Question about Vizio L32 32 in. LCD HDTV
When i turn my volume up or down on my vizio 32in tv. it wont stop after one click
    President:
  • Vizio Master
  • 1,779 Answers
Your main board needs replaced. The ic that is bad is in a Non Serviceable Area.
Posted on Mar 25, 2011
I have a Vizio 19 inch tv we lost the remote so I need to know how to turn the volume down on the tv we can't fine the volume button any where on the tv
Most times they are on the side of the TV Use you MODEL number and find the quick setup guide for the TV on the Vizio site. There will be a picture showing the volume control buttons
Dec 28, 2017 | Vizio Televison & Video
Can I default my 32in vizio tv. I am stuck in spanish and want to go back to english?
select MENU on your tv remote.
choose settings
select language
Choose English
Apr 25, 2014 | Vizio M320NV 32in 1080p LED HDTV and Mount
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
Nov 11, 2013 | Vizio VW37L 37 in. LCD HDTV
Vizio E320VL has yellow light but wont turn on even with a new Power Supply
The power supply get's it "turn on" signal from the main board. It is very likely you have a faulty main board. Do you have electronics experience??
May 15, 2012 | Vizio E320VL 32 in. HD Ready LCD TV
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
42 in Vizio TV volume stopped working
you can eithor get the board from shopjimmys.com or hook up surround sound system-and not use tv speakers
Sep 11, 2009 | Vizio L32 32 in. LCD HDTV
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Discolored lines within picture 32 inch LCD TV
I have the same tv, if you turn up the brightness and turn down the contrast that should help a little bit.... Hope this helps
Aug 15, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
156 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
