Question about ViewSonic VA1716w Monitor
Problem in viewsonic VA1716w Sir, firstly my left side of screen got little darkish(right side was more brighter) after that all of a sudden picture disappeared. Whenever screen switch is tuned OFF and ON again, picture appears for 2 sec and then disappears. this is happening every time although computer is turned ON. please sort this problem. Regards Shailendra +919555022219
    Scholar:
  • 84 Answers
Sounds like a hardware failure inside your monitor.
If it's still under warranty I would suggest you return your monitor for a new one. If it's not, then I would recommend looking for a local repair shop to repair it or try to purchase a new or used monitor to replace it.
Posted on Mar 25, 2011
LN-T4971F dark on the right side of screen.
Hey Steve,
Sorry to be the bearer of bad news but you have a bad LCD panel tab. There are videos on youtube that show you how to repair this but they are temporary in nature.
Jun 28, 2013 | Samsung Televison & Video
Problem in viewsonic VA1716w Sir, firstly my left side of screen got little darkish(right side was more brighter) after that all of a sudden picture disappeared. Whenever screen switch is tuned OFF and...
First i would check my connection cables. I have had a cable go bad in the past and monitor was fine after replacing the cable. if that doesnt help, fortunately, Vieiwsonic has on eof the better support depts.
start here and select "monitor turns on then off"
http://www5.nohold.net/ViewSonic/Loginr.aspx?pid=5&eroute=ChatEscalation,EmailEscalation
Good luck and dont forget to rate FIXYA
Mar 25, 2011 | Computers & Internet
Firstly left side of the screen got little darkish. Then all of a sudden all dark. whenever screen is switched off & then On , picture appears for 2 sec and again goes off. Ever time this occurs
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the monitor will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Mar 25, 2011 | ViewSonic VA1716w Monitor
I have installed viewsonic va1716w monitor using windows xp. I am unable to set its resolution to 1440X900. from display properties it going from 1024X768 to 1280X1024
It is possible that the video driver cannot support 1440X900 resolution.
Try installing the latest video driver and then try the higher screen resolution.
Mar 19, 2011 | ViewSonic VA1716w Monitor
Says out of range
Out of range means that your computer resolution is set too high for the monitor to understand and accept.
Try restarting the computer with the screen turned on and that may correct it.
If not, You may have to reset your computer resolution to a lower level using a different monitor then hook up the viewsonic.
Aug 18, 2010 | ViewSonic VA1716w Monitor
ViewSonic VP171b resolution problem
If you went from a standard screen to a wide-screen, you have to upgrade the video card.
Also, try going into the menu option on screen and have it automatically detect settings.
First thing you should do is update your drivers.
Should have said that first.
Jun 12, 2009 | ViewSonic VP191b 19" LCD Monitor
Issue with my 17" Viewsonic VA1716w LCD monitor
If all the buttons on the front don't work I would beleive it was a cable that is not connected correctly. I've seen things like this happen on otherwise perfectly good equipment. It's probably an easy fix however, monitors have enough power to KILL YOU (dead not a little bit very dead) if your not sure what your doing find someone who is most things I encourage you to open up and play with but not monitors. (did I mention you could die)
Be careful
Rob
Dec 10, 2008 | Computers & Internet
Dark picture
pls adjust G2 voltage of picture tube. picture will be brighter.
Jun 14, 2008 | Televison & Video
ViewSonic VA1716w Monitor Logo
133 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
