Question about The First Years Carry-Me-Near 3-in-1 Bassinet
Wondering if there is a special way to move handle from upright position on the carry me near bassinet?
They're buttons hidden right at the base of the handle on the inside under the fabric. just push those down. I had a hell of a time myself...lol.
Posted on Apr 20, 2011
Vacuum hard to move on carpet
The key to getting an Oreck to move or push is to use as low and angle of the handle as possible. The more upright the handle, the harder the machine is to push (move). The lower the angle or the closer the handle is to the carpet, the easier it is to move (push). Use a straight stiff arm that is pointed down and move your arm at the shoulder with a near locked elbow.
Mar 18, 2014 | Oreck XL21 Bagged Upright Vacuum
I have a first years bassinet Model # Y11047, I need to know how to get the "carry-me-near ergonomic handle back down once it is in th carrying position. I don't see any buttons to release the handle
Ther are two levers on the bottom of the handle that you have to pull up to release the handle to be moved. It would be the same ones when unfolding from the travel postion.
Apr 18, 2010 | The First Years Carry-Me-Near 3-in-1...
Placing the handle of my Dyson DC07 into its upright and locked position causes the beater bar to stop turning. It will not start turning until the handle is first lowered to the working position and the...
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you get the handle from the upright position
there is a pedal on the left side near the wheel press down and lean the handle back.sometimes you have to lean the handle forward while presing the pedal and then lean the handle back
Apr 23, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Where do I put the water.
1. Release the handle and lay the machine
handle back to access the tank.
2. Remove the tank from the base of the
machine by lifting the tank carry handle.
3. Carry like a bucket to the sink. Rotate the handle forward
to unlatch the lid. Lift off and set the lid aside.
4. Fill up the bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the bladder.
5. Replace the top of the tank by matching the
lid and tank edges. Handle must be in the
forward position in order to replace lid. Rotate
Note: Remember to secure the lid and test to make
sure it is secure before picking up the Tank.
6. Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
You can download the manual from the Bissell website www.bissell.com
Jan 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
I need the manual
Here's the PDF version for the manual, from the manufacturer's website: http://content.learningcurve.com/wps/wcm/connect/fd902d8049670b5da9b6ab3efa0f6b5d/3073.pdf?MOD=AJPERES
Nov 07, 2008 | The First Years Carry-Me-Near 3-in-1...
I have misplaced the directions for the Bissell powersteamer powerbrush. I need the directions for filling the u tank etc.
Release the handle and lay the machine handle
back to access the Tank.
2. Remove the Tank from the base of the machine by
lifting the Tank carry Handle.
3. Carry like a bucket to the sink. Rotate the Handle
forward to unlatch the lid. Lift off and set the lid aside.
4. Fill up the Bladder with clean hot tap water.
destroy the Bladder.
5.
Replace the top of the Tank by matching the lid
and tank edges. Handle must be in the forward
position in order to replace lid. Rotate the handle
to the carrying position to latch the lid.
make sure it is secure before picking up the Tank.
6.
1.
Lift the formula Tank up and out of the machine base.
2. To fill the Formula Tank, first unscrew the Cap
and Insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
Cap and Insert. Place Formula Tank back into the
base of machine, making sure it is seated securely.
Note: If bottle leaks, check for proper positioning
of red gromment and straw.
Apr 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
The First Years Carry-Me-Near 3-in-1 Bassinet Logo
476 people viewed this question
Top The First Years Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a The First Years Baby Gear Expert? Answer questions, earn points and help others
