Question about HP Pavilion dv1000 Notebook
My hp dv1000 power cord goes on and off from charging mode to battery, is the power port the problem?
  • 902 Answers
More then likely yes. but i would also check the power cord/adapter/and power brick to see if it may be that.
Posted on Mar 25, 2011
  • 60 Answers
Alot of laptops have the same problem. Power ports and the plugs get wiggled around and they eventually get loosened up. It is most likely the problem. Try holding it in a position that you know it's charging and the let go and see if its still charging or not.
Hp dv1000 doesnt boot
Sounds like the battery is not being charged properly. With a voltmeter, check for voltage at the output of the charger that plugs into the computer. It should read several volts higher than the battery voltage rating. It is common for one of the wires to break just inside the plug. Radio Shack stores have a plug and cord that fits the computer, but the new wiring must be spliced into the original cord (with the correct polarity). Replacement cost for a new charger is quite high! Good luck!
Jan 31, 2010 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
Hp dv1000 won't power up running on power cord or battery
PLease check both of them. First check the power cord by replacing the power cord and see if its charging or the battery and see if it is charging.
Thanks
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Power Problem
Sounds like normal wear and tear, you might need a replacement. I'd suggest looking on eBay to help save money. Or you could proably order one from HP
Apr 17, 2009 | HP Pavilion dv1000 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
My HP DV1000 will not start.
You have a power issue. The board is not charging the system or the battery. If you know someone with a similar model, ask them if you can borrow their battery and see if your system boots with it. If it does, you may need a new adapter or the power board in the notebook is out. When you remove the battery and try it, there's enough juice to power it up for the moment, but not sustain it.
Nov 19, 2008 | HP Pavilion dv1000 Notebook
Charging cable gets hot, charge port too, not battery though
No it is not a problem. The power dissapiation in the adaptor causes it to become hot.
Jul 16, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
61 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
