Question about Maytag MED9600S Electric Dryer
My dryer does not turn on when pressing the control on button. I have done every test in the tech manual. Every Button Checks out with my fluke and every button and light comes on during the diagnostic test. I have checked power to the dryer everything checks out fine. During the diagnostic test which may be nothing if i press the control on button the temp led's go off and on with a press of the button and of course a beep. Any idea's why it will not turn on with just the Control On button? thanks
  • 13 more comments
  • joe_smo Mar 25, 2011
    thermostat checks out fine?????
    MED9600SQ0 dryer the control on button does not turn on the display. Did the diagnostic test and every button passes also did a button test with my meter and every button checked out fine. What gets me is the panel turns on with the diagnostic test and even the start button starts the drive motor. I am an electrician by trade but not with home appliances. I have 240 Volts to the dryer, moisture sensor,thermistor,thermal cut-off, high limit thermostat,thermal fuse, heater element and even door switch all check out. During the diagnotic test i push the control on button which triggers a beep but the temp led's go out and come back on with each push of the button and so does the temp button? any idea's???? thanks
    so the Console Electronic Board or the Machine Control Board is bad? I don't believ it is the control button itself it checks out fine with an ohm meter pressed and unpressed..
    door switch checks out fine I even jumped the closed side of the switch out with a jumper and still the same problem????
    do you know what the part number is off hand and a website with the best deal on this part?
    door switch checks out fine connected and not connected to the machine control board.
    dryer starts fine nothing binding or anything.
    motor starts fine no hum takes right off during the diagnostic test by pressing the start button. Problem is the Control panel does not turn on when i press the control on button, but every button checks out according to the diagnostic test and even checking each button with my meter? so unless the control panel board can still be bad even with all the tests saying it isn't then im leaning towards the machine control board but just a guess and these parts are expensive so i don't like buying things on just a guess...
    sorry if you are getting alot of questions but im not sure if you got my first one. The motor starts fine the problem is that when i go to put a load in the dryer and press the control on button the display doesn't turn on. I do the diagnostic test with the +,-,+,- buttons to activate the diagnostic test and every button checks out the door switch does and the moisture sensor everything the motor starts fine with the start button. the control panel checks out with my meter everything???? so unless the control panel can still be bad but pass the diagnostic test then i have no idea if it would even be the machine control board but i don't want to buy a expensive part if it is not that part.
  • joe_smo Mar 27, 2011
    door switch checks out fine and i jumped it out even. still the same problem. the motor starts fine with the start button during the diagnostic test. My issue is the control panel will not turn on when i press the CONTROL ON button. During the diagnostic test the +,-,+,- sequence every LED lights up and every button checks out with a beep and an LED off and on. Only weird thing is during the diagnostic test if i press the CONTROL ON button the LED's go off and on in the TEMP LED's and the TEMP button does the samething in its row. I do get a beep when pressing the CONTROL ON button so that tells me that it see's the button. I also checked with my fluke and it checks out through the ribbon.. so what is it i don't want to buy an expensive part on just a guess
    the control on button seems to be part #31 on the diagram actaully the plastic plunger not the actual button on the circuit board. So even when tested with my fluke for resistance when pushed and not pushed and checks out and during the diagnostic test when i press the Control On button it beeps BUT the lights go out on the TEMP LED Row the board can be bad? Your answers have made the most sense as a fault out of everyone else though just wanted to make sure before i almost order a $300 part.
    NOT every LED goes out on the display just the LED's in the Temp row
    thank you i emailed them and i will let you know what i find out
  • joe_smo Mar 28, 2011
    I called Marcone they wanted 50 dollars more after shipping and everything then midwestapplianceparts.com but thanks for your help and i will rank you on ur good help hopefully this part solves the problem.
    Helpful and now have troubleshot to only two possibilities hope the part I ordered is the culprit.
  • 1,998 Answers
Have you checked the door switch this is one of the first pieces that you should check you can actually jump past the switch by takeing a wire and stripping off both ends and inserting each into the each side of the connector. this is the first place you should start checking the next would be the wiring doing continuity tests to the motor from the timer if you have power going to the motor but the motor does not start then you have a bad motor you can test this by taking your multimeter and setting it to check voltage and putting the lead on the hot side of the motor and having someone press the button this requires you take out the entire drum to do this type of test and lastly you would look at the timer for shorted wires or loose connection message me back with your finds personally if you havent checked the dryer switch it sounds like that is your culprit I await your reply as well as if you have any further questions Thanks Rick
Posted on Mar 26, 2011
  • 2 more comments
  • Rick Ead
    Rick Ead Mar 27, 2011
    if i press the CONTROL ON button the LED's go off - this is a fault code either the touch pad or the control has a fault when the you press that control on button in test all lights should be lit here is the schematic for the control section of your machine http://www.searspartsdirect.com/partsdir... make sure part number 35 is interacting and makeing the proper connection on the board if you have any further questions message me back these boards are very well known to short out within a 3-5year period Thanks Rick
  • Rick Ead
    hold on before purchasing a 300 dollar part you can try going to www.marcone.com under contact us there is a 1800 number as well as an international number this piece is much cheaper at this company so try them out or next week I am starting a parts company on the east coast where we have boards like this used or rebuilt if you can wait i can get you a used or rebuilt control board price if not try out marcone there alot better in price then any of the other appliance parts places I await your reply Thanks Rick
    p.s please remember to rank how this opinion has helped it allows me to help others in the future in similar situations Thanks again
    get your price first on the control and message me back how much they want if its too much il try calling ahead to where im going to see if there are any in yet
  • Rick Ead
    joe just wait till monday and you can call them directly thanks Rick
  • Rick Ead
    Rick Ead Mar 28, 2011
    sorry about that with marcone they were the main ones i was useing have to look into a new discount program with customers with them 50 dollars more is ridiculous Thanks again for using fixya
    Rick
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it. Here is a link to the part.
Posted on Mar 25, 2011
  • Richard Roth
    Richard Roth Mar 25, 2011
    When you push start, does the dryer attempt to start or make a humming sound or is it quiet?
  • amyellenkend Feb 24, 2013
    I have a similar problem. We replaced the door switch but that has not helped. When we press the "Control On" button, nothing happens. When the dryer door is opened, the interior light does go on. Sometimes the control on will work, other times not. Another weird thing that may or may not be related is that when the dryer is running, it sometimes beeps multiple times throughout the cycle. Dryer is working fine when it does turn on. Thanks!
  • 4,323 Answers
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
  • 2 more comments
  • Daniel Scott
    Daniel Scott Mar 25, 2011
    Alright then the control button is bad and the panel should be replaced
  • Daniel Scott
    Bad control board as even the motor checks out fine nothing else
  • Daniel Scott
    Not the machine control board the CCU is bad and should be replaced
  • Daniel Scott
    The part no is 8558455 and you can buy it from this link.
My cabrio wtw6200sw2 has F50 code and won't spin I can't seem to find out what the code means. Could it be the motor coupler or controller board?
The F50 code for the Whirlpool Cabrio is most commonly a Motor Control Board failure.
Motor Stalled
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
? Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
? If basket turns freely, see TEST #3, page 4 of the Diagnostics and Repair manual.
The Diagnostics and Repair manual can be downloaded as a PDF document file here:
http://www.mediafire.com/?np4yufblj33c0xm
DIAGNOSTIC TESTS
There are three diagnostic test modes available: Automatic, Manual and Console. These tests allow the factory or service personnel to test and verify all inputs to the machine/motor control. You may want to allow the automatic test cycle to complete prior to going into specific troubleshooting tests.
ACTIVATION OF AUTOMATIC DIAGNOSTIC TEST MODE
  1. Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on).
  2. Select any one button (except POWER, START, STOP and PAUSE/CANCEL) and follow the steps below, using the same button (remember the button):
  • Press/hold 3 seconds.
  • Release for 3 seconds.
  • If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
  • If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause.
  • If still unsuccessful, see Diagnostic: Unsuccessful Entry.
  1. The program then checks for saved fault codes:
? If there are no saved fault codes, all indicators on the console will momentarily turn off, then
turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
DIAGNOSTIC: Automatic
Performs a five-minute automatic test with water functions to check major washer functions (door can be open). Press the same button used in step 2 above to advance through automatic test steps.
NOTE: Basket must be floating in order to agitate.
Feb 01, 2011 | Whirlpool WTW6400SW Cabrio Washer
Err68
Hi
Error E68 on Frigidaire dryer means that One of the keys (buttons) is stuck closed (active). Please check whether any button is pressed or stuck. Also try removing the lint filter and clean the contacts of the inside of the filter.
Try performing function test to check which button is at fault. Enter function test mode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists then you'll need to replace the electronic control.
Function Test--
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and “rES” will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode, the buzzer will sound 3 times and all LED’s will rapidly flash.
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power from dryer. Dryer will be reset for regular operation.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I'VE HAD MY DRYER 3 YEARS. POWER COMES ON BUT WHEN YOU PUSH START BUTTON THERE'S JUST A PAUSE AND THE ERROR CODE " F". PLEASE HELP!!
Select any one button (except POWER, START, and STOP) and follow
Press/hold
3 seconds
➔ Release for
3 seconds
➔ Press/hold
3 seconds
➔Release for
3 seconds
➔ Press/hold
3 seconds
All indicators on the console will
momentarily turn off, then turn back on with 88 displayed. After
5 seconds, the Automatic test begins.
Use the tech sheet info on page 2 as a starting point
Note to get the exact tech sheet or manual for your machine go to ServiceMatters and post your model number.
May 03, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Our Kenmore Elite HE4 gas dryer will not start although all controls on front are lite and appear to be functioning properly (settings can be changed, etc). I has been working fine for several hours until...
check the door switch and door latch. Open door, set the dryer to air fluff cycle, and manually depress the door switch. Press start button. If it started - door needs alignment to fix it.
If it did not start:
If your dryer has light inside - check if light turns off when you press the switch. If not - switch needs replacement.
If all that checks out ok - the problem is more serious, and you might need a tech to come out and diagnose it.
Mar 04, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer model #84052
check for broken belt ,bad thermal fuse, broken door switch or is it in control lock mode? let me know if you need any more help
Sep 15, 2009 | Kenmore 84052 Dryer
GE Dryer model DSXH47 keeps shutting off after about 30-40 sec.
It could be the door switch. If it vibrates a bit then the door switch senses it's open and shuts down. Give it a look
Jul 07, 2009 | GE DSXH47GGWW Dryer
Whirlpool duet dryer will not start. Panel lights come on as usual and when press start machine clicks and will not start. Light on wet sensor lights and no drying action begins.
press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly. This is a secret test and reset for your dryers control, so please keep this between us. The whirlpool people would be heart broke if they see this posted on the web ;-) . If your dryer will still not start after this test, you may need a new control. If you need a part let me know and I can ship it right to you. Good luck and I hope this will fixYa and saves you the $400.00 it would cost for whirlpool to send a certified tech to come to your home.
Mike Anderson
Anderson Appliance Repair
9865)945-3808
Dec 01, 2008 | Whirlpool GEW9200L Electric Dryer
New Machine Control Electronics needed?
HUH????? just change interface(buttons and board ) have never took time to ck resistance.. front interface just tells machine control what to do
Sep 03, 2008 | Kenmore Elite HE4 Electric Dryer
Not properly drying
If you remove the front cover hitting the reset switch is rather easy. However I did that the other day and only got 1 load done before it tripped again.
I just picked this dryer up used from a buddy the other day and am already having trouble. Also... It runs very loud. How loud is yours complared to the washer?
May 30, 2008 | LG DLE0332 Gas Dryer
Kenmore Oasis Dryer - CF codes 01, 02, 03
Remove the top console (plastic control panel) of the dryer ( 3 screws on the back, tip and slide forward). Inside the console or taped under it should be the tech sheet for the dryer (unless a previous service person did not put it back).
Read over the tech sheet. In there there will be a section on how to initiate the computer's diagnostic routine. This is typically activated by pressing and holding any button on the console (other than the stop button) for 2-5 seconds, seven times in a row. When activated all the LEDs (lights) on the console illuminate, and then the console displays the actual “F” error/failure codes. In many cases with these Oasis Dryers (model 110.67082600) and similar models the typical one which will be displayed will be F-02 code (even if you got CF 01, 02 and/or 03 before activating the diagnostic routine. F-02 indicates that a button (or possibly several) on the front (user interface) console is simply stuck. If this is the code you get, simply press each of the buttons on the main console and to find which button is indeed sticking (i.e. the one that doesn't work will be the culprit). Save the Stop button for last as that button exits the diagnostic mode, if it is not the one that is sticking.
The tech sheet (which again shold have been right inside the console housing) explains step by step how to remove the console interface board from the console housing (3 screws and 3 plastic clips). Sometimes simply plaing with the button on the board will get it unstuck, but a simple spray with electronics contact cleaner (which can be purchased at any Radio Shack or other electronics parts store) into the base of the stuck switch on the board, and pressing it quickly a few times will usually do the trick. Once the button is unstuck, no more error code, and the dryer will work fine again. If you can't seem to get the button unstuck (or if it is really damaged), you can either replce the button switch yourself (if you have the electronics and soldering know-how), or buy a new console board from one of the many online parts houses for around $100.
Again you will need to locate the tech sheet inside the console housing or order one from Whirlpool or Sears for you model for under $10 if yours is missing. Some models vary in what each code means so you will need the tech sheet to be sure.
Best of Luck Everone...
Oct 08, 2007 | Dryers
Maytag MED9600S Electric Dryer Logo
348 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
