Question about Cyberhome CH-DVD 300 DVD Player
Normally when i turn on dvd player screen is blue cyberhome dvd logo but today it was red and the faces of all actors in previews and feature are a washed out blueish tinge ...do i need new dvd player or can i adjust this mtself?
  • 158 Answers
How is it hooked up to the tv??
Posted on Mar 25, 2011
Do you need the red yellow white blue and green to have it show on the power its on but it wont show up on the t.v. so if you know whats rong on it holler at me
You need tyo select the input on your tv that matches how you have the dvd player hooked up if you are using hdmi select hdmi, if you are using the red yellow green blue and white cords these are called component video cables so look for something along those lines on your input selection screen
Apr 02, 2011 | Cyberhome CH-DVD 300 DVD Player
When I start the movie the screen is dark and there is no vertical hold on the cyberhome screen
ur palyer is progressive mode u cahnge normal mode.press and hold stop button on ur dvd palyer front panel
Jan 26, 2010 | Cyberhome CH-DVD 300 DVD Player
CD won't play
Your lens might be dirty.Open the cover of player and identify the lens.Its a little glass eye.Get a clean cotton cloth dipped in methylated spirits gently rub surface of lens. Give some time to dry and replace cover.You should be ok.
Jul 19, 2008 | Cyberhome CH-DVD 300 DVD Player
The cyberhome no picture when playing a dvd on the ch-ldv 712
Sometimes portable DVD players allow you to switch to a secondary TV for playback. When this happens it disables the primary screen on the portable DVD player.
Thats usually the culprit as to why that happens.
If you have that feature on your portable DVD player you should check it out.
Jun 14, 2008 | Cyberhome CH-LDV 712 Portable DVD Player
Cyberhome CH-DVD 300 DVD doesn't work, Help! please.
It sounds like a common problem with these units, which is easily fixed...
Open the unit and look at the capacitors on the power supply circuit board, there are probably some bulging or leaking caps on it, just replace them and you should be good to go. You should replace them with a little higher voltage but keep the same micro-farad value. ie: use a 16volt in place of a 12volt.
Jun 08, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD problem
I have a cyberhome CH-300 my player running 50mins and next stuck the move .
Feb 12, 2008 | Cyberhome CH-DVD 300 DVD Player
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
No picture only sound
Try unplugging the set for a few hours. If that dosent work look in your owners manual on how to do a default reset or complete reset. Good Luck
Jul 27, 2006 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
