Question about Refrigerators
How to clean drain tube from freezer down - Refrigerators
    Sergeant:
    Champion:
  • 202 Answers
Use hot water or comprese air... try Hot water 1st
Posted on Mar 25, 2011
Ice builds up under the pull out freezer drawer then melts allowing war we to flow onto the floor
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Aug 16, 2014 | Maytag MFD2560HES Bottom Freezer French...
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator and freezer have a bad smell. I
Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travels down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Mar 31, 2010 | Kenmore 64802 Top Freezer Refrigerator
Ice buildup on freezer floor.auto defrost puts water on floor
You have a clogged drain. If you have a top mounted freezer you might have the drain line on the outside of the fridge. Look for a tube that is thicker than the water intake line and goes from back of bottom of freezer down into the back of the unit to a drain pan. Remove that tube and take it outside and use your hose to shoot a stream of water to clean it out.
If you have a side by side fridge, your drain is still at the lowest point at the rear of your freezer. You may have to removed the rear wall of the freezer to get at it. Remove the back cover to get at the other end of the drain tube. It needs to be cleaned out also.
Apr 22, 2009 | Refrigerators
The refrigerator has a bottom freezer and the door won't open. Help
My Subzero 550 did this: The right side of the freezer has a drain that is plugged with ice. When the freezer defrosts the water runs down the inside of the box and onto the drawer rails, where it then freezes. The drain tube is normally kept ice free by an aluminum strap wrapped around the copper defrost tube in the freezer heat exchanger, which runs down into the drain tube. Over time the copper defrost tube gets some surface corrosion and the aluminum strap doesn't get warm enough during the defrost cycle to melt ice in the tube. If you can get it apart, you can clean up the tub surface with steel wool, or buy the electric defroster for the drain tube to replace the aluminum strap.
Oct 21, 2008 | Refrigerators
Maytag Frostfree Freezer ice at bottom
hi thanks for the question .The drain tube is clogged up. Pull fridge away from wall, remove back panel, clean all coils. let thaw 24 hrs. find drain tube by drain tray clean tube to freezer thanks the appliance doc
Sep 28, 2008 | Freezers
Sub Zero 550 series... The freezer door gets stuck and won't open. There's frozen condensation leaking.
Sep 15, 2008 | Sub-Zero Refrigerators
Leaking water inside fridgerator
You need to manually defrost then let sit over night .Pour warm water down the drain hole if does not go down fast than you will need to clean drain tube out with wire start at the rear of the unit and there will be a drain tube going in the drip pan good luck :)
Sep 10, 2008 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Sub Zero model 550 bottom Freezer/ Refrigerator. The freezer section keeps freezing up and the drain off water runs down the inside across the rail frezing the door shut. No matter how many times we...
Clarkk I have seen this many times. Your drain is clogged. If you pull the drawers out and pull the top cover you will see the evap. On the cover you will find a nozzle that goes to the drain. Use some compressed air and blow out the drain. In some cases there will be some silicone that will need replaced. You can get a food grade silcone sealant at a hardware store. Hope this helps.
Aug 09, 2008 | Sub-Zero Refrigerators
My Jennair Side by side has ice in freezer bottom and leaks water
This sounds like the defrost drain line is clogged and frozen. Every 8-12 hours the defrost cycle melts the ice buildup on the coils and is supposed to drain out to the pan under the fridge. Once this is blocked or freezes up the next cycles continue to put liquid water over the existing ice which then freezes, etc. till finall the area is frozen enough for water to find it's way out the door seals. You will need to take the back interior panel off the freezer side to view the coils and drain line. It will take lots of hot water to melt the ice in the drain area and the drain line in order to run a cleaning tube (basically a piece of 1/4" tubing like the water line tubing a couple feet long that you can force down the drain to make sure it's not plugged). Once you push the cleaning tube down the drain and can see it come out the other end in the drip tray pull it back out and pour hot water down it once more to watch that it drains fast. That should do it!
Feb 08, 2007 | Maytag MZD2665HE Side by Side Refrigerator
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
