May 05, 2010 | Sharp BD-HP21U Blu-Ray Player
Bios update. I have .bin file, but flash is not working.Chaintek MPM800-3.
Bios is best flashed from a dos (or similar) floppy disk. If you have a floppy then you need to download a boot floppy (I prefer win 98 ones)
and then copy the bin file and the flash utility to that disk.
Bootdisck.com has a selection
Boot from the floppy (you may have to set your bios to do this)
If you don't have a floppy try borrow a usb floppy drive (you may have to tell your bios about it)
If you have windows working there are flash programs that will work from windows.
As with all bios procedures make sure that you have the CORRECT bios for your board. Other bios's will not work and may end up harming your board
Also ALWAYS make a backup of your original bios (best to copy to a flash drive as soon as you can)
Aug 24, 2009 | Chaintech Computers & Internet
Deleted .bin file on disk
you either you put it on wrong file, or the type of file the songs are might not be supported by your phone
Feb 23, 2009 | SanDisk 2GB microSD Memory Card
Flash drive failure
You need to format your drives. Even though you delete files on them a small amount of data remains each time. After so long the data builds up and clogs the drive.
Insert a USB with a problem
Go applications, Disk utility
open disk utility, then you should see the USB disk in the utility screen. click on then click format. It will kill all data on the USB and make it usable again.
Jul 01, 2008 | Apple MacBook Pro Notebook
Toshiba 2GB USB Flash Drive Capacity Problem
format the Flash Drive in in slow mode
click on the properties of flash drive
then click on tools then CLICK ON DEFRAGMENT NOW TAB
Mar 11, 2008 | Computers & Internet
Viewsat Ultra USB port
Ultra could be clone.
Dec 17, 2007 | Belkin (F5U304)
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
