Machine operates OK, The drum was rubbing on the door seal and started to smoked before being switched off. Removed top and back panel,checked machine every thing seemed OK. Tryed a trial load and the machine became very noisy on spin, so turned off!
  • Washing Mach... Master
  • 822 Answers
Sorry....but sounds like the drum bearing has popped..................
cheers
Posted on Mar 25, 2011
Miele W1926 burning smell
The front support seals -felt around the top of the door -are worn out. You can order them online with your model # or call the parts distributor and tell them you need the replacement kit - it comes with the top and side seals. To get them separate is more money. You will have to take apart the front of the unit - top first - then the control panel and then the door (front). It supports the drum. You will need to scrape off the old seals and apply the heat glue for the seals. Put the new seals on and reassemble the unit. This should do it if it was rubbing on the front plastic.
Jan 08, 2014 | Miele W1926A Front Load Washer
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Two red fasing lights on right hand side of machine
Both lights flashing usually is caused by a water leak into the case of the machine which trips the float switch in the base. You can reset this by tipping the machine forwards at 45 degrees and allowing the water to drain out on to the floor. It will reset everything but if you still have a leak it will trip ou again due to the float switch.
I had the same problem with the 2 red lights flashing, which was fixed by emptying the float tray as above.
On further investigation I found that the door seal had rubbed on itself at the 6 o'clock position and had worn a small hole which was causing the water leak.
To replace or repair the Door Seal you will need to remove the front panel.
1. Turn power off and unplug machine after opening door.
2. Remove the front panel lower kick plate by inserting a thin ruler between the kick plate and front panel about 4 inches from each end and lever down until it releases.
3. Remove the 2 screws at the door lock switch on the front panel.
4. With the kick plate removed you will see 2 screws at each lower edge of the front panel, remove these 4 screws.
5. Remove the spring loaded band from around the edge of the door seal facing you and after that release the seal from the front panel and push in.
6. Remove the hex bolt from the 6 o'clock position just below the door seal on the front panel.
7. You should now be able to lower the front panel out of the locating pins and remove it.
8. With front panel removed you will be able to remove the tensioning band which holds the door seal in place around the drum by undoing the screw at the right hand side of the band at the 3 o'clock position. It is accessible from above with a long bladed screwdriver. Take note of how far it is tensioned on the thread of the screw and try not to undo it all the way or you may lose the nut on the band.
9. Once you have removed the band, slip the seal off the drum and slide the water outlet to the seal from the dispenser.
10. When you replace the seal do not do the tensioning band up too tightly or you will hear it squeak when you spin the drum in either direction.
11.Reassembly is the reverse of removal, taking care to put the door manual release strap through the inner slot in the front panel.
I repaired my door seal with Silicone Sealant and loose weave fabric tape after rubbing it clean with alcohol as i didn't want to pay $100 for a new seal from Miele.
Dec 17, 2012 | Miele Novotronic Premier 500 Front Load...
Drum motor wont start
Hi don keener
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley,faulty capacitor, or a faulty motor.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Please take time to rate me
Bud
Oct 08, 2012 | GE Profile Wizard DPSE592EAWW Electric...
How to remove powder drawer indesit w1a101
see this causes and fix it. God bless you
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the water inlet valve.
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace the door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. Follow the video for the strut replacement and remove the top springs and the inner and outer drum will pull out the front
Sep 27, 2012 | Washing Machines
The two lights to check outlet and inlet are flashing and the water will not drain away. I imagine that it's the pump or something. I've opened the little door down at the bottom left and...
In the bottom of your machine the is a tray in the tray the is a float, if the machine leaks the float lifts and hits a switch activating the two light on the fascia. By tipping the machine you are emptying the tray thus allow it to work.Most likely cause is when you checked the drain pump the flap on the front was not angled down sufficiently or you unscrewed the filter to much and water backed up into the base. Put towel on floor and tip appliance and retest
May 22, 2011 | Miele Novotronic W1918A Front Load Washer
The check drain and check inlet lights are flashing constantly on my miele w 2240 washing machine
I have a Miele W502.
Feb 09, 2011 | Miele W2240 Front Load Washer
Check drain check Inlet lights flashing any ideas?
This usually means that the water pump has not been able to completely 'drain' the water in your washing machine: this may be caused by obstruction in your Drain outlet or a faulty pump.
Your user manual should tell you where to find and check the drain plug for obstructions (could be Lint, coins, pieces of materials, tissue papers, etc).
Hope it helps!
Jan 22, 2011 | Washing Machines
Smoking washing machine
Switch it off before you burn your house down
The drum support sounds to have either cracked or come loose allowing the drum to run on the door gasket
The friction will cause the rubber to melt and burn hence the smoke.
Get a service person out to it asap
Jun 14, 2009 | Whirlpool GSC9455 Top Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
