Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I tried this method as you told , when i deletes the F drive from Disk management , it shows an unpartitioned/ unused disk space. i want to merge these two drives due insufficient disk space , can i use a third party software to merge these two drives into one ? please help me ...
  • 1,591 Answers
1.Open Computer Management (Local)
click Start, and then click Control Panel. Click Performance and Maintenance, click Administrative Tools, and then double-click Computer Management.
OR - right click My Computer and choose MANAGE
2.In the console tree, click Disk Management.
Computer Management (Local) > Storage > Disk Management
3.Right-click the unallocated space on one of the dynamic disks where you want to create the spanned volume, and then click New Volume.
4.In the New Volume wizard, click Next, click Spanned, and then follow the instructions on your screen.
Note
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
You can create spanned volumes on dynamic disks only. - if one or more of the disks is listed as BASIC on the left hand pane, click the drive you need to make dynamic, right click and choose convert to dynamic.
You need at least two dynamic disks to create a spanned volume.
You can extend a spanned volume onto a maximum of 32 dynamic disks.
Spanned volumes cannot be mirrored or striped.
Spanned volumes are not fault tolerant - if one drive fails, the data on all the spanned volumes is basically lost.
Posted on Mar 25, 2011
  • Norman Skinner
    Norman Skinner Mar 25, 2011
    NOTE: BACKUP ALL YOUR DATA FIRST !!!
    Also, spanning volumes can only be done using UNALLOCATED drive space, meaning if your C: drive is running out of space, this is NOT a solution. The solution there would be to clone the smaller drive to the larger one using a program like Acronis True Image, and once the cloning is complete, make the larger drive your C: drive.
    This can be done by changing the boot order in the CMOS (BIOS) setup, or by swapping the data cables between the two drives.
I have 320GB hard dsik capacity. But yesterday i have given by laptop to format and install OS(Windows 7). But now i am able to see only 296GB. Please let me know what will happen to remaining space.
There are many reasons.......
Maybe you have available unpartitioned space left in the hard disk. To check this:
1. Right click on the "Computer" icon on the desktop and select "manage"
2. After the Computer Management window appears, select Disk Management. It should show you if you have any unpartitioned drive space.
3. You can up or format your unpartitioned spaces from hereon. may be your harddisk is corrupted and has space 296GB only
or sometimes all drives contains some space for system file in that space is hidden
Jan 22, 2013 | SimpleTech 320GB SimpleDrive External by...
When installing windows xp, the C: drive got partioned and formed a new drive named F:, now i want to merge these two drives due to low disk space , can you tell me how to merge that two drive into one .
Hi
When you attempt you reinstall the windows operating system and you are in the WINDOWS XP SET UP, there is an option there to delete the partition.
Another option is by going to COMPUTER MANAGEMENT. Just right click mouse on MY COMPUTER ICON, click on MANAGE, click on DISK MANAGEMENT, now right click on DRIVE YOU WANT TO DELETE and there is an option to DELETE THE VOLUME. Be sure you back up your files coz it will wipe all your files there.
I hopw it helps you.Regards
Mar 25, 2011 | Computers & Internet
Please i need help i recently used windows XP disk administrator to delete some partitions of my Quantum Fireball Lct15 500GB and now it only shows 13GB avaivable, what could i do to recover the original...
use disk admin again and delete the 13 gb partition... reboot.... get back into disk admin and check the drive. you will have to create a new partition and format it before you can use it
Mar 13, 2011 | Quantum Fireball Lct15 (QML20000LC-A) 20...
I have a SAMSUNG HM320JI (320GB). After loading Windows XP Proffesional, I found that the C Drive only has 116 GB assigned t it and the hard disk proerties (in Device Manager) shows 117 GB in "Unallocated...
To increase the capacity of formatted disk space on your computer, you will need to go to Disk Management. This can be found under the Control Panel, Administrative Tools, and Computer Management. Under the Control Panel's category view, Administrative Tools can be found under Performance and Maintenance.
On the left pane, you will see several options. Disk Management is available under Storage. You will definitely be able to format your unpartitioned space here. However, you may or may not be able to expand your C Drive space with this option, it may end up becoming a D Drive, or another letter of your choosing.
If this does not work to extend your C Drive space and adding a second drive letter is not an option for you, you can either reformat to receive the entire available disk space, or, if you prefer, there is commercial (such as Partition Magic), and potentially free, software available to perform this.
Please let me know if I can be of any additional help. Thanks!
Aug 11, 2010 | Samsung Computers & Internet
My system is detecting my 20GB hard drive as 8GB.So what do i do?
right click on my computer and click on manage then click on disk manager. list of disk space existing will be displayed right click on the disk goto properties and format the unpartitioned space on extend the dive c:
Jul 01, 2010 | HP Compaq Motherboard
I have a problem with my Local Disk C .
It sounds like you formatted the Utility Partition of the HDD and loaded the OS to that partition. Check disk Management, see if you have both a C: and D: listed for hard drives. If you do, that is the likely answer.
If disk management shows only 1 HDD and a lot of unpartitioned space, then you made a disk partitioning error and will need to remove and repartition the drive then reinstall
Dec 18, 2009 | Dell Computers & Internet
Computer saying its using more space then it actually is
Go to computer management (Right click my computer and go to manage) and select disk management. There you can see unpartitioned space and used space. Create partitions in unpartitioned space.
Apr 03, 2009 | Microsoft Windows Vista Ultimate Edition
Not enough disk space to copy
Scan the drive due to possibly virus managing your disk drive. Virus can easily access through USB hard drives. If not solve the problem, so its better to format.
Mar 12, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
SHARING SPACE
Right click on My Computer and select Manage. Under Storage, select Disk Management. From here you can name and format your new drive. If the jumper for the D drive is set to slave, it should work.
Nov 18, 2007 | Computers & Internet
Seagate drive partition
This is fairly straightforward using the Windows XP tools.
IMPORTANT, copy everything you want to keep from partition F otherwise it will be deleted. Drive G will not be affected.
  • Right click 'My Computer' >'Manage' then click disk Management.
  • Right click your drive F and 'Delete Partition'.
  • You now have 210GB unused space on the drive.
  • Right click the unused space and "Create Partition".
  • Specify the size of the new partition to your requirements or create more partitions until the free space runs out.
  • You can then right click and format the new partitions. 'Quick Format' is fine unless you have been experiencing disk problems.
To swap around drive letters in Disk Management:-
  • Right click the drives and 'change drive letters', to X, Y or Z or whatever
  • Now you can change the drive letters back to F, G, H or whatever order you want them in
I'm sure you get the idea, you just have to change the letters of the drives to unused letters to make a space in the sequence (not that any sequence really matters)
Good luck
Nov 08, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
157 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
